History Version 8
Re: History Version 8
Version 8.33
Contest
- Updated: YOTA (points)
- Updated: VFDB-Kontest (Sonder-DOK)
Contest - Work
- A call sign that has already been logged will not only be displayed
after entry as "Double", but also registered 2s later as "Double"
in the bandmap.
Contest - Score Upload
- "CQ Contest" renamed to "Live Score" (contest.run),
Upload destination updated
- Contest IDs updated
Member lists updated
- RDA.TXT
- FIRAC.TXT
- FOC.TXT
- HSC.TXT
Country list
- New/changed special calls
TX0QRP FO
GB6WWA GW
GB8WWA GI
KL2A/7 W
TO5LA FH
EM1EHR CE9
EM1UTQ CE9
R81AWD UA3
TX7W FO/A
TO8FP FP
Nun schon 2 Fehlalarme, das wird immer schlimmer werden ...
Already 2 false alarms, this is only going to get worse ...
Leider habe ich keinen Weg gefunden, Cynet und Rising wegen der Fehlalarme zu kontaktieren :(
Die 8.34 Beta 8 endlich mal wieder ohne jeden Fehlalarm :D
Version 8.34
Contest
- New: World Wide Patagonia DX
Scan - Text
- Results list sorted by callsign
Settings - Station - General
- New: Scaling (All windows): 100...200 %
Windows - Bandmap
- New check box "Sum": Show band overview column
- 40m Fone extended to 7300 (if set in "Station-Bandplan")
Windows - DX Cluster - Contest
- "Show only - Multipliers": Messages for own callsign suppressed
Network
- State display for "Data Rate" and "Log deficit" improved.
- Match of own locators checked (important for VHF/UHF)
- RDA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- MC-AL.TXT
- AGCW.TXT
- DIG.TXT
- CWOPS.TXT
Fixed errors
- Scan - Distance: Band selectable again
Country list
XQ7UP/9 CE9
TO7PX FR
EM1/UW5EHR CE9
N5J KH5 20240801-
N2W KP2 20240103-20240201
AO75IB EA6
AO75IC EA8
AO75MC EA9
E51TLM E5/S
TO60CSG FY 20240406-20240721
Version 8.35
Contest
- New: MRAI - DL6RAI Memorial
- Updated: DARC Hessen HF (MIXED added)
Settings - Station - Transceiver - CAT - Offset
- Negative values allowed
Example: SDR Console and QO-100: Display=10GHz but TX frequency=2.3GHz
Band=2300 Offset/kHz= -8089500 --> Display=2.3GHz
View - Recorded Audio
- English lettering restored
- RDA.TXT
- FOC.TXT
- HSC.TXT
Country list
3D2CCC 3D2/C
GB6WW GM
RP79H UA9
RP79PK UA9
RP79V UA9
GB0SRW GM
GB8VED GM
N5J KH5 20240805-20240820
K8K KH8 20240626-20240709
3D2Z 3D2/R 20241115-20241204
Version 8.36
Contest
- Deleted: DL-DX RTTY
Fixed errors
- Keying via Kenwood CAT: Repetition of last sent serial number
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
Country list
- Prefixes VK0, AX0 and VI0 removed at Heard I. and Macquarie I.
KH7Y W 20240313-
JD1BQW JD1/O
TO0J FY
WH6LE W 20211120-
GB9DAT GM
GB6DD GM
R2024B UA2 20240610-20240625
9M1Z 9M6
KL7YK W 20240409-
9M4TOTA 9M2
9M4VM 9M2
GB9OO GM
VK2/W7BRS VK9L 20240710-20240801
K8R KH8 20240707-20240725
VK0* CE9 20240511
E51KEE E5/S
TO973FY FY 20240726-20240810
E51CZZ E5/S
Leider wieder vom Virus-Scanner Bkav Pro der bekannte Fehlalarm:
Version 8.37
Contest
- Updated: DARC HSW Aktivitaetswettbewerb (S-DOKs)
- New rules: Russian WW RTTY (before: Russian RADIO RTTY WW)
New member list
- OLYMP24.TXT
- FOC.TXT
- RDA.TXT
Country list
K8R KH8 20240707-20240728
TO2DX FM 19950304-19950326
TO2DX FR 20240928-20241007
GB1URC GM
TX7XG FO
TO2X FG
9M67MA 9M2
9M67MB 9M2
9M67MC 9M2
9M67MD 9M2
9M67MJ 9M2
9M67MK 9M2
9M67MM 9M2
9M67MN 9M2
9M67MP 9M2
9M67MR 9M2
9M67MT 9M2
9M67MW 9M2
9M67MY 9M2
E51WLG E5/S
Wie fast immer der Fehlalarm vom Virus-Scanner Bkav Pro:
Version 8.38
Contest
- New: SP Straight Key
- Updated: ARRL EME (New multiplier rule)
- Updated: UBA ON
- Updated: DARC Koeln-Aachen (Sonder-DOK)
Import - ADIF
- Additional field NOTES into "Remarks"
Contest - Import
- Operator added
Fixed errors
- EDI Mode codes 3 and 4 exchanged
Help: Settings - Station
- Split into subchapters
Master list
- MASTER_CT.TXT updated (Release 2024.10.02.00 by Stu Phillips, K6TU)
Locator list
- LCTR_MMM.TXT updated (October 31, 2024 - Source: MMMonVHF (Make More Miles on VHF))
- LOTW.TXT
- DOK.TXT
- RDA.TXT
- FOC.TXT
- HSC.TXT
- FIRAC.TXT
- GDXF.TXT
Country list
3D22 3D2/R
3D2V 3D2/R
3D2YY 3D2 20240904-20240919
FO/G0VDE FO 20240917-20240921
FO/N5LCP FO 20241111-20241116
TX9A FO/A 20250425-20250507
FO/NX1P FO/M
TX100REF FO/M 20250112-20250127
TX7MAS FO/M 20250112-20250127
TX7N FO/M 20250112-20250127
TX7WW FO/M 20250112-20250127
FO/DH5FS FO 20241004-20241023
3D2Y 3D2/R 20241115-20241204
E51SGC E5/S 20241106-20241124
KL7QK W
WH6GNK/4 W
GB2ZL GM
K2IDA KP4
KL1Y W
Endlich wieder ohne einen einzigen Virus-Scanner-Fehlalarm:
Version 8.39
Contest
- New : DARC CW Ausbildungscontest
- Updated: Russian 160-m-DX
(Points from 10, oblast determination for multiplier)
- Updated: DARC Schwaben
Settings - Station - Band Plan
- List of FT4 and FT8 frequencies added
- Send UDP "Radio Info": Second destination possible
Send UDP-Message "Log QSO":
- Points added for contest QSOs (<points>)
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- MF.TXT
- AGCW.TXT
- DIG.TXT
Country list
FO/DL7JLL FO
KP4Q W
4U30B I
TX5NH FO
Ohne Virus-Scanner-Fehlalarme:
Version 8.40
Contest
- New: WWA (World Wide Award)
- Updated: WW PMC (Peace Messenger Cities) - New "GMC"
- Updated: VFDB-DLPX (Month of SSB part)
- Updated: VFDB-Conteste (Special DOKs)
- Updated: PRO DIGI (FT, RTTY, BPSK63 -> 3 independent contests)
- Updated: FOC Marathon (Continent Antarctika=AN counted)
- New check box "> 0 points" at "Display = Contest":
Suppresses all messages with 0 points (mostly double QSOs)
QSO - Work
- QRZ.COM/QRZCQ.COM: SSL used
List of satellite names updated from ARRL
- RDA.TXT
- RRDXA.TXT
- BCC.TXT
- FOC.TXT
- EHSC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- MC-AL.TXT
- FIRAC.TXT
Country list
TX24HAID FK
VK9/W5EIT VK9C
WL7OU W
W4I KP4 20250101-20250116
UE25NY UA3
RC25BA UA9
RK25BA UA3
Keine Virus-Scanner-Fehlalarme:
Version 8.41
Attention:
In Windows 11, the "Mailslots" have recently been switched off (2024).
To work around this, see Help, chapter "Network".
Contest
- Updated: DARC contests: DOK take over from list DOK.TXT
- Updated: DARC Baden-Wuertbg. (Classes, Special DOKs, Cabrillo log)
- Updated: DARC Franken (Band 10m, Mode FM, DOKs)
- Updated: RSGB Commonwealth (Country rating)
- Corrected: WWA (DX cluster display)
UDP "Radio Info"
- Field <gridsquare> filled
Fixed errors
- Telnet messages - Line detection: Error tolerance improved
- DOK.TXT
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- AGCW.TXT
- DIG.TXT
Country list
W4I KP4 20250101-20250131
GB200LB GM
K4W KP4 20230101-20230131
IR0WWA IS
VK9AB VK9N 20250222-20250301
VK9QD VK9N 20250222-20250301
VK9YB VK9N 20250222-20250301
KH7AL W
JA1YVT/JD1 JD1/O 20250402-20250410
FO/TF1OL FO
TO1P FJ
TO8AN FS
Keine Fehlalarme auf VirusTotal:
Gesperrt
