Error in Name field?
Verfasst: Donnerstag 6. August 2009, 08:52
von EB2RA
Hi
In Work window is not posible type a name with two word, like JOSE LUIS, when I type space, the cursor tab to next field. I can only type JOSE.
Thanks for this software.
(Version 6.43)
Re: Error in Name field?
Verfasst: Donnerstag 6. August 2009, 20:04
Yes, this is correct.
The idea was that we use normally no double names in ham radio and
that the space is then available as hotkey to return quickly to the call sign field.
It would not be a problem to change this behavior.
What is the opinion of other users about this?
Verfasst: Montag 10. August 2009, 18:28
Hi,
I think that the space running as a hotkey is a very fine solution. To put double names into the name field the easiest way is to use the stroke (-) instead the space!
Verfasst: Montag 10. August 2009, 21:15
von DC3RJ
<Shift> Space???
73 de Juergen
Verfasst: Montag 10. August 2009, 22:12
Shift+Space
- for blank or
- for selection of call sign field?
Verfasst: Dienstag 11. August 2009, 18:06
von EB2RA
Ok, thats is a idea... I report this "no error" but another simple solution is type JOSELUIS, and all ok.
Verfasst: Mittwoch 12. August 2009, 09:37
Hi,
I added in UcxLog 6.44 Beta 3 the possibility to enter blanks in the QSO-Work-Name field using the key '_'.
