DX Cluster Window - Not all band specific spots shows up...
Verfasst: Mittwoch 6. August 2014, 07:29
von LB2EG
Hello Ben,
I have been searching the documentation, but can not find an answer...
In the DX Cluster window, I have configured it to show me spots that I need on the HF band. But when I change to band specific view (RX option), I will find spots that does not show up in the general all band view.
In the enclosed screenshots, none of the spots showing worked but not confirmed entities on the 30 meter band, is visible in the all band view.
Is this a bug or a feature?
73 de LB2EG Richard
Re: DX Cluster Window - Not all band specific spots shows up
Verfasst: Mittwoch 6. August 2014, 19:16
Hello Richard,
It is a powerful feature but many users do not care about it.
Make all check boxes for bands
Black not Grey
Help:
If the check box is greyed:
A new band slot for this band will only be displayed if the entity is missed/unconfirmed on all checked bands in the selected mode.
Verfasst: Mittwoch 6. August 2014, 19:26
von LB2EG
DL7UCX hat geschrieben:Hello Richard,
Black not Grey
Help:
Thank you, Ben!
I will read the documentation more carefully next time
Richard
Verfasst: Freitag 8. August 2014, 15:49
von DF2LH
Hello @ll
I write my question in this threat, cause I use similar DX Cluster Windows settings like Richard.
With this view I am no able to see spots on VHF e.g. E Sporadic, Aurora or Tropo. Is there a way to show this spots?
Like an watchlist entry: Watch/Call: *, Show: all, Bands: 144, Mode CSR, Color: ...
So it could be possible to monitor the last 6 DXCCs on HF and the Tropo openings on favorite VHF Bands.
Sorry Ben, if this is inplemented since xxx years and I dind't find it
Best '73s
Thomas, DF2LH
Verfasst: Freitag 8. August 2014, 19:23
warum siehst Du keine Spots auf 144 MHz?
Benutzt Du etwa auch graue Häkchen ? Dann siehst Du nichts auf 144 MHz.
Oder liegt es daran, daß Du nur neue Länder anzeigst (wegen KW) und deshalb auf UKW nichts siehst ?
Was ist mit "kHz-kHz" in der Watch-List ?
Verfasst: Freitag 8. August 2014, 22:03
von DF2LH
Hallo Ben
Ich habe nicht ohne Grund: " if this is inplemented since xxx years and I dind't find it... " geschrieben.
Du hast es schon lange realisiert und es funktioniert 100% wie gewünscht. Ich habe mir die Hilfe angesehen, aber nicht zeilenweise durchgelesen
und khz-khz übersehen.
Watch call = 144000-144500, Show = khz-khz und die Spots kommen wie gewünscht. Für KW benutze ich keine grauen Haken, habe aber alles so minimiert, dass nur die neuen Länder/Bandpunkte/IOTA angezeigt werden.
Super Sache, dickes Lob für Deine Ideen und die Umsetzung!
'73 Thomas... jetzt brauche ich nur noch eine Farbe die für mich 144MHz darstellt
Verfasst: Dienstag 26. August 2014, 17:45
von LB2EG
LB2EG hat geschrieben:DL7UCX hat geschrieben:Hello Richard,
Black not Grey
Help:
Thank you, Ben!
Richard
Ben,
I hope i have read the user documentation carefully this time:
Using the "RX" option i DX Cluster window, makes the spot view to follow band AND mode.
A feature request would be to have a black and grey marking also for the "RX" option, where one option is to follow band AND mode, and the other option is to follow band and ANY mode.
What say?
73 de LB2EG Richard
Verfasst: Dienstag 26. August 2014, 19:44
Hello Richard,
I'm not convinced that this is a really needed feature.
You can quickly switch the mode of TRX and see the related spots.
Verfasst: Dienstag 26. August 2014, 20:37
von LB2EG
Yes, I can. But it is convenient sometimes doing S&P DXing on one band, having a single view of CW/Pone/Digital cluster spots for that band without touching the radio ...
Anyway, I can live with your decision
Richard
Verfasst: Mittwoch 27. August 2014, 19:43
You can change the mode in Ucxlog by hotkey without touching the radio.
I like to get a quick view of band/mode spots with 1 click to RX and to go back with a second click.
With the grey check box I would need always one more click also if I do not like the view for all modes.
And an explanation is needed about the meaning of "grey".
Verfasst: Mittwoch 27. August 2014, 23:56
von LB2EG
DL7UCX hat geschrieben:You can change the mode in Ucxlog by hotkey without touching the radio.
Ben,
you may get around that by giving the user an option to check any other mode when the RX-option is actually activated.
This could be done with both grey and black, as it is done today when the RX option is not activated.
What say?
Richard
Verfasst: Donnerstag 28. August 2014, 20:27
Richard,
there are 2 possibilities to get a new feature in UcxLog:
- I like the feature
OR
- Several users ask for this feature and the feature will not disturb other users.
I think, more "gray" check buttons are not helpful, only confusing.
To vary the behavior of the "RX" check button needs additional settings, e.g. by a pop-up menu.
Verfasst: Dienstag 10. November 2015, 18:02
von LB2EG
DL7UCX hat geschrieben:Richard,
OR
Hello Ben,
A year ago I requested a feature allowing me to display all modes on a single band in DX Cluster Window, clicking the "RX" button. At that time you were not convinced, as stated in your last reply in the thread (above).
I kindly repeat my request for this feature, and suggest that it can be enabled using a pop up choice a la the "RBN BPSK" now used on the mode buttons.
What say?
73 de LB2EG Richard
Verfasst: Mittwoch 11. November 2015, 08:13
Hello Richard,
Please check Version 7.54 Beta 9, DX Cluster window:
New Pop-Up menu at "RX" check box: "Only RX Mode" / "All Modes"
(or use the small (?) beside modes).
At program start is always "Only RX mode" checked.
Verfasst: Mittwoch 11. November 2015, 13:32
von LB2EG
Thanks!
I will install the new beta in the evening.
Richard
