Icom's OK, But Hassles with Yaesu and Kenwood
Verfasst: Sonntag 26. Juli 2009, 16:36
I have no issues at all plugging in an Icom and using the software with it, but everything else seems problematic.
I have just about got the Yaesu FT-897D and FT-2000D working with it, but for some reason it doesn't like it sometimes, not sure why, but a reboot of the PC seems to cure the problems.
As for Kenwood though, both TS-480SAT and TS-2000, forget it, does not matter what I try it just does not talk to the software.
I know that the leads are OK as if I shutdown UcxLog and Startup HRD that sees it perfectly and works no problem, but then if I try UcxLog again, nowt!
Any ideas... ??? I really like the software but it is causing me and others real hassles and we need to get this sorted before the next DXpedition, else we will have to use HRD instead.
