Seite 1 von 7
				History Version 7
				Verfasst: Montag 30. Januar 2012, 11:07
				Version 7.01
UcxLog is SHAREWARE from version 7 !
After test on 30 days the user will be asked for registration
(at the moment 20 EUR inclusive updates for 2 years).
All test versions (Beta versions) are FREEWARE.
Setup simplified.
Contest
- VFDB: S-DOKs updated
- RAC Winter: Points for RAC call signs updated
- Work: Direction added
- New: NRAU-Baltic
Modes
- New: DSTAR
QSL - Print
- New check box "Only if not yet LOTW confirmed"
Settings - Station - Special
- New check box "Key ESC clears work window if not sending"
Settings - Station - Transceivers
- CAT COM port settings: "Auto Detect"
View - Countries
- Additional sums: 5/6/9/10-Band-Mixed
Hotkeys
- Alt+W, Alt+F8: Only remove QSO data of work window
- Esc: (New) switchable: If not sending then remove QSO data of work window
Member lists
- BCC.TXT updated
- DIG.TXT: DL2OE deleted
TRX control
- New: Ten-Tec Eagle
- TS-590: PTT ON -> ACC2/ USB input (instead of MIC)
COUNTRY.TXT Version 7.01
- New special calls
E51BKV       E5/S
TO4M         FH
TO5G         FY         20120102-20120107
TW0F         FW
TX6T         FO
Fixed errors
- Import - ADIF: Field SIG imported for DL into DOK
				Re: History Version 7
				Verfasst: Sonntag 5. Februar 2012, 15:35
				Version 7.02
Contest
- New: UBA Spring
- New: Bucuresti Contest
List DL.LST
- "Bayern Süd" changed to "Oberbayern"
COUNTRY.TXT Version 7.02
- New special calls
TO3J         FJ
Fixed errors
- REF-Contest - Wrong rule for Cabrillo 2.0 fixed
- Registration text shortened
- Black Sea Contest: Range check error
				Verfasst: Sonntag 19. Februar 2012, 16:46
				Version 7.03
Settings
- New: "Log Cloud" - Backup or synchronize logs on UcxLog webserver
ADIF
- Field QSLSDATE imported/exported
Transceivers:
- K3 shifted from Kenwood/K2 to Flexradio
  because of similar RTTY modes control (AFSK based)
- Checkbox "ICOM mode PSK" (no PSK via audio) added
  in "Settings-Station-Other interfaces"
Lists:
- MASTER list: Updated (RELEASE 2012.02.05)
- FIRAC.TXT: Updated
COUNTRY.TXT Version 7.03
- New special calls
E51NJB       E5/S
- ARRL definition for "European Russia" changed without modification note
http://www.arrl.org/news/new-russian-pr ... tem-in-use
  U/UA...UI 8/9 F/S/T/W/X, R/RA...RZ 8/9 F/S/T/W/X -->
  U/UA...UI 8/9 F/G/X, R/RA...RZ 8/9 F/G/X
Fixed errors
- DX spot window: Hotkey Alt+I
- Indication of own call sign in task bar
- DL-XMAS-Contestt: "NM" no multiplier
				Verfasst: Mittwoch 29. Februar 2012, 08:43
				Version 7.04
eQSL
- QSL - eQSL - Export/Import ADIF file
- Edit Log - Full: Checkbox "E"
- Settings - Station - Colors/QSL: New table "Confirmed="
Contest
- Canadian Province Abbreviations NF->NL, NWT->NT, PEI->PE
- Also after Undo all list are updated
QSO/Contest-Work
- Ctrl + F...: Send all key words double
COUNTRY.TXT Version 7.04
- South Sudan: ST0 --> Z8
- Malyj Vysotskij I. R1MV --> #151 (deleted)
- New special calls
  E51M    E5/N
  TO7BC   FH
Fixed errors
- TRX Control K3 RTTY/FSK: K3 separated from Flexradio
- QSL-Repeat print: Overflow at 1000 QSOs fixed
				Verfasst: Dienstag 13. März 2012, 17:33
				Version 7.05
Edit Log - Full
- Colors for QSL states
Contest
- ARI-DX: Rules for Italians added
QSO/Contest-Work
- Hotkeys for TRX frequency change in numeric block:
  "/": Decrease
  "x": Increase
  CW/SSB: 0.1/1/10 kHz - FM: 5/12.5/25 kHz
  with Ctrl: Value 2, with Shift: Value 3
Scan
- Move WFF from remarks to award field
Windows - Callbook
- Switches in Pop-Up menu for taking over of QTH, Locator, IOTA
Lists
- LOCATOR.TXT updated with
http://www2.darc.de/ukw-funksport/ukw/vhfdb/vhf-txt.zip
COUNTRY.TXT Version 7.05
- Coordinates of 3C0 corrected
				Verfasst: Freitag 30. März 2012, 10:47
				Version 7.06
Contest
- New: LZ Open Contest
QSO - Import ADIF
- Frequency expanded to 25 GHz
Scan
- Check countries
Lists:
COUNTRY.TXT Version 7.06
- B <M/N/O/P/Q/U/V/W/X> 9 --> BV (Taiwan)
- ZW0S -> PY0S
- New special calls
4U1GSC       I
3D2/W7DRA    3D2
3D2IR        3D2
9M0M         1S
CE9/R1ANF    VP8/H
EM1KCC       CE9
FK/JA1NLX    FK
FK8GM        FK
FK8HW        FK
FO/DL3GA     FO/A
FO8RZ        FO
FR/F5TNI     FR
FR/PA3GIO/P  FR
FR5FD        FR
FR5ZU/T      FR/T
JA1KJW/JD1   JD1/O
JA2NQG/JD1   JD1/O
JD1BIA       JD1/O
JD1BLK       JD1/O
JD1YAB       JD1/O
JE5DTS/JD1   JD1/O
JG4LSR/JD1   JD1/O
JH1EFP/JD1   JD1/M
JK1KNB/JD1   JD1/O
JL4CVB/JD1   JD1/O
JM3FVL/JD1   JD1/O
PY0ZFO       PY0F
VP6AJ        VP6
VP8CTM       VP8/F
VP8DBR       VP8/F
VP8DEI       VP8/F
VP8DGA       VP8/F
VP8DMN       VP8/F
VP8GEO       VP8/G
VP8THU       VP8/S
2R0JBC/p     G
4K0GNY       -
4N4U         YU         19910101-19911231
5N/LZ1QK     -
9M4CJB       9M2
9U/F5FHI     -
EG92*        EA
EH92*        EA
EZ9L         UA9        19920101-19921231
FR/DJ7RJ     FR
FO5JV        FO
FR/F4EGZ     FR
FR5GS        FR
FR5FR        FR
GB50ATG      GW
GB5FI        GW
GR3UOF       GW
HK1T         HK0M       20120101-20120109
HV0HH        -
I2RAO/HK0    -
KL7DN/1      W
MR0MVP       GI
OH0MB        OJ0        19910101-19911231
OH2AP/OH0M   OJ0
OX/NA1SA     -
PG5M/BA4RF   BY
PP0T         PY0T
RU3HD/ANT    CE9
T6LR         -
TO11A/P      FG
TO5SM/P      FS
TO7C         FY         20050307-20050317
U5ARTEK/A    UR
U5EX         UR
UA1ZFQ/4K3   UA3        19920101-19921231
UF6FAL       4L         19910101-19911231
VP2V/KF4EZ   -
VP8DNT       VP8/F
YT3B         4O         20060628-20070511
YT6T         4O         20060628-20070511
9M0L         1S
E51BKM       E5/S
E51GMH       E5/S
JD1BLC       JD1/O
JI1LET/JD1   JD1/O
9M6/OH2YY    1S
9M6/LA7XK    1S
9M6/N1UR     1S
AC3A/CE0     CE0Y
DP1ANF       CE9
GB0U         GU
GB1OL        GM
GB4HI        GW
GB4SWF       GM
GB5FI        GW
GB5TI        GM
GB2OWM       GM
HC/FT5YK     VP8/H
IA0PS        CE9
II0MZ        CE9
II0P         IS
IR0LVC       IS
IR0PS        CE9
LU/R1ANF     VP8/H
LU4ZS        CE9
N8Z          KP2        20021230-20030108
OJ1ABOA      CE9
PS0F         PY0F
R1ANF/P      VP8/H
R50YG        UN
R750FF       UA2
R750M        UA2
R750Y        UA2
RA9LI/FJL    R1FJ
S79RRC/F     S7
U5FK         UR
VK0DX        CE9
VK0JLX       CE9
ZY0K         PY0F
Fixed errors
- Russian DX contest: Use WAE list, Oblast detection PM/KO
- MVP-Contest: Multiplier check refined
- Prefix length increased from 4 to 6
				Verfasst: Dienstag 10. April 2012, 16:52
				Version 7.07
- New check box MMTTY "On top" (replaces start parameter -MMTTY_NO_TOP)
Scan - Award
- New button "List Award Names"
View
- New: Recorded Audio
Contest
- R-Contest (Nordrhein) updated
- Baden-Wuerttemberg VHF: STF
Oblast determination
..1E -> LO
..1K -> KL
..1X -> PS
..1Y -> MU
COUNTRY.TXT Version 7.07
- Mexico prefixes updated:
  XA-XI 4A-4C 6D 6F 6H 6J
- FR -> Reunion (without ask for FR/G,J,T)
- FK -> New Caledonia (without ask for FK/C))
- R-150-S entries corrected:
  RI0Q            UA9#7
  RI0L            UA9#J
- Changed special calls
R1ANF*       VP8/H
UN*          UA3        -19930501
UN1*         UA3        -19991231
- New special calls
3D2UU        3D2/R      19920120-19920215
NP3D         W
NP3D/NY2     W
R35NP        -          20070101-20081231
R85NN        UA3
R900DM       UA3
TO5K         FM
4U1WED       OE
FR/DJ8CR/G   -
FR/F6KDF/T   FR/T
UF6FAL       4L         19910101-19921231
3D2EE        3D2
9M4SAB       9M6
9U5CW        -          19970101-19971231
FK/I2GPT     FK
FK8IK        FK/C       20100809-20100819
FK8VHY/P     FK/C
FK8VHY/P     FK         20000428-20000430
FK8VHY/P     FK         20010525-20010526
FO5RH        FO
FO8WBB       FO
FT?Y*        CE9
EA/FT5YK     VP8/H      20110318-20110319
9M1CSP       9M2
9M4DXX       9M2
9M50MP       9M2
EX9X         UA9        19920101-19921231
EZ9MA        UA9        19920101-19921231
SY2A         SV/A
VP8DIZ       VP8/F
YT3B         4O         20101027-20101031
4N2*         9A         19910626-19921231
4N3*         S5         19910626-19921231
4N4*         E7         19911015-19921231
4N5*         Z3         19910908-19921231
4N6*         4O         20060628-20061231
YT2*         9A         19910626-19921231
YT3*         S5         19910626-19921231
YT4*         E7         19911015-19921231
YT5*         Z3         19910908-19921231
YT6*         4O         20060628-20061231
YU2*         9A         19910626-19921231
YU3*         S5         19910626-19921231
YU4*         E7         19911015-19921231
YU5*         Z3         19910908-19921231
YU6*         4O         20060628-20061231
YZ2*         9A         19910626-19921231
YZ3*         S5         19910626-19921231
YZ4*         E7         19911015-19921231
YZ5*         Z3         19910908-19921231
YZ6*         4O         20060628-20061231
9M2/R6AF/6   9M6
				Verfasst: Donnerstag 31. Mai 2012, 18:06
				Version 7.08
QSL
- New: eQSL - Download QSLs
- New: eQSL - Export + Upload ADIF file
Contest
- New: Juri Gagarin International DX
- IOTA: Changed rules updated
- Hamburg: Rules updated
- YU DX: Rules updated
QSO - Group Modify
- Reset of "LOTW/eQSL confirmed" possible
COUNTRY.TXT Version 7.08
- VP6 -> Pitcairn (without ask for VP6/D)
- KH8 -> American Samoa (without ask for KH8/S)
- Only special determination: 4U_IT, 4U_UN, FT.W, FT.X, FT.Z, VP6/D, KH8/S
- Prefix U5: UA3 -> UR
- 2Q --> G
- PP0F PQ0F PR0F PS0F PT0F PU0F PV0F PW0F
  PX0F PY0F PZ0F ZV0F ZW0F ZX0F ZY0F ZZ0F --> PY0F
- PP0S PQ0S PR0S PS0S PT0S PU0S PV0S PW0S
  PX0S PY0S PZ0S ZV0S ZW0S ZX0S ZY0S ZZ0S --> PY0S
- PP0T PQ0T PR0T PS0T PT0T PU0T PV0T PW0T
  PX0T PY0T PZ0T ZV0T ZW0T ZX0T ZY0T ZZ0T --> PY0T
- ZT0-ZT6 ZU0-ZU6 --> ZS
- New special calls
TO3X         FJ
3D2DX        3D2       20110318-20110327
E51EWP       E5/S      20120324-20120427
9M0L         1S        20120410-20120424
VU9LHA       VU        20110812-20110822
9M2/PG5M     1S        20070419-20070423
VK9PN        VK9N
ZQ3M         ZB2
RI1ANF       VP8/H
VK9LNO       VK9L      20060504-20060513
BT1B         BV
DL2JRM/BY8SKM BY
FO/DL7CN     FO/A      20010401-20010430
FO/DL7FT     FO/A      20010401-20010430
HK3JJH/0M    HK0M
K8T          KH8       20021026-20021110
KV4FZ        KP2
NL7AU/4      W
UA9XKB/FJL   R1FJ
VK9YL        VK9L
VP8CXV       VP8/F
GB100MUC     GM
CQ8X         -         20120324-20120325
ZQ2ER        ZB2
3D2WW        3D2       20071000-20071031
PT0T         PY0T
VP6DI        VP6/D     20020316-20020326
VP6DIA       VP6/D     20030308-20030315
VP6DX        VP6/D     20080210-20080227
VP8/LZ1UQ    VP8/H
FR5ZL/G      FR/G
FR7ZL/T      FR/T
FR7ZQ/G      FR/G
FR7ZU/J      FR/J
9M6TPR       1S
EM1HO        CE9       19980101-20051231
EM1KA        CE9       19980101-20051231
EM1LV        CE9       19980101-20051231
EM1U         CE9       19980101-20051231
PY0ZF*       PY0F
PY0ZS*       PY0S
PY0ZT*       PY0T
R2/OZ5IPA    UA2
RA1O/FJL     R1FJ
RX1OX/FJL    R1FJ
SV0LK        SV9
UA3DSP/FJL   R1FJ
XR0ZY        CE0X      20000401-20000430
ZQ2          ZB2       20120101-20120610
Fixed errors
- Wrong German caption and buttons (instead of English) in Message Dialogs
				Verfasst: Donnerstag 21. Juni 2012, 16:53
				Version 7.09
QSO - Edit
- Zero in call signs with slash
Send DX Message
- Button "Copy message to clipboard"
QSO - Work
- Band change to 30m: SSB changed to CW if not in band plan
QSL - Send - ADIF File
- DXCC-ID added
Contest
- New: Kazakhstan DX Contest (UN DX)
- New: Worked All Provinces of China
- New: Kulikovo Polye Contest
- New: Portugal Day Contest
Update
- Information for Beta testers if newer beta version is available
Lists
- IOTA.CSV updated
COUNTRY.TXT Version 7.09
- ZQ -> Gibraltar
- 3D2 -> Fiji (without ask for 3D2/C+R)
- VP8 -> Falkland Is. (without ask for VP8/G+H+O+S)
- New/changed special calls
VK9PN        VK9L      20120523-20120530
KH2D/NG4     W
TX5VT        FO/M
EM1HO        CE9        19970305-20060212
EM1HU        CE9        19970201-19970228
EM1KA        CE9        19970102-20010403
EM1KCC       CE9        20010201-20020131
EM1KGG       CE9        19991005-20021210
EM1KY        CE9        20000401-20010430
EM1LV        CE9        19980201-20011031
EM1U         CE9        19990327-20040831
EM1UA        CE9        20030826-20040106
JD1BMG/JD1   JD1/O
Fixed errors
- Direction in VHF-Contest-Work window not updated after selection
  of other locator
				Verfasst: Montag 2. Juli 2012, 09:12
				Version 7.10
Contest - QTC receive
- Automatic completion of leading time digits
Fixed errors
- QSO - Edit Log - Short:
  No country determination for some call signs with "0"
- QSO - Import - ADIF
  Bands 60M, 4M, 1.25M imported as frequency + band='???'
				Verfasst: Dienstag 4. September 2012, 08:14
				Version 7.11
Contest
- New: Venezuelan Independence Contest
- New: RAC Canada Day Contest
- New: RSGB Low Power Contest
- New: DIG QSO-Party, Fruehjahr-, Kurz-Contest
- O-QRP: January, July, December separated
eQSL Upload
- Upload of Remarks possible
QSL - Received
- Warning if call/QSO is marked NEVER/NOT to be printed
Telnet 2
- Pop-Up menu to add actual TRX offset to DX message frequency
  (useful for skimmer after converter)
Lists:
Fixed errors
- DMC RTTY Contest: Cabrillo CATEGORY-TIME added
- IOTA Contest: Detection of AN... fixed
COUNTRY.TXT Version 7.11
- Prefix 2O -> England
- Prefix S6 -> Singapore
E51TAI       E5/S
E51YNB       E5/S
KL1A         W          20040101-
TO5U         FM
2Q0ARE       GU         20020601-20020631
KC4/N2TA     CE9
AX9YL        VK9N       20001001-20001031
VK9YL        VK9C       19780601-19780630
VK9YL        VK9L       20020901-20020930
VK9YS        VK9C       19780601-19780630
2O12W        GW
9M0C         1S         19980210-19980228
9M4SLL       1S         20120807-20120813
EM1KA        CE9        19960101-20010403
EM1U         CE9        19960101-20040831
FR???/E      FR/J
FR???/G      FR/G
FR???/J      FR/J
FR???/T      FR/T
LU1ZC        VP8/H      19971221-19980228
OH0MAS       OJ0        19730101-19731231
OH0MB        OJ0        19960801-19960831
OK1IAI/YA    YA
TO2D         FJ
TO2U         FP
TO5M         F          19951028-19951029
TO5M         FR         20041023-20041130
TO5MM        F          19931030-19931031
TO7C         F          19911026-19911027
TX0HF        FO/A
UW2F         UA2        -20010430
VK9RS        VK          19990921-19990926
ZK1VVV       E5/S       20021101-20021111
ZV0MB        PY0T       19961008-19961010
ZV0MV        PY0T       19961008-19961010
ZX0DX        VP8/H      19980101-19980228
4K1HX        4J         19941221-19950630
9M4SEB       9M6        20060714-20060717
9M50MB       9M2
EZ9AX        UA3        19900512-19920510
GB2IOM       GD         20021005-20021012
OH3MIG/4U    YK         19930319-19930427
PA3CXC/ST0   #244       19800417-19941231
PA3CXC/ST0   ST         19950101-19970204
R100N        UA9
R100RW       UA9
R70B         UA9        20081201-20081231
SM1TDE/4U    OD         19931101-19940430
VY0A         CY9        19751104-19751107
4U0G         HB         19991218-20000313
4U48UN       4U_UN
4U49UN       4U_UN
4U50UN       4U_UN
9M0F         1S
9M4SLL       1S
9U5CW        -
AX0LD        VK0/M      20000125-20000126
FO/F6CTL     FO/A       20040525-20040527
FO/IT9YRE    FO         20040920-20040924
FO/OH1RX     FO/M       20080109-20080123
FO0CLA       FO/M       19990525-19990627
FO0CLA       FO/M       20000221-20000320
FO0CLA       FO         20000404-20010403
FO0CLA       FO/A       20010407-20010422
FO0CLA       FO         20010507-20011009
FO0IGS       FO
FO5IW        FO
FO5NL        FO
FO5PI        FO
JD1BKR       JD1/O
JD1/JA9XBW   JD1/O
LU1ZC        VP8/H      19971219-19980305
R850D        UA3
R860T        UA3
RA/UW7LL     UA3
R/N7PLU      UA3
TO7C         F          19910330-19911127
TO8T         F          19960727-19960729
TX1XX        F          19910814-19910820
VE3UWC/4U    YK         19941005-19950211
VK0LD        VK0/M      19980101-20000130
VK0TS        VK0/M      19990331-19991102
VP8PJ        CE9        20031214-20040113
VS96BG       VR
ZK1SHJ       E5/S
ZMY2K        ZL
2A*          GM         19980719-19990731
2C*          GW         19990506-19990630
2S*          GM         19990506-19990630
2T*          GM         19990506-19990630
2X*          GW         19990506-19990630
2Y*          GW         19990506-19990630
6O/G3KOX     T5         19921216-19930309
CE0DFL       CE0Y       19810406-19920119
JD1BJN       JD1/O
VI0ANT       CE9        19941001-19950330
R10RLHA/0    UA9
R10RLHA/2    UA2
R35CZF       UA9
ZK1SCQ       E5/S       19980810-19980814
ZK1SCQ       E5/N       19980816-19980822
ZK1SCQ       E5/S       19980825-19980826
ZK1SCQ       E5/S       19990805-19990818
ZK1SCQ       E5/N       19990821-19990826
ZK1SCQ       E5/S       19990828-19990901
ZK1SCQ       E5/S       20010731-20010801
ZK1SCQ       E5/S       20020805-20020822
ZK1SCR       E5/S       19980812-19980814
ZK1SCR       E5/S       19990805-19990818
ZK1SCR       E5/N       19990821-19990826
ZK1SCR       E5/S       19990828-19990828
R875R        UA3
				Verfasst: Dienstag 4. September 2012, 08:15
				Version 7.12
Contest
- New: RSGB 80m Club Sprint
- New: Russian RADIO RTTY WW Contest
- New: DARC Aktivitaets-Kurzcontest des Distrikts Ruhrgebiet
- New: AGCW Handtastenparty
Settings - QSL Layout
- Remark: New keyword <contest> for contest name
- Text 1..50: Keyword <name> added
Settings - Printer
- Adjusted printer properties survive
QSL - Print - Export ADIF
- Confirmation to include Remarks parts "..."
COUNTRY.TXT Version 7.12
- New Prefix E6 for Niue
E51AIU       E5/S
SM4GDB/4U    SU
GB2YLS       GM
E51MGA       E5/S
UA1OT        R1FJ       19840101-19901231
VP8CTR       CE9        19970207-19980327
3Y0C         3Y/B
4U9U         9U
JA0EOK/JD1   JD1/O
JA1RJU/JD1   JD1/O
JA1XEQ/JD1   JD1/O
JA1ZEK/JD1   JD1/O
JA9XBW/JD1   JD1/O
JD1/7J1AYK   JD1/O
JD1ACH       JD1/O
JD1BFA       JD1/O
JD1BIZ       JD1/M
JD1BKZ       JD1/O
JD1BIE       JD1/O      20080915-20090531
JD1BIE       JD1/M      20090610-20090618
JD1BIE       JD1/O      20090710-20101116
JD1BJP       JD1/O
JD1BKQ       JD1/O
JD1BLX       JD1/O
JD1BMC       JD1/O
JD1BNA       JD1/O
JD1BNF       JD1/O
JD1BNK       JD1/O
JD1BNN       JD1/O
JD1BNQ       JD1/O
JD1YAF       JD1/O
JD1YAH       JD1/O
JD1YBO       JD1/O
JD1YBS       JD1/O
JD1YBT       JD1/O
JF3CTR/JD1   JD1/M
JG1GGU/JD1   JD1/O
JJ1JGI/JD1   JD1/O
JL1KFR/JD1   JD1/M      19980528-19991104
JM1KNI/JD1   JD1/O
JN1HOW/JD1   JD1/O
JP1JWF/JD1   JD1/O
JQ1QET/JD1   JD1/O
JQ1SYQ/JD1   JD1/O
JR6TYH/JD1   JD1/M      20040923-20041212
JR6TYH/JD1   JD1/O      20050405-20060325
JR8XXQ/JD1   JD1/M
FO/F8DQL     FO
FO/JJ8DEN    FO
FO0AAA       FO/C
FO0AOI       FO/M       19991105-19991114
FO0AOI       FO         19991115-19991201
FO0DEH       FO/A       19990921-19991028
FO0DEH       FO         19991108-20011213
FO0DEL       FO
FO0EEN       FO/A
FO0FI        FO/A
FO0FR        FO/M
FO0FR        FO         20001025-20001031
FO0FRY       FO/A
FO0HWU       FO/A
FO0MCA       FO
FO0MOT       FO
FO0MOT/p     FO/A
FO0MSN       FO
FO0SEV       FO/A
FO0SIL       FO/M
FO0WEG       FO/A
FO0WII       FO/A
FO0XE        FO/C
FO0YAM       FO
FO0XUU/M     FO/M       19990116-19990129
FO0XUU/A     FO/A       19990202-19990210
FO5QB        FO
FO5QD        FO
FO5QO        FO
9M0A         1S
9M0SEA       9M2
9M4SJJ       9M6
9M4STE       9M2
VP8CGK       VP8/G
VP8CQR       VP8/H
VP8CQS       VP8/H
VP8DLM       VP8/H      20090224-20090225
VP8DLM       CE9        20090302-20090306
VP8NP        CE9
VP8PL        VP8/O
VP8SO        VP8/O
VP8SU        VP8/G
XR9JA        VP8/H
FO5OP        FO
FO5RA        FO
FO5OU        FO
E51AND       E5/S       20100720-20120805
E51AND       E5/N       20120827-20120915
R21GGGR      UA2
NH8S         KH8/S      20120905-20120919
Fixed errors
- Work-QSO-Round: Sporadic data loss fixed.
- QSL-Print/Received: MHz displayed if band=???
				Verfasst: Donnerstag 11. Oktober 2012, 17:58
				Version 7.13
Update - Fall back
- Fall back from beta version to last released version possible
QSL - Send - Export ADIF
- ADIF field NOTES used (instead of COMMENT) for Remarks parts "..."
QSL - eQSL - Export
- ADIF field QSLMSG used (instead of COMMENT) for Remarks parts "..."
Windows - Send - Tune
- Function added for RTTY and PSK
Contest
- Rheinland-Pfalz: 40m added
COUNTRY.TXT Version 7.13
FO8EX        FO
NH8S         KH8/S
SM4GDB/4U    SU         -19961231
GB0BRE       GW
GO2MP        GM
VP8DLM       CE9        20090227-20090306
Fixed errors
- Ruhrgebiet-Contest: Same multiplier counts again per QSO
				Verfasst: Donnerstag 11. Oktober 2012, 17:59
				Version 7.14
Help:
- New page "Menu Overview"
Contest
- New: BARTG Sprint 75
- New: Makrothen
RTTY Receive
- Check box "Auto detect" stored in settings
Member lists
- LOTW.TXT updated
- AGCW.TXT updated
- DIG.TXT updated
- HSC.TXT updated
- RTC.TXT updated
Fixed errors
- BARTG Sprint: No RST
COUNTRY.TXT Version 7.14
- European Russia: CQ zone 17 added
FO/F6BCW     FO
TO2M         FH
GB2OL        GM
GB4BPL       GW
GB4MDI       GW
RC80MO       UA3
RP67KM       UA9
RP67RK       UA9
RP67TG       UA9
YT3B         4O         20061027-20061031
TX5EG        FO
TX5FS        FK
RA/KE5JA     UA9
R750FW       UA2
YT6A         4O         -20070531
				Verfasst: Dienstag 13. November 2012, 08:58
				Version 7.15
TRX control
- K2/K3/KX3: CW keying via CAT
Worked List
- Pop up menu - New Entry: "Make window smaller"
  (helpful, if bottom edge is not reachable)
Settings - Station - Other Interfaces - Rotor
- New control "Via Yaesu TRX CAT"
Contest
- New: Memorial OK1WC (MWC)
- Updated: VFDB
- Updated: RSGB 160m
- ARRL-DX: Canadian province VO1: NL -> NF
Contest - Work:
- New check box "Log only multis"
Settings - QSL layout
- PSE/TNX QSL: Vertical offset
View - QSO Statistics
- New field: LOTW received ... %
Member lists
- EPC.TXT updated
- BCC.TXT updated
- RRDXA.TXT updated
- LOTW.TXT updated
Fixed errors
- NAC: CQSOP corrected
- Edit Full: Deletion of correct WAE country determination not possible
- Contest - Network - Shared number:
  Not allocated by F-text with Snr, special handling for ESM added
COUNTRY.TXT Version 7.15
- WAE entries
Z6              YU8	20080217-
YU8/            YU8     20080217-
GM4SID/P        GM/s    19970724-19970727
- New R150S entries
  ..8W 		UA9#9
GB2JTA       GU
TO2A         FY
TX4FO        FO
9M4CBP       9M6
E51ABS       E5/S
E51BYD       E5/S
E51C         E5/S
E51CHX       E5/S
E51KBR       E5/S
TO9R         FM
GO3UOF       GW         20120720-20120909
RI1ANF/P     VP8/H
VP8SGK       VP8/G
2R0CTT       G
3Y5X         3Y/B
4O1A         YU         -20070331
4O2A         YU         -20070527
FO4BM        FO
II0AMZS      CE9
JF7MTO/JD1   JD1/M
PJ0J         #255       -20101009
PJ1B         #85        -20101009
R100W        UA9        20091101-20091130
R60F         UA2
VE2PAB/4U    YK
ZS9Z/ZS1     #493
LU???/XP     LU
LU????/XP    LU
E51BZD       E5/S
RI1ANU       VP8/H
