Version 8.47
Contest
- New: Hell Contest
- Updated: UBA ON (40m added)
- Updated: EUDXCC: Multiplier Greenland DK06 removed
- Updated: DARC Westfalen Nord Aktiv.
QTCs (WAEDC + HELL contests)
- New internal QTC log file format (Cabrillo instead of Stuetzerbach)
- Contest - Edit Log - Contest Data: New "Edit QTCs"
RTTY
- New: 2Tone engine can be used alternatively to MMTTY
(See Help: Index "2Tone" !!!)
TRX control
- New: Yaesu FTX-1
Modes
- New: FREEDV
Windows - DX Cluster
- Response of Telnet commands "show/wwv" and "show/wcy" evaluated
- Blocking of message sender (spotter) callsigns by list BLOCK.TXT
Settings - Station - Other interfaces - Rotor control
- New: UDP Port 12040
Windows - Send
- New key word: Snrs (all figures in short form)
Fixed errors
- CW via CAT: Pcalv sends also unchanged callsign
Member lists updated
- RDA.TXT
- RRDXA.TXT
- FIRAC.TXT
- MF.TXT
- EHSC.TXT
- FOC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
Country list
- Deleted special calls
G8T GW
- New/changed special calls
E51MWA E5/N 20251009-20251020
9M4JOTA 9M2
TO2M FM 20251025-20251026
VK9AFP VK9X
AO84CMC EA
R035* UA3
WH6VL W
IP0A IS
AL7IH W
Keine Fehlalarme auf VirusTotal:
History Version 8
Re: History Version 8
Version 8.48
Contest
- Neu: YL World Wide Award
- Neu: DARC Ruhrgebietsaktivität (RGA)
- Updated: DARC Baden-Wuertbg. (Sonder-DOKs)
- Updated: DARC Rheinland-Pfalz Akt.Woche
- REG1TEST-Logs (EDI): FT8 -> Mode 7
- Updated: DARC Westfalen Sued Aktiv. (Bänder)
- Updated: VFDB-Conteste (Sonderstationen und DOKs)
- Updated: World Wide Patagonia DX --> World Wide Argentina DX
- Updated: Tisza Cup (Mode CW+SSB)
- Updated: FOC Marathon (Multi-Berechnung korrigiert)
QSO/Contest - Work - Callsign
- Neuer Hotkey "Umschalt+Leertaste" bei leerem Rufzeichen:
Kopiert (nur) das Rufzeichen aus der Bandmap-Zeile der TRX-Frequenz
Einstellungen - Station - Andere Schnittstellen - RTTY
- Bis zu 4 zusätzliche 2Tone-Engines zum Dekodieren nutzbar
Behobene Fehler
- Übernahme des Namens von QRZ.com auch in Contest-QSOs
- Falsche ICOM-Frequenz angezeigt über 4,2GHz
Member-Listen updated
- AAW2026.TXT (neu)
- WWA_YL.TXT (neu)
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- EHSC.TXT
- FOC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- RRDXA.TXT
- FIRAC.TXT
Länderliste
- VU7 (Lakshadweep Is.): Prefix AU7 hinzugefügt
- 4UNR: WAE = 4U_V
- Neue/geänderte Special-Calls
NP3QT W
4U7FOC I
4U8FOC I
4U80FOC I
AT44I CE9
LU1WGB/Z VP8/O
W4I KP4 20260101-20260131
3G9S CE
FO/F6HCM FO 20260110-20260205
XR9N CE9 20260110-20260117
FO/VA7YM FO/M 20260423-20260720
TX5EU FO/A 20260312-20260325
AM800TUI EA
JA0RQV/JD1 JD1/O
4UNR OE
HF0PAS VP8/H
JK1EZO/JD1 JD1/O
JK1VCO/JD1 JD1/O
JK1XML/JD1 JD1/O
Keine Fehlalarme auf VirusTotal.com:
Contest
Behobene Fehler
- AAW2026.TXT (neu)
- WWA_YL.TXT (neu)
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- EHSC.TXT
- FOC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- RRDXA.TXT
- FIRAC.TXT
Länderliste
- 4UNR: WAE = 4U_V
NP3QT W
4U7FOC I
4U8FOC I
4U80FOC I
AT44I CE9
LU1WGB/Z VP8/O
3G9S CE
AM800TUI EA
JA0RQV/JD1 JD1/O
4UNR OE
HF0PAS VP8/H
JK1EZO/JD1 JD1/O
JK1VCO/JD1 JD1/O
JK1XML/JD1 JD1/O
