Trranserter option
YO5LD
Trranserter option
Beitrag von YO5LD »
Hello,
I worked in the IARU VHF contest this weekend with a TS590 and transverter connected to UCXLog.
As the contest setting was 2m only, and the CAT signal was on 28MHz the software reacted strangely by jumping to `144` on the first click to the contest window and after some time jumping back to the CAT frequency.
Is it in plan to create a Transverter option? The offset kHz option does support maximum 28 MHz.
I'm thinking about something in the VHF contest window and option to enable transverter mode, or maybe something in the CAT setup (but need to find an easy way to activate/deactivate it on the flight).
Thanks,
Dani
YO5LD
Re: Trranserter option
Hello Dani,
There is a transverter option, see Help chapter "Settings - Station - Transceivers":
Band / Offset
List of maximal 6 bands with frequency offset for use of a band converter at the controlled TRX.
The band change must be made in UcxLog.
UcxLog frequency = TRX frequency + Offset (kHz)
Example for converter from 28 MHz to 144 MHz::
TRX "1" - Used on "1.8" - "144" MHz - CAT "..." - Band "144" - Offset/kHz "116000"
