Feature Request...
Verfasst: Montag 24. März 2014, 15:39
Hi Ben, I hope that this is in the right section...
I have asked for this before, not just for myself but others over here have said that it is a shame that this feature is not in the software as well, so I am asking again just in case it has come up by others...
Is it possible to have the 'Country' name that you are working added to the logbook so that it will appear...
In a column here where the arrow is, when I am logging I try to add the country name manually to the log but as you can see it appears after say the name of the contact and the QTH town.
I would say that nearly everyone that I have introduced the software to has liked it, but nearly everyone has asked if there is a way to glance down the log to se who you have worked, and if you don't enter this manually it can be a little harder to work out some of the countries from the call signs, and it would be so much easier to see if the country was added to a separate column either in front of the presently last column or after it.
Is this at all possible in the future?
Hope all is well and Cheers...
