WAB Squares
MD0MDI
WAB Squares
Beitrag von MD0MDI »
I know this is a long shot, but i am getting a few people both here and in Germany ask me about he logging of WAB Squares (Worked all Britian), i suppose that there is the same sort of thing for most/all countries out there, but just in case, can you think about this for a latter date as a possibility...
Thanks again...
James (MD0MDI)
Re: WAB Squares
Hi James,
use the QSO Work-Window, fields Award and Count.
The problem is, that someone has to put the necessary informations handy in these two fields. I think mostly if the QSLs coming in and will be registered in the log.
You can search via "Scan/Award" in the main window.
An other possibility is the field "District/State" in the QSO Work-Window.
You can search via "Scan/District" in the main window.
