Seite 1 von 2
RTTY
Verfasst: Mittwoch 12. März 2014, 21:09
von oz6bam
Hi ..
Now when I am in the process of testing period of the program.
So I try to run something RTTY on it too, but can not quite figure out the setup program.
I have a Yaesu FT-450D
Singnalink USB.
Can easily get the program and CAT to work.
But do not completely understand how the additional setup should be???
Must just be with it is still trying period I am working on, do not know if it would have any effect.
Is there someone who can explain to me why or where it goes wrong for me??
Vy 73
OZ6BAM/OZ5TO
Re: RTTY
Verfasst: Mittwoch 12. März 2014, 21:16
Hello,
you should explain, what works and where is the problem.
First step:
What happens if you choose mode "RTTY" in UcxLog ? Opens the MMTTY engine ?
Supplement:
There is no "setup" program for RTTY.
There are no restrictions in the UcxLog test phase.
Re: RTTY
Verfasst: Mittwoch 12. März 2014, 21:54
von oz6bam
Hello Ben.
No no it does not look like it will start up something like that.
When I go in and choose RTTYmode I get this picture. no 1
And here's happening no more?
If I go into the program settings, so I can not check MMTTY engine Pic no 2
Re: RTTY
Verfasst: Mittwoch 12. März 2014, 22:13
Did you follow the Help ?
Use "Search" and type "MMTTY", then select chapter "Program-Start":
If the MMTTY
engine should be used for RTTY, the file MMTTY.EXE must be existing in addition (see
http://hamsoft.ca/pages/mmtty.php). At least MMTTY engine V1.65 should be used.
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 09:09
oz6bam hat geschrieben:If I go into the program settings, so I can not check MMTTY engine Pic no 2
The background looks white (instead of gray), so it
should be clickable.
Otherwise, follow Ben's advice and copy the file into the program directory.
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 09:22
Hello,
Yes, the checkbox is clickable to get a helpful message if you click and the MMTTY engine is missing.
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 09:32
von DL1EZ
Hello Nameless
it is fairly easy to setup. Get the MMTTY
engine from
http://hamsoft.ca/pages/mmtty.php.
Just make sure to download the engine (the MMTTY program itself is not needed).
The download for the engine can be found almost in the middle of the page, just scroll down a bit
Once downloaded, unpack the exe file from the engine into the UCX program directory and make sure in the UCX settings MMTTY is checked.
Restart UCXLog and enjoy..
What TRX will you be using and do you want to use AFSK or FSK?
73 de Adi
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 19:53
von oz6bam
DL1EZ hat geschrieben:Hello Nameless
engine from
73 de Adi
You so funny.
But now I have got it to work Wiiiiiii! Come on, it took a long time with this old junk
For some reason (probably myself) then it would not start RTTY up. Suddenly it seemed the program.
Can not explain why or how, but now it works.
However, you should probably just get used to running with the keys F1 & F2-3-4-5 and forward it on.
But it will now probably go a little messed up in this weekend's contest and I accept it as it comes and learn from it.
But have not exactly figured out how to possibly directs some in makcro is already?
Keld Larsen
OZ6BAM/OZ5TO
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 20:25
Hello Keld,
Your Receive window is very small, you can use the mouse to drag this window bigger.
Sri, I have some problems to understand your English, do you still have any questions
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 20:32
von oz6bam
DL7UCX hat geschrieben:Hello Keld,
Hallo Ben.
Nicht jetzt, sind wahrscheinlich einige mehr morgen. Muss nur sein, ein wenig mehr auf der Suche auf RTTY Teil morgen, wenn ich wieder nach Hause kommen von der Arbeit
Re: RTTY
Verfasst: Donnerstag 13. März 2014, 23:11
von DL1EZ
Hello Keld,
I'm glad to see it works now for you..
If you are not into ragchewing on RTTY, the macros can be quite short and simple like:
Of course you can do them well-formed and "big" for ragchewing, if you want to
The keywords for macros are mentioned in the help / windows / send and there are quite a few for normal qsos as well as for contests.
Just be aware, "copy and paste" in the send window is
not via crtl-c / crtl-v but with crtl-insert / shift+insert.
Hope that helps, 73 de Holger "Adi"
Re: RTTY
Verfasst: Freitag 14. März 2014, 16:31
von oz6bam
Hmm?
Simply can not get it to decode any of the messages I hear on RTTY?
I'm running on 14085.49mhz SSB and as you can see I get through my sound card an excellent signal for the program?
But why I can not decode the signals, there does not seem menu using has given me the solution to this?
Are there any who are on a Skype session where in you can guide me through the last setup menu
Re: RTTY
Verfasst: Freitag 14. März 2014, 19:32
NO
Look to your "RTTY Control Panel" picture:
There is
nothing what looks like a RTTY signal.
You must see two peaks (Mark and Space frequency, see below), but this is basic know-how about RTTY/MMTTY, not UcxLog.
The UcxLog settings are ok, the "CW/SSB soundcard" is not relevant for RTTY (see MMTTY options), "AFSK" and "TX" are not relevant for "FSK".
Re: RTTY
Verfasst: Freitag 14. März 2014, 20:25
von DL1EZ
That is exactly, why I was asking wchich TRX and which mode (FSK/AFSK) is to be used..
Re: RTTY
Verfasst: Donnerstag 20. März 2014, 14:22
von oz6bam
Hey Ben ..
Do not think I quite understand what you meant?
Is not so important anymore, because I've got it working now.
And must admit after BARTG-HF RTTY contests , I am very positively about the program.
The top would be if it once came to support PSK modes in the same manner as RTTY is at the moment so that it can be used in the same manner Contest.
Playing now forward it to the program, and must admit that written further up a great program
