Export continent to ADIF
YO5LD
Beitrag von YO5LD »
Any chance to have continent added as an ADIF field to exports?
Thanks,
Dani
YO5LD
Re: Export continent to ADIF
Hello Dani,
I added the output of field "CONT" at "QSO/Contest-Export-ADIF" in Version 7.89 Beta 5.
Note that you can view/change the continent only in connection with the DXCC selection.
It is always the "WAC" continent, not the "IOTA" continent (i.e. never AN).
YO5LD
Beitrag von YO5LD »
Thank you Ben, fast as always. This works perfect now :)
Is there an easy way to also add the WPX prefix (PFX field) to the ADIF export? So it's easier to integrate with other softwares which use this data.
Thanks,
Dani
YO5LD
Hello Dani,
The WPX prefix ist not stored in the log data record, it can not be edited or viewed.
UcxLog determines the prefix using some known rules only if it is needed.
If other software needs the prefix it can do it by itself.
