Backup Failing...
Verfasst: Donnerstag 27. August 2009, 23:42
von MD0MDI
I have not used the software in a while but I have been updating it so I am not sure if this is a bug or something that has started to happen on a certain build.
I have A backup directory, normally under the program directory but when exiting it states the backup failed, I have now created a new directory off the root of C: and this is giving the same problem.
Checkout the screen captures...
Any help would be much appreciated, I am sure it is me....
Thanks
James
Re: Backup Failing...
Verfasst: Freitag 28. August 2009, 07:44
Hello James,
I assume that there are problems with your file (write) permissions.
If you are using Vista you should store private data only in your user directory or better on another partition (e.g. D:). On drive C: some file writings are done only "virtually" and lost after logout.
Verfasst: Sonntag 30. August 2009, 09:56
von MD0MDI
I have made sure that 'Everone' has Full control of the directory, and just in case I have also added My login and Administrators group as well, but still not having it...
Windows 7 x64
Verfasst: Sonntag 30. August 2009, 19:42
Please be so kind to try another directory in your user directory or on another drive.
May be it's also helpful to avoid blanks in the directory name.
And I still think that Vista blocks some file actions on drive C: also if you have full permissions!
Verfasst: Montag 31. August 2009, 13:53
von MD0MDI
Tried it to another 2 drives and still failing.
Verfasst: Montag 31. August 2009, 19:33
Sri, nobody ever reported this problem.
Please send me your file UCXLOG.ST2
Do you have write permissions for this file?
Please check file date/time. Was it written during each UcxLog close?
