QSL Layout
Verfasst: Samstag 31. Januar 2026, 13:51
von OZ2I
Im using Windows 11 pro together with a Canon TS9550 Inkjet printer.
It has worked very well for more years now.
But now All my Layouts for different callsigns are changed so that the papersize is A4 in stead of 14x9 cm.
I am using many different calls and so also many different Layouts. The layout are changed for all my calls and I cannot change the size.
Any hints ???
Is this corrupt?
D44EE.ST2
/ € ZJ–“Púï?å³ & - ÿÖDF , Ô. 6 /¥x ? D44EE HENNING PRAIA D4 Øë @
Cape Verde hë4 À¢À ™@HK84FW oz1bii ÿ×R_fÇ D44EE """"œæ@d44ee
4  ) , Ñ
sW z â   È X ´ ¾ È x TÈ È     È Xˆ  Ü È È ¥   ð Ü ð z  h³¤ô aâ}?V­»?ŒÌ? °¯¯? ðày ŒÌ? è ,* À ¡ ÿ Arial ã \ < › Arial ã é < € Arial ã ® < € Arial ã S < › Arial ã > < € Arial ã þ A @€€ Arial X è g Arial ß ‰ L Arial <  ` Arial Arial È X 0 Arial Ò X 0 Arial Ü X 0 Arial æ < 0 Arial ð X 0 Arial ú X 0 Arial 5 E 7 Arial 6This QSL card printed with UcxLog - April 2025 by OZ2IOZ2III “ ‹ > Arial To Radio: Ü X 0 Arial æ X 0 Arial ð X 0 Arial ú X 0 Arial X 0 Arial X 0 Arial X 0 Arial " X 0 Arial , X 0 Arial 6 X 0 Arial @ X 0 Arial J X 0 Arial T X 0 Arial ^ X 0 Arial h X 0 Arial r X 0 Arial | X 0 Arial † X 0 Arial  X 0 Arial š X 0 Arial ¤ X 0 Arial ® X 0 Arial ¸ X 0 Arial  X 0 Arial Ì X 0 Arial Ö X 0 Arial à X 0 Arial ê X 0 Arial ô X 0 Arial þ X 0 Arial X 0 Arial X 0 Arial X 0 Arial & X 0 Arial 0 X 0 Arial : X 0 Arial D X 0 Arial N X 0 Arial X X 0 Arial b X 0 Arial l X 0 Arial v X 0 Arial € X 0 Arial Š X 0 Arial ” X 0 Arial ž X 0 Arial ¨ X 0 Arial ² X 0 Arial 0’¨ L €?D44EEcannet €? €? €? €? €? €? €? €? €? <contest> PSE QSL TNX QSL D44EE hereby confirm report: Œ Z D44EE hereby confirm QSO: F¤ )° F¤ )° F¤ )° SINGLE-OP LOW DANISH DX GROUP Henning Andresen Slotsgade 17 6100 Haderslev Denmark mail@oz1bii.dk OZ1BII ÿÿ
Re: QSL Layout
Verfasst: Samstag 31. Januar 2026, 15:40
von DL1EZ
If I remember right (my paper QSL printing was done ages ago), the paper size setting
is done via the printer settings in Windows and UcxLog is using that setting..
You might want to try that..
Re: QSL Layout
Verfasst: Samstag 31. Januar 2026, 19:10
Hello,
you must go to UcxLog menu "Settings - Printer" and set there the paper size (and possibly some other printer settings).
And in the layout normally check "Use printer settings".
Re: QSL Layout
Verfasst: Sonntag 1. Februar 2026, 11:13
von OZ2I
Thanks for help.
I deleted the printer drivers and downloaded the latest. So now it works again.
Thanks for the great UcxLog program.
Best 73 de OZ2I Henning
