n new computer (WIN11) UcxLog sometimes stops working with error message
oh1nd
Beitrag von oh1nd »
In old computer, WIN10 operating system, I had never the attached error situation. In new PC, WIN11 home, this happens about every week. To recover from the error I have to close UcxLog and start again. Is there anything I can do to avoid this situation?
73 Juha OH1ND
Re: n new computer (WIN11) UcxLog sometimes stops working with error message
Hello Juha,
Such an error has not been reported so far.
I have no chance to find the cause with the error number.
is there a relation to any event?
Have you implemented all the virus scanner tips?
Try to update to version 8.44 Beta, there are more runtime checks implemented ...
DL1EZ
Beitrag von DL1EZ »
Hi Juha,
does this error (or similar) also pop up with other programs running than UcxLog?
It might be an idea to check the RAM for consistency with memtest86+ or something like that..
just my 2 cents, Holger
oh1nd
Beitrag von oh1nd »
Thank you for answers,
I have my PC on from morning to late evening and UcxLog too. Sometimes in 24/7 mode. This error message does not appear every day.
With Task Manager I can see that there is enough memory available.
I also use JTDX (improved version) for FT8 mode many hour's every day mostly just monitoring. I noticed that JTDX has a setting for threads in use. I suppose this means the CPU cores it uses for decoding. Maybe I am wrong with this. Anyway earlier the setting was AUTO. I did reduce it to 4 that gives fast enough decoding. Possibly AUTO setting did try to use all resources and then sometimes that was too much and caused problems with UcxLog.
After a week or so I know if the setting change in JTDX has any effect.
73 Juha
using UcxLog more than 10 years
DL1EZ
Beitrag von DL1EZ »
Hi Juha,
I do use a "small and fairly old" computer with 4 CPU cores for UcxLog and JTDX and never ran into this kind of problem.
Also I do not think that it is related to the amount of memory availabel or the number of concurrent threads for JTDX.
My assumption is more into a hardware error or malfunction related to RAM (bit switch or defect cell etc.), so I again
suggest to run a memtest86+ from a bootmedia (not within Windows).
Hello,
UcxLog requires much less memory than other programs.
It uses several tasks in parallel but this is managed entirely by Windows.
I fear that the stability of modern PC hardware (and Windows) has not improved ...
Normally there are on home PCs no memory checks/error corrections active.
Also the stability and quality of drivers is not getting any better.
oh1nd
Beitrag von oh1nd »
Thank you again for answers,
last two weeks have been without any errors.
Yes, memory is non-ecc type meaning no error correction.
I did run windows own memory test. That seems to exit windows and start the error test program from a simple text based program.
No errors were found. Later I may use the more advanced program if needed.
I believe that UcxLog has been ok all the time so this is my last message about this subject.
73 Juha OH1ND
