CAT Elecraft K3 - loosing connection
Verfasst: Samstag 3. August 2019, 08:59
Hi
When I am in a contest I sometime loose the CAT USB connection. That is especially if mismatch with antenna or to big near-field.
I have done a lot to prevent, but sometimes it do not work.
I can see that you have made a "fix" to reconnect in the normal work-window with the "TRX" on/off.
Can you make the same in the Contest window?
As now I have to goto Transmitter and do a Auto reconnection and that is taking time.
What you say?
What you say?
