RTTY TS590S/TS590SG TRX Ctrl
Verfasst: Montag 24. April 2017, 09:58
von oz30eu
When I'm in the window, QSO Works, hits the TRX Ctrl off
I can choose PSK, or RTTY, (fldigi 3.23.19)
The radio is in SSB mode
The UCXlog is in PSK or RTTY mode
And it works fine
Problem:
The radio is still in SSB mode
When I'm in the window, QSO Works, hits the TRX Ctrl on
The fldigi closes, and the MODE: Switches automatically to SSB
Jeg bruger usb kabel fra PC til radio
UCX log 7.73
fldigi 3.23.19
Is there anyone who can tell me where there is a selection missing or is it too much?
Avoid using a little google translate.
VY oz30eu Svend Erik sek@oz30eu.dk
Re: RTTY TS590S/TS590SG TRX Ctrl
Verfasst: Montag 24. April 2017, 10:31
Hello Svend Erik,
Try this:
- Switch "TRX Ctrl." on
- Change mode only in UcxLog to RTTY or PSK
UcxLog should show the mode RTTY or PSK with yellow background (signaling different TRX mode).
TRX should show mode SSB or Packet.
Possibly try to change "Settings-Station-Other interfaces - RTTY/PSK/Digital - TX Mode - SSB/Data".
Verfasst: Montag 24. April 2017, 11:34
von oz30eu
Thanks for quick response Ben
Radio start in USB
UCXloc start in Mode SSB, TRX Ctrl on
Switches UCXlog to Rtty
Background does not change color
FLdegi starts
After approx. 3-5 seconds, Fldigi asks if it should close, and UCXlog MODE automatically switched to SSB
The same thing about the radio on usb + data
Fresh start
Radio start in USB
Push the radio switch FSK: ON
QSO work window, Mode Switches automatically to RTTY (White background) and fldigi start.
RTTY Seems to work, But in a narrower window / waterfall due to FSK bandwidth
If I change mode RTTY to psk (TRX Ctrl on)
Mode: Shows PSK for approx. 3 seconds
Mode: Switches to SSB
The radio automatically switches to USB
What forces FLDIGI to close in SSB mode ?
VY
oz30eu Svend Erik
Verfasst: Montag 24. April 2017, 12:21
von oz30eu
Hello again Ben
Now it works
In the window Other Interfafase / TX mode
Have I changed Data/Pkt Off, and SSB on
Sorry I've spent your time.
VY
oz30eu Svend Erik
Verfasst: Montag 24. April 2017, 18:49
Hello Svend Erik,
please pay attention to Help chapter "General - Digital modes - ... Fldigi:
Programm Fldigi must be installed with some settings:
- Configure - User interface - UI - General: Uncheck "Confirm exit"
