ClubLog ADI tags
ClubLog ADI tags
Hi
I use the ClubLog UpLoad but are missing some ADI tags.
The <OPERATOR:xx> tag
Do you have a list of which tags UCXLog sends to ClubLog?
Re: ClubLog ADI tags
Hello Henning,
UcxLog uploads these fields to Clublog:
call
band
freq
mode
qso_date
time_on
rst_sent
What do you want to upload with the "OPERATOR" field
This is defined as the "logging operator's callsign".
UcxLog uses the callsign of the actual logging operator already as "own callsign" for Clublog login/upload
call
band
freq
mode
qso_date
time_on
rst_sent
Hi Ben
I want to log the Operator. The one set by the program.
Reason.
We are more ops using the same call and want to see who on the download from clublog.
By the way it would be nice if it also are oncluded in Adi export. Especilly in Multioperator.
Reason.
Hi again.
ADIF 3.0.4. Specification:
"OPERATOR - the logging operator's callsign
if STATION_CALLSIGN is absent, OPERATOR shall be treated as both the logging station's callsign and the logging operator's callsign"
So it would be correct to implement both.
Your used call sign during logging is sent to Clublog OUTSIDE of ADIF data, it is an extra required PHP upload parameter.
What will you say with (the same!) OPERATOR callsign
What will you say with (the same!) OPERATOR callsign ???
It is NOT the same.
OPERATOR is the actual operator.
The used STATION callsign is the used call sign.
See document
http://oz1bii.dk/documents/UCXLog%20Operator.pdf
It is NOT the same.
See document
Sri, it is difficult because the "Operator" is used for different situations in UcxLog.
We have 3 valuess:
- Main_Callsign :- This is from field "callsign" in "Settings-Station-General" while "Chief-Op" is selected
- Operator_Name: Selected field in Settings-Operator
- Operator_Callsign : This is from field "callsign" in "Settings-Station-General" while Operator_Name is selected
In the moment UcxLog uses for Clublog upload only the Operator_Callsign.
If you work at a club station, you have for example
- Main_Callsign: OZ90EDR
- Operator_Name: OZ1BII
- Operator_Callsign: OZ90EDR
For Clublog must be used:
- Log parameter Callsign: OZ90EDR
- ADIF STATION_CALLSIGN: OZ90EDR
- ADIF OPERATOR: OZ1BII
But if you use the operator for a portable operation, you have for example
- Main_callsign: OZ1BII
- Operator_Name: FYN
- Operator_callsign: OZ1BII/p
- Only Log parameter Callsign: OZ1BII/p.
Some users defined a senseless operator with Operator_Name = Main_Callsign = Operator_Callsign.
I will add a new field in the Clublog window for "Operator" and
initialize it with the operator name, if it is a valid callsign and different from Operator_Callsign.
We have 3 valuess:
New field in the Clublog window for "Operator" added in Version 7.71 Beta 7.
If "Operator" is used, these ADIF QSO fields will be added
STATION_CALLSIGN
OPERATOR
Please check entry for "Operator" in the Clublog windows before upload.
STATION_CALLSIGN
OPERATOR
Henning, for what is the "Operator" entry in Clublog needed ?
Hi Ben
YES it is working perfect.
The reason is that we do have this special call OZ90EDR througout 2017.
Read more at http://www.oz90edr.dk
All the operators uploads there logs to the same Clublog acount and then we download the whole log from Clublog.
To see who have uploaded the QSOs we only have the OPERATOR field.
So thank you Ben, for your always quick response and great help.
Happy New Year!
Happy New Year!
