Dymo Labelwriter 450
Verfasst: Donnerstag 24. August 2017, 12:05
von PA3EYC
Every month I answer all my buro QSL requests. Therefore I use A4 sheets with 7x3 stickers.
Sometimes I become a request for a direct card and I want to answer that immediately.
Is it possible to print a single sticker with a Dymo Labelwriter 450?
Re: Dymo Labelwriter 450
Verfasst: Donnerstag 24. August 2017, 18:29
For all label prints UcxLog has in "QSL-Receive/Send" the 2 input fields "Start label number on first page - Horiz." + "... Vert.".
This should also work with your printer if the A4 sheets endure multiple prints.
Verfasst: Donnerstag 24. August 2017, 20:24
von PA3EYC
Ben,
you are right and I am doing that already for many years.
But sometimes I need just one label.
I use 7x3 label sheets and it is not possible to print 21 times one label.
My label sheets endure about 5 times thru the printer, maybe 6, but not 21 times.
Therefore my question.
Verfasst: Freitag 25. August 2017, 06:46
Hello Maarten,
I think you print 1 label and next time several labels, then 1 label ...
So your label sheets need only 2 or 3 passes through the printer.
And I don't see any possibility how UcxLog can help you.
If you want to collect the print of some single labels, you can do it by collecting the direct request.
Verfasst: Freitag 25. August 2017, 08:09
von PA3EYC
DL7UCX hat geschrieben:.......
Ben,
This is the answer to my question. I thought there may be a possibility to print single labels with a labelwriter.
If not, no problem. I do it with the A4 sheets.
Thanks for your reactions.
Verfasst: Freitag 25. August 2017, 10:41
Maarten,
I think I do not really understand your question:
Is this related to hardware or software ?
You can print a single lable or a single card with UcxLog.
Verfasst: Freitag 25. August 2017, 16:17
von PA3EYC
Ben,
this is related to hardware.
I know that I can print single or multiple labels. I do already that on A4 sheets with 3x7 labels.
But now I have a Dymo labelwriter 450. So, I thought it may be is possible to print the single labels with that label printer.
I have drivers of the printer but do not know if it is possible to drive it from UCXLog.
That was actually my question.
Verfasst: Freitag 25. August 2017, 19:09
Ok Maarten,
I do not know this Dymo labelwriter but I assume it prints 1 label as 1 page.
So you can try to set this printer in UcxLog for "single card" with right paper size (= lable size) and print 1 QSL on 1 page = 1 lable.
Verfasst: Samstag 9. September 2017, 18:57
von PA3EYC
Hello Ben,
After installing the correct drivers and redirect the text is is working 100%.
