I have just synced a load of logs from various systems that we have here to each other, and in the process I have found a slight problem.
All of the logs that have been sync were under my own callsign (MD0MDI).
I use a main PC in the office for doing all my QSL Card management etc, and I was working through some more card tonight and I have noticed that I cannot pull up any entries as I used to.
If I go into QSL Received and enter a call sign, I can see it in the 'Worked' window but it does not allow me to select it, and I cannot also select 'Toggle Rcvd' or Edit QSO as I am unable to get the callsign into the top window.
It does display a hint at the top of the QSL Received window stating '1 QSO with other OP', but all of the QSO's on these systems are just Me.
How can I get this sorted?
QSL Received - QSO with Other OP!
Re: QSL Received - QSO with Other OP!
Hello James,
you can see all real logged Operators in "QSO - Statistics" and you can change the operators with "QSO - Group Modify - Operator".
But if you only want to ignore all Operator entries for QSL handling then uncheck "QSL - Only current operator"
