Hi Guys,
I am returning after a long battle with the dreaded 'Cancer and I just cannot remember what I once knew regarding UCXLOG.
I have Backed up UCXLOG Many Times, sometimes through the software and other times just copying the folders to a new location.
I have ended up with 'LOADS' of Backups and I am not sure which is which with regard to which is complete and which would be any old DXpeditions or Contests.
Is there a description anywhere as to what files are what, and which I need to keep and what I can delete ???
Any Help would be very much appreciated.
Returning After a Long Time Off Radio and Need a Bit of Help
Re: Returning After a Long Time Off Radio and Need a Bit of Help
Hello James,
All files and directories are described in the Help chapter "General - Internal File Structure".
You need always these old files:
All with extension .UCX = Log files
All with extension .ST2 = Setting files
If you have them multiple times, get the newest ones.
Copy these files into the "Log data directory" (location see menu "Help - Show file locations - ..."), then (re)start UcxLog.
