Trranserter option
Verfasst: Dienstag 10. September 2019, 09:58
				Hello,
I worked in the IARU VHF contest this weekend with a TS590 and transverter connected to UCXLog.
As the contest setting was 2m only, and the CAT signal was on 28MHz the software reacted strangely by jumping to `144` on the first click to the contest window and after some time jumping back to the CAT frequency.
Is it in plan to create a Transverter option? The offset kHz option does support maximum 28 MHz.
I'm thinking about something in the VHF contest window and option to enable transverter mode, or maybe something in the CAT setup (but need to find an easy way to activate/deactivate it on the flight).
Thanks,
Dani
YO5LD
Thanks,
Dani
YO5LD
