Error Message: Ungultige Gleitkommaoperation.
Verfasst: Donnerstag 3. November 2011, 18:42
von MD0MDI
I am getting a dialogue box appera whenever I select the 'QRZ.COM' button in the work window.
It states:
"Ungultige Gleitkommaoperation."
If I then try to move the window that displays 'QRZ.COM' i get this message:
'Zugriffsverletzung bei Adresse 3D7B4E56 in Modul 'jscrip.dll'. Lesen von Adresse 0000F012.
The UcxLog shuts down!!
Sorry but I do not understand German, but if you could suggest anythign to fix this I would be greatful.
James (MD0MDI)
Re: Error Message: Ungultige Gleitkommaoperation.
Verfasst: Donnerstag 3. November 2011, 18:49
von DG9VH
Which Version of Internet-Explorer you have installed and which OS you are using?
Verfasst: Donnerstag 3. November 2011, 21:18
I think it's not an error in UcxLog but in your Internet Explorer and JavaScript.
"Ungueltige Gleitkommaoperation" means "Invalid floating point operation".
No idea to fix this.
Verfasst: Freitag 4. November 2011, 18:17
von DG9VH
Maybe installing actual Microsoft patches for OS and IE would fix the problem. Also upgrading IE could also do something good on it.
Verfasst: Samstag 5. November 2011, 00:29
von MD0MDI
Hi Guys, I personally do not use IE, but I take it from the comments that UcxLog defaults to IE?
The version that is installed is 8.0.6001.18702
I have checked 'Windows Update' and the system is updated as far as it can go (Windows XP SP3), plus ALL available updates...
I have installed the latest version of Java (Version 6 Update 29).
Any other ideas?????
James (MD0MDI)
Verfasst: Samstag 5. November 2011, 13:48
Hi James,
UcxLog "defaults" to windows API functions and components and windows opens an explorer, don't know which.
