History Version 7
History Version 7
Version 7.01
UcxLog is SHAREWARE from version 7 !
After test on 30 days the user will be asked for registration
(at the moment 20 EUR inclusive updates for 2 years).
All test versions (Beta versions) are FREEWARE.
Setup simplified.
Contest
- VFDB: S-DOKs updated
- RAC Winter: Points for RAC call signs updated
- Work: Direction added
- New: NRAU-Baltic
Modes
- New: DSTAR
QSL - Print
- New check box "Only if not yet LOTW confirmed"
Settings - Station - Special
- New check box "Key ESC clears work window if not sending"
Settings - Station - Transceivers
- CAT COM port settings: "Auto Detect"
View - Countries
- Additional sums: 5/6/9/10-Band-Mixed
Hotkeys
- Alt+W, Alt+F8: Only remove QSO data of work window
- Esc: (New) switchable: If not sending then remove QSO data of work window
Member lists
- BCC.TXT updated
- DIG.TXT: DL2OE deleted
TRX control
- New: Ten-Tec Eagle
- TS-590: PTT ON -> ACC2/ USB input (instead of MIC)
COUNTRY.TXT Version 7.01
- New special calls
E51BKV E5/S
TO4M FH
TO5G FY 20120102-20120107
TW0F FW
TX6T FO
Fixed errors
- Import - ADIF: Field SIG imported for DL into DOK
Setup simplified.
Contest
- New: NRAU-Baltic
Modes
- New: DSTAR
QSL - Print
View - Countries
Hotkeys
Member lists
- BCC.TXT updated
TRX control
- New special calls
E51BKV E5/S
TO4M FH
TW0F FW
TX6T FO
Fixed errors
Re: History Version 7
Version 7.02
Contest
- New: UBA Spring
- New: Bucuresti Contest
List DL.LST
- "Bayern Süd" changed to "Oberbayern"
COUNTRY.TXT Version 7.02
- New special calls
TO3J FJ
Fixed errors
- REF-Contest - Wrong rule for Cabrillo 2.0 fixed
- Registration text shortened
- Black Sea Contest: Range check error
Contest
- New: UBA Spring
List DL.LST
- New special calls
TO3J FJ
Fixed errors
Version 7.03
Settings
- New: "Log Cloud" - Backup or synchronize logs on UcxLog webserver
ADIF
- Field QSLSDATE imported/exported
Transceivers:
- K3 shifted from Kenwood/K2 to Flexradio
because of similar RTTY modes control (AFSK based)
- Checkbox "ICOM mode PSK" (no PSK via audio) added
in "Settings-Station-Other interfaces"
Lists:
- MASTER list: Updated (RELEASE 2012.02.05)
- FIRAC.TXT: Updated
COUNTRY.TXT Version 7.03
- New special calls
E51NJB E5/S
- ARRL definition for "European Russia" changed without modification note
http://www.arrl.org/news/new-russian-pr ... tem-in-use
U/UA...UI 8/9 F/S/T/W/X, R/RA...RZ 8/9 F/S/T/W/X -->
U/UA...UI 8/9 F/G/X, R/RA...RZ 8/9 F/G/X
Fixed errors
- DX spot window: Hotkey Alt+I
- Indication of own call sign in task bar
- DL-XMAS-Contestt: "NM" no multiplier
Settings
ADIF
Transceivers:
Lists:
- New special calls
E51NJB E5/S
Fixed errors
Version 7.04
eQSL
- QSL - eQSL - Export/Import ADIF file
- Edit Log - Full: Checkbox "E"
- Settings - Station - Colors/QSL: New table "Confirmed="
Contest
- Canadian Province Abbreviations NF->NL, NWT->NT, PEI->PE
- Also after Undo all list are updated
QSO/Contest-Work
- Ctrl + F...: Send all key words double
COUNTRY.TXT Version 7.04
- South Sudan: ST0 --> Z8
- Malyj Vysotskij I. R1MV --> #151 (deleted)
- New special calls
E51M E5/N
TO7BC FH
Fixed errors
- TRX Control K3 RTTY/FSK: K3 separated from Flexradio
- QSL-Repeat print: Overflow at 1000 QSOs fixed
eQSL
Contest
QSO/Contest-Work
- New special calls
E51M E5/N
TO7BC FH
Fixed errors
Version 7.05
Edit Log - Full
- Colors for QSL states
Contest
- ARI-DX: Rules for Italians added
QSO/Contest-Work
- Hotkeys for TRX frequency change in numeric block:
"/": Decrease
"x": Increase
CW/SSB: 0.1/1/10 kHz - FM: 5/12.5/25 kHz
with Ctrl: Value 2, with Shift: Value 3
Scan
- Move WFF from remarks to award field
Windows - Callbook
- Switches in Pop-Up menu for taking over of QTH, Locator, IOTA
Lists
- LOCATOR.TXT updated with
http://www2.darc.de/ukw-funksport/ukw/vhfdb/vhf-txt.zip
COUNTRY.TXT Version 7.05
- Coordinates of 3C0 corrected
Edit Log - Full
Contest
QSO/Contest-Work
"/": Decrease
"x": Increase
Scan
Windows - Callbook
Lists
Version 7.06
Contest
- New: LZ Open Contest
QSO - Import ADIF
- Frequency expanded to 25 GHz
Scan
- Check countries
Lists:
COUNTRY.TXT Version 7.06
- B <M/N/O/P/Q/U/V/W/X> 9 --> BV (Taiwan)
- ZW0S -> PY0S
- New special calls
4U1GSC I
3D2/W7DRA 3D2
3D2IR 3D2
9M0M 1S
CE9/R1ANF VP8/H
EM1KCC CE9
FK/JA1NLX FK
FK8GM FK
FK8HW FK
FO/DL3GA FO/A
FO8RZ FO
FR/F5TNI FR
FR/PA3GIO/P FR
FR5FD FR
FR5ZU/T FR/T
JA1KJW/JD1 JD1/O
JA2NQG/JD1 JD1/O
JD1BIA JD1/O
JD1BLK JD1/O
JD1YAB JD1/O
JE5DTS/JD1 JD1/O
JG4LSR/JD1 JD1/O
JH1EFP/JD1 JD1/M
JK1KNB/JD1 JD1/O
JL4CVB/JD1 JD1/O
JM3FVL/JD1 JD1/O
PY0ZFO PY0F
VP6AJ VP6
VP8CTM VP8/F
VP8DBR VP8/F
VP8DEI VP8/F
VP8DGA VP8/F
VP8DMN VP8/F
VP8GEO VP8/G
VP8THU VP8/S
2R0JBC/p G
4K0GNY -
4N4U YU 19910101-19911231
5N/LZ1QK -
9M4CJB 9M2
9U/F5FHI -
EG92* EA
EH92* EA
EZ9L UA9 19920101-19921231
FR/DJ7RJ FR
FO5JV FO
FR/F4EGZ FR
FR5GS FR
FR5FR FR
GB50ATG GW
GB5FI GW
GR3UOF GW
HK1T HK0M 20120101-20120109
HV0HH -
I2RAO/HK0 -
KL7DN/1 W
MR0MVP GI
OH0MB OJ0 19910101-19911231
OH2AP/OH0M OJ0
OX/NA1SA -
PG5M/BA4RF BY
PP0T PY0T
RU3HD/ANT CE9
T6LR -
TO11A/P FG
TO5SM/P FS
TO7C FY 20050307-20050317
U5ARTEK/A UR
U5EX UR
UA1ZFQ/4K3 UA3 19920101-19921231
UF6FAL 4L 19910101-19911231
VP2V/KF4EZ -
VP8DNT VP8/F
YT3B 4O 20060628-20070511
YT6T 4O 20060628-20070511
9M0L 1S
E51BKM E5/S
E51GMH E5/S
JD1BLC JD1/O
JI1LET/JD1 JD1/O
9M6/OH2YY 1S
9M6/LA7XK 1S
9M6/N1UR 1S
AC3A/CE0 CE0Y
DP1ANF CE9
GB0U GU
GB1OL GM
GB4HI GW
GB4SWF GM
GB5FI GW
GB5TI GM
GB2OWM GM
HC/FT5YK VP8/H
IA0PS CE9
II0MZ CE9
II0P IS
IR0LVC IS
IR0PS CE9
LU/R1ANF VP8/H
LU4ZS CE9
N8Z KP2 20021230-20030108
OJ1ABOA CE9
PS0F PY0F
R1ANF/P VP8/H
R50YG UN
R750FF UA2
R750M UA2
R750Y UA2
RA9LI/FJL R1FJ
S79RRC/F S7
U5FK UR
VK0DX CE9
VK0JLX CE9
ZY0K PY0F
Fixed errors
- Russian DX contest: Use WAE list, Oblast detection PM/KO
- MVP-Contest: Multiplier check refined
- Prefix length increased from 4 to 6
Contest
QSO - Import ADIF
Scan
- Check countries
Lists:
- ZW0S -> PY0S
- New special calls
4U1GSC I
3D2/W7DRA 3D2
3D2IR 3D2
9M0M 1S
CE9/R1ANF VP8/H
EM1KCC CE9
FK/JA1NLX FK
FK8GM FK
FK8HW FK
FO/DL3GA FO/A
FO8RZ FO
FR/F5TNI FR
FR/PA3GIO/P FR
FR5FD FR
FR5ZU/T FR/T
JA1KJW/JD1 JD1/O
JA2NQG/JD1 JD1/O
JD1BIA JD1/O
JD1BLK JD1/O
JD1YAB JD1/O
JE5DTS/JD1 JD1/O
JG4LSR/JD1 JD1/O
JH1EFP/JD1 JD1/M
JK1KNB/JD1 JD1/O
JL4CVB/JD1 JD1/O
JM3FVL/JD1 JD1/O
PY0ZFO PY0F
VP6AJ VP6
VP8CTM VP8/F
VP8DBR VP8/F
VP8DEI VP8/F
VP8DGA VP8/F
VP8DMN VP8/F
VP8GEO VP8/G
VP8THU VP8/S
2R0JBC/p G
4K0GNY -
5N/LZ1QK -
9M4CJB 9M2
9U/F5FHI -
EG92* EA
EH92* EA
FR/DJ7RJ FR
FO5JV FO
FR/F4EGZ FR
FR5GS FR
FR5FR FR
GB50ATG GW
GB5FI GW
GR3UOF GW
HV0HH -
I2RAO/HK0 -
KL7DN/1 W
MR0MVP GI
OH2AP/OH0M OJ0
OX/NA1SA -
PG5M/BA4RF BY
PP0T PY0T
RU3HD/ANT CE9
T6LR -
TO11A/P FG
TO5SM/P FS
U5ARTEK/A UR
U5EX UR
VP2V/KF4EZ -
VP8DNT VP8/F
9M0L 1S
E51BKM E5/S
E51GMH E5/S
JD1BLC JD1/O
JI1LET/JD1 JD1/O
9M6/OH2YY 1S
9M6/LA7XK 1S
9M6/N1UR 1S
AC3A/CE0 CE0Y
DP1ANF CE9
GB0U GU
GB1OL GM
GB4HI GW
GB4SWF GM
GB5FI GW
GB5TI GM
GB2OWM GM
HC/FT5YK VP8/H
IA0PS CE9
II0MZ CE9
II0P IS
IR0LVC IS
IR0PS CE9
LU/R1ANF VP8/H
LU4ZS CE9
OJ1ABOA CE9
PS0F PY0F
R1ANF/P VP8/H
R50YG UN
R750FF UA2
R750M UA2
R750Y UA2
RA9LI/FJL R1FJ
S79RRC/F S7
U5FK UR
VK0DX CE9
VK0JLX CE9
ZY0K PY0F
Fixed errors
Version 7.07
- New check box MMTTY "On top" (replaces start parameter -MMTTY_NO_TOP)
Scan - Award
- New button "List Award Names"
View
- New: Recorded Audio
Contest
- R-Contest (Nordrhein) updated
- Baden-Wuerttemberg VHF: STF
Oblast determination
..1E -> LO
..1K -> KL
..1X -> PS
..1Y -> MU
COUNTRY.TXT Version 7.07
- Mexico prefixes updated:
XA-XI 4A-4C 6D 6F 6H 6J
- FR -> Reunion (without ask for FR/G,J,T)
- FK -> New Caledonia (without ask for FK/C))
- R-150-S entries corrected:
RI0Q UA9#7
RI0L UA9#J
- Changed special calls
R1ANF* VP8/H
UN* UA3 -19930501
UN1* UA3 -19991231
- New special calls
3D2UU 3D2/R 19920120-19920215
NP3D W
NP3D/NY2 W
R35NP - 20070101-20081231
R85NN UA3
R900DM UA3
TO5K FM
4U1WED OE
FR/DJ8CR/G -
FR/F6KDF/T FR/T
UF6FAL 4L 19910101-19921231
3D2EE 3D2
9M4SAB 9M6
9U5CW - 19970101-19971231
FK/I2GPT FK
FK8IK FK/C 20100809-20100819
FK8VHY/P FK/C
FK8VHY/P FK 20000428-20000430
FK8VHY/P FK 20010525-20010526
FO5RH FO
FO8WBB FO
FT?Y* CE9
EA/FT5YK VP8/H 20110318-20110319
9M1CSP 9M2
9M4DXX 9M2
9M50MP 9M2
EX9X UA9 19920101-19921231
EZ9MA UA9 19920101-19921231
SY2A SV/A
VP8DIZ VP8/F
YT3B 4O 20101027-20101031
4N2* 9A 19910626-19921231
4N3* S5 19910626-19921231
4N4* E7 19911015-19921231
4N5* Z3 19910908-19921231
4N6* 4O 20060628-20061231
YT2* 9A 19910626-19921231
YT3* S5 19910626-19921231
YT4* E7 19911015-19921231
YT5* Z3 19910908-19921231
YT6* 4O 20060628-20061231
YU2* 9A 19910626-19921231
YU3* S5 19910626-19921231
YU4* E7 19911015-19921231
YU5* Z3 19910908-19921231
YU6* 4O 20060628-20061231
YZ2* 9A 19910626-19921231
YZ3* S5 19910626-19921231
YZ4* E7 19911015-19921231
YZ5* Z3 19910908-19921231
YZ6* 4O 20060628-20061231
9M2/R6AF/6 9M6
Scan - Award
View
Contest
..1E -> LO
..1K -> KL
..1X -> PS
..1Y -> MU
RI0Q UA9#7
RI0L UA9#J
R1ANF* VP8/H
UN* UA3 -19930501
UN1* UA3 -19991231
- New special calls
NP3D W
NP3D/NY2 W
R85NN UA3
R900DM UA3
TO5K FM
4U1WED OE
FR/DJ8CR/G -
FR/F6KDF/T FR/T
3D2EE 3D2
9M4SAB 9M6
FK/I2GPT FK
FK8VHY/P FK/C
FO5RH FO
FO8WBB FO
FT?Y* CE9
9M1CSP 9M2
9M4DXX 9M2
9M50MP 9M2
SY2A SV/A
VP8DIZ VP8/F
9M2/R6AF/6 9M6
Version 7.08
QSL
- New: eQSL - Download QSLs
- New: eQSL - Export + Upload ADIF file
Contest
- New: Juri Gagarin International DX
- IOTA: Changed rules updated
- Hamburg: Rules updated
- YU DX: Rules updated
QSO - Group Modify
- Reset of "LOTW/eQSL confirmed" possible
COUNTRY.TXT Version 7.08
- VP6 -> Pitcairn (without ask for VP6/D)
- KH8 -> American Samoa (without ask for KH8/S)
- Only special determination: 4U_IT, 4U_UN, FT.W, FT.X, FT.Z, VP6/D, KH8/S
- Prefix U5: UA3 -> UR
- 2Q --> G
- PP0F PQ0F PR0F PS0F PT0F PU0F PV0F PW0F
PX0F PY0F PZ0F ZV0F ZW0F ZX0F ZY0F ZZ0F --> PY0F
- PP0S PQ0S PR0S PS0S PT0S PU0S PV0S PW0S
PX0S PY0S PZ0S ZV0S ZW0S ZX0S ZY0S ZZ0S --> PY0S
- PP0T PQ0T PR0T PS0T PT0T PU0T PV0T PW0T
PX0T PY0T PZ0T ZV0T ZW0T ZX0T ZY0T ZZ0T --> PY0T
- ZT0-ZT6 ZU0-ZU6 --> ZS
- New special calls
TO3X FJ
3D2DX 3D2 20110318-20110327
E51EWP E5/S 20120324-20120427
9M0L 1S 20120410-20120424
VU9LHA VU 20110812-20110822
9M2/PG5M 1S 20070419-20070423
VK9PN VK9N
ZQ3M ZB2
RI1ANF VP8/H
VK9LNO VK9L 20060504-20060513
BT1B BV
DL2JRM/BY8SKM BY
FO/DL7CN FO/A 20010401-20010430
FO/DL7FT FO/A 20010401-20010430
HK3JJH/0M HK0M
K8T KH8 20021026-20021110
KV4FZ KP2
NL7AU/4 W
UA9XKB/FJL R1FJ
VK9YL VK9L
VP8CXV VP8/F
GB100MUC GM
CQ8X - 20120324-20120325
ZQ2ER ZB2
3D2WW 3D2 20071000-20071031
PT0T PY0T
VP6DI VP6/D 20020316-20020326
VP6DIA VP6/D 20030308-20030315
VP6DX VP6/D 20080210-20080227
VP8/LZ1UQ VP8/H
FR5ZL/G FR/G
FR7ZL/T FR/T
FR7ZQ/G FR/G
FR7ZU/J FR/J
9M6TPR 1S
EM1HO CE9 19980101-20051231
EM1KA CE9 19980101-20051231
EM1LV CE9 19980101-20051231
EM1U CE9 19980101-20051231
PY0ZF* PY0F
PY0ZS* PY0S
PY0ZT* PY0T
R2/OZ5IPA UA2
RA1O/FJL R1FJ
RX1OX/FJL R1FJ
SV0LK SV9
UA3DSP/FJL R1FJ
XR0ZY CE0X 20000401-20000430
ZQ2 ZB2 20120101-20120610
Fixed errors
- Wrong German caption and buttons (instead of English) in Message Dialogs
QSL
Contest
QSO - Group Modify
- 2Q --> G
- New special calls
TO3X FJ
VK9PN VK9N
ZQ3M ZB2
RI1ANF VP8/H
BT1B BV
DL2JRM/BY8SKM BY
HK3JJH/0M HK0M
KV4FZ KP2
NL7AU/4 W
UA9XKB/FJL R1FJ
VK9YL VK9L
VP8CXV VP8/F
GB100MUC GM
ZQ2ER ZB2
PT0T PY0T
VP8/LZ1UQ VP8/H
FR5ZL/G FR/G
FR7ZL/T FR/T
FR7ZQ/G FR/G
FR7ZU/J FR/J
9M6TPR 1S
PY0ZF* PY0F
PY0ZS* PY0S
PY0ZT* PY0T
R2/OZ5IPA UA2
RA1O/FJL R1FJ
RX1OX/FJL R1FJ
SV0LK SV9
UA3DSP/FJL R1FJ
Fixed errors
Version 7.09
QSO - Edit
- Zero in call signs with slash
Send DX Message
- Button "Copy message to clipboard"
QSO - Work
- Band change to 30m: SSB changed to CW if not in band plan
QSL - Send - ADIF File
- DXCC-ID added
Contest
- New: Kazakhstan DX Contest (UN DX)
- New: Worked All Provinces of China
- New: Kulikovo Polye Contest
- New: Portugal Day Contest
Update
- Information for Beta testers if newer beta version is available
Lists
- IOTA.CSV updated
COUNTRY.TXT Version 7.09
- ZQ -> Gibraltar
- 3D2 -> Fiji (without ask for 3D2/C+R)
- VP8 -> Falkland Is. (without ask for VP8/G+H+O+S)
- New/changed special calls
VK9PN VK9L 20120523-20120530
KH2D/NG4 W
TX5VT FO/M
EM1HO CE9 19970305-20060212
EM1HU CE9 19970201-19970228
EM1KA CE9 19970102-20010403
EM1KCC CE9 20010201-20020131
EM1KGG CE9 19991005-20021210
EM1KY CE9 20000401-20010430
EM1LV CE9 19980201-20011031
EM1U CE9 19990327-20040831
EM1UA CE9 20030826-20040106
JD1BMG/JD1 JD1/O
Fixed errors
- Direction in VHF-Contest-Work window not updated after selection
of other locator
QSO - Edit
Send DX Message
QSO - Work
- DXCC-ID added
Contest
Update
Lists
- IOTA.CSV updated
- ZQ -> Gibraltar
KH2D/NG4 W
TX5VT FO/M
JD1BMG/JD1 JD1/O
Fixed errors
of other locator
Version 7.10
Contest - QTC receive
- Automatic completion of leading time digits
Fixed errors
- QSO - Edit Log - Short:
No country determination for some call signs with "0"
- QSO - Import - ADIF
Bands 60M, 4M, 1.25M imported as frequency + band='???'
Fixed errors
Version 7.11
Contest
- New: Venezuelan Independence Contest
- New: RAC Canada Day Contest
- New: RSGB Low Power Contest
- New: DIG QSO-Party, Fruehjahr-, Kurz-Contest
- O-QRP: January, July, December separated
eQSL Upload
- Upload of Remarks possible
QSL - Received
- Warning if call/QSO is marked NEVER/NOT to be printed
Telnet 2
- Pop-Up menu to add actual TRX offset to DX message frequency
(useful for skimmer after converter)
Lists:
Fixed errors
- DMC RTTY Contest: Cabrillo CATEGORY-TIME added
- IOTA Contest: Detection of AN... fixed
COUNTRY.TXT Version 7.11
- Prefix 2O -> England
- Prefix S6 -> Singapore
E51TAI E5/S
E51YNB E5/S
KL1A W 20040101-
TO5U FM
2Q0ARE GU 20020601-20020631
KC4/N2TA CE9
AX9YL VK9N 20001001-20001031
VK9YL VK9C 19780601-19780630
VK9YL VK9L 20020901-20020930
VK9YS VK9C 19780601-19780630
2O12W GW
9M0C 1S 19980210-19980228
9M4SLL 1S 20120807-20120813
EM1KA CE9 19960101-20010403
EM1U CE9 19960101-20040831
FR???/E FR/J
FR???/G FR/G
FR???/J FR/J
FR???/T FR/T
LU1ZC VP8/H 19971221-19980228
OH0MAS OJ0 19730101-19731231
OH0MB OJ0 19960801-19960831
OK1IAI/YA YA
TO2D FJ
TO2U FP
TO5M F 19951028-19951029
TO5M FR 20041023-20041130
TO5MM F 19931030-19931031
TO7C F 19911026-19911027
TX0HF FO/A
UW2F UA2 -20010430
VK9RS VK 19990921-19990926
ZK1VVV E5/S 20021101-20021111
ZV0MB PY0T 19961008-19961010
ZV0MV PY0T 19961008-19961010
ZX0DX VP8/H 19980101-19980228
4K1HX 4J 19941221-19950630
9M4SEB 9M6 20060714-20060717
9M50MB 9M2
EZ9AX UA3 19900512-19920510
GB2IOM GD 20021005-20021012
OH3MIG/4U YK 19930319-19930427
PA3CXC/ST0 #244 19800417-19941231
PA3CXC/ST0 ST 19950101-19970204
R100N UA9
R100RW UA9
R70B UA9 20081201-20081231
SM1TDE/4U OD 19931101-19940430
VY0A CY9 19751104-19751107
4U0G HB 19991218-20000313
4U48UN 4U_UN
4U49UN 4U_UN
4U50UN 4U_UN
9M0F 1S
9M4SLL 1S
9U5CW -
AX0LD VK0/M 20000125-20000126
FO/F6CTL FO/A 20040525-20040527
FO/IT9YRE FO 20040920-20040924
FO/OH1RX FO/M 20080109-20080123
FO0CLA FO/M 19990525-19990627
FO0CLA FO/M 20000221-20000320
FO0CLA FO 20000404-20010403
FO0CLA FO/A 20010407-20010422
FO0CLA FO 20010507-20011009
FO0IGS FO
FO5IW FO
FO5NL FO
FO5PI FO
JD1BKR JD1/O
JD1/JA9XBW JD1/O
LU1ZC VP8/H 19971219-19980305
R850D UA3
R860T UA3
RA/UW7LL UA3
R/N7PLU UA3
TO7C F 19910330-19911127
TO8T F 19960727-19960729
TX1XX F 19910814-19910820
VE3UWC/4U YK 19941005-19950211
VK0LD VK0/M 19980101-20000130
VK0TS VK0/M 19990331-19991102
VP8PJ CE9 20031214-20040113
VS96BG VR
ZK1SHJ E5/S
ZMY2K ZL
2A* GM 19980719-19990731
2C* GW 19990506-19990630
2S* GM 19990506-19990630
2T* GM 19990506-19990630
2X* GW 19990506-19990630
2Y* GW 19990506-19990630
6O/G3KOX T5 19921216-19930309
CE0DFL CE0Y 19810406-19920119
JD1BJN JD1/O
VI0ANT CE9 19941001-19950330
R10RLHA/0 UA9
R10RLHA/2 UA2
R35CZF UA9
ZK1SCQ E5/S 19980810-19980814
ZK1SCQ E5/N 19980816-19980822
ZK1SCQ E5/S 19980825-19980826
ZK1SCQ E5/S 19990805-19990818
ZK1SCQ E5/N 19990821-19990826
ZK1SCQ E5/S 19990828-19990901
ZK1SCQ E5/S 20010731-20010801
ZK1SCQ E5/S 20020805-20020822
ZK1SCR E5/S 19980812-19980814
ZK1SCR E5/S 19990805-19990818
ZK1SCR E5/N 19990821-19990826
ZK1SCR E5/S 19990828-19990828
R875R UA3
Contest
eQSL Upload
QSL - Received
Telnet 2
Lists:
Fixed errors
E51TAI E5/S
E51YNB E5/S
KL1A W 20040101-
TO5U FM
KC4/N2TA CE9
2O12W GW
FR???/E FR/J
FR???/G FR/G
FR???/J FR/J
FR???/T FR/T
OK1IAI/YA YA
TO2D FJ
TO2U FP
TX0HF FO/A
UW2F UA2 -20010430
9M50MB 9M2
R100N UA9
R100RW UA9
4U48UN 4U_UN
4U49UN 4U_UN
4U50UN 4U_UN
9M0F 1S
9M4SLL 1S
9U5CW -
FO0IGS FO
FO5IW FO
FO5NL FO
FO5PI FO
JD1BKR JD1/O
JD1/JA9XBW JD1/O
R850D UA3
R860T UA3
RA/UW7LL UA3
R/N7PLU UA3
VS96BG VR
ZK1SHJ E5/S
ZMY2K ZL
JD1BJN JD1/O
R10RLHA/0 UA9
R10RLHA/2 UA2
R35CZF UA9
R875R UA3
Version 7.12
Contest
- New: RSGB 80m Club Sprint
- New: Russian RADIO RTTY WW Contest
- New: DARC Aktivitaets-Kurzcontest des Distrikts Ruhrgebiet
- New: AGCW Handtastenparty
Settings - QSL Layout
- Remark: New keyword <contest> for contest name
- Text 1..50: Keyword <name> added
Settings - Printer
- Adjusted printer properties survive
QSL - Print - Export ADIF
- Confirmation to include Remarks parts "..."
COUNTRY.TXT Version 7.12
- New Prefix E6 for Niue
E51AIU E5/S
SM4GDB/4U SU
GB2YLS GM
E51MGA E5/S
UA1OT R1FJ 19840101-19901231
VP8CTR CE9 19970207-19980327
3Y0C 3Y/B
4U9U 9U
JA0EOK/JD1 JD1/O
JA1RJU/JD1 JD1/O
JA1XEQ/JD1 JD1/O
JA1ZEK/JD1 JD1/O
JA9XBW/JD1 JD1/O
JD1/7J1AYK JD1/O
JD1ACH JD1/O
JD1BFA JD1/O
JD1BIZ JD1/M
JD1BKZ JD1/O
JD1BIE JD1/O 20080915-20090531
JD1BIE JD1/M 20090610-20090618
JD1BIE JD1/O 20090710-20101116
JD1BJP JD1/O
JD1BKQ JD1/O
JD1BLX JD1/O
JD1BMC JD1/O
JD1BNA JD1/O
JD1BNF JD1/O
JD1BNK JD1/O
JD1BNN JD1/O
JD1BNQ JD1/O
JD1YAF JD1/O
JD1YAH JD1/O
JD1YBO JD1/O
JD1YBS JD1/O
JD1YBT JD1/O
JF3CTR/JD1 JD1/M
JG1GGU/JD1 JD1/O
JJ1JGI/JD1 JD1/O
JL1KFR/JD1 JD1/M 19980528-19991104
JM1KNI/JD1 JD1/O
JN1HOW/JD1 JD1/O
JP1JWF/JD1 JD1/O
JQ1QET/JD1 JD1/O
JQ1SYQ/JD1 JD1/O
JR6TYH/JD1 JD1/M 20040923-20041212
JR6TYH/JD1 JD1/O 20050405-20060325
JR8XXQ/JD1 JD1/M
FO/F8DQL FO
FO/JJ8DEN FO
FO0AAA FO/C
FO0AOI FO/M 19991105-19991114
FO0AOI FO 19991115-19991201
FO0DEH FO/A 19990921-19991028
FO0DEH FO 19991108-20011213
FO0DEL FO
FO0EEN FO/A
FO0FI FO/A
FO0FR FO/M
FO0FR FO 20001025-20001031
FO0FRY FO/A
FO0HWU FO/A
FO0MCA FO
FO0MOT FO
FO0MOT/p FO/A
FO0MSN FO
FO0SEV FO/A
FO0SIL FO/M
FO0WEG FO/A
FO0WII FO/A
FO0XE FO/C
FO0YAM FO
FO0XUU/M FO/M 19990116-19990129
FO0XUU/A FO/A 19990202-19990210
FO5QB FO
FO5QD FO
FO5QO FO
9M0A 1S
9M0SEA 9M2
9M4SJJ 9M6
9M4STE 9M2
VP8CGK VP8/G
VP8CQR VP8/H
VP8CQS VP8/H
VP8DLM VP8/H 20090224-20090225
VP8DLM CE9 20090302-20090306
VP8NP CE9
VP8PL VP8/O
VP8SO VP8/O
VP8SU VP8/G
XR9JA VP8/H
FO5OP FO
FO5RA FO
FO5OU FO
E51AND E5/S 20100720-20120805
E51AND E5/N 20120827-20120915
R21GGGR UA2
NH8S KH8/S 20120905-20120919
Fixed errors
- Work-QSO-Round: Sporadic data loss fixed.
- QSL-Print/Received: MHz displayed if band=???
Contest
Settings - Printer
E51AIU E5/S
SM4GDB/4U SU
GB2YLS GM
E51MGA E5/S
3Y0C 3Y/B
4U9U 9U
JA0EOK/JD1 JD1/O
JA1RJU/JD1 JD1/O
JA1XEQ/JD1 JD1/O
JA1ZEK/JD1 JD1/O
JA9XBW/JD1 JD1/O
JD1/7J1AYK JD1/O
JD1ACH JD1/O
JD1BFA JD1/O
JD1BIZ JD1/M
JD1BKZ JD1/O
JD1BJP JD1/O
JD1BKQ JD1/O
JD1BLX JD1/O
JD1BMC JD1/O
JD1BNA JD1/O
JD1BNF JD1/O
JD1BNK JD1/O
JD1BNN JD1/O
JD1BNQ JD1/O
JD1YAF JD1/O
JD1YAH JD1/O
JD1YBO JD1/O
JD1YBS JD1/O
JD1YBT JD1/O
JF3CTR/JD1 JD1/M
JG1GGU/JD1 JD1/O
JJ1JGI/JD1 JD1/O
JM1KNI/JD1 JD1/O
JN1HOW/JD1 JD1/O
JP1JWF/JD1 JD1/O
JQ1QET/JD1 JD1/O
JQ1SYQ/JD1 JD1/O
JR8XXQ/JD1 JD1/M
FO/F8DQL FO
FO/JJ8DEN FO
FO0AAA FO/C
FO0DEL FO
FO0EEN FO/A
FO0FI FO/A
FO0FR FO/M
FO0FRY FO/A
FO0HWU FO/A
FO0MCA FO
FO0MOT FO
FO0MOT/p FO/A
FO0MSN FO
FO0SEV FO/A
FO0SIL FO/M
FO0WEG FO/A
FO0WII FO/A
FO0XE FO/C
FO0YAM FO
FO5QB FO
FO5QD FO
FO5QO FO
9M0A 1S
9M0SEA 9M2
9M4SJJ 9M6
9M4STE 9M2
VP8CGK VP8/G
VP8CQR VP8/H
VP8CQS VP8/H
VP8NP CE9
VP8PL VP8/O
VP8SO VP8/O
VP8SU VP8/G
XR9JA VP8/H
FO5OP FO
FO5RA FO
FO5OU FO
R21GGGR UA2
Fixed errors
Version 7.13
Update - Fall back
- Fall back from beta version to last released version possible
QSL - Send - Export ADIF
- ADIF field NOTES used (instead of COMMENT) for Remarks parts "..."
QSL - eQSL - Export
- ADIF field QSLMSG used (instead of COMMENT) for Remarks parts "..."
Windows - Send - Tune
- Function added for RTTY and PSK
Contest
- Rheinland-Pfalz: 40m added
COUNTRY.TXT Version 7.13
FO8EX FO
NH8S KH8/S
SM4GDB/4U SU -19961231
GB0BRE GW
GO2MP GM
VP8DLM CE9 20090227-20090306
Fixed errors
- Ruhrgebiet-Contest: Same multiplier counts again per QSO
Update - Fall back
QSL - eQSL - Export
Contest
FO8EX FO
NH8S KH8/S
GB0BRE GW
GO2MP GM
Fixed errors
Version 7.14
Help:
- New page "Menu Overview"
Contest
- New: BARTG Sprint 75
- New: Makrothen
RTTY Receive
- Check box "Auto detect" stored in settings
Member lists
- LOTW.TXT updated
- AGCW.TXT updated
- DIG.TXT updated
- HSC.TXT updated
- RTC.TXT updated
Fixed errors
- BARTG Sprint: No RST
COUNTRY.TXT Version 7.14
- European Russia: CQ zone 17 added
FO/F6BCW FO
TO2M FH
GB2OL GM
GB4BPL GW
GB4MDI GW
RC80MO UA3
RP67KM UA9
RP67RK UA9
RP67TG UA9
YT3B 4O 20061027-20061031
TX5EG FO
TX5FS FK
RA/KE5JA UA9
R750FW UA2
YT6A 4O -20070531
Help:
Contest
- New: Makrothen
RTTY Receive
Member lists
- LOTW.TXT updated
- AGCW.TXT updated
- DIG.TXT updated
- HSC.TXT updated
- RTC.TXT updated
Fixed errors
FO/F6BCW FO
TO2M FH
GB2OL GM
GB4BPL GW
GB4MDI GW
RC80MO UA3
RP67KM UA9
RP67RK UA9
RP67TG UA9
TX5EG FO
TX5FS FK
RA/KE5JA UA9
R750FW UA2
YT6A 4O -20070531
Version 7.15
TRX control
- K2/K3/KX3: CW keying via CAT
Worked List
- Pop up menu - New Entry: "Make window smaller"
(helpful, if bottom edge is not reachable)
Settings - Station - Other Interfaces - Rotor
- New control "Via Yaesu TRX CAT"
Contest
- New: Memorial OK1WC (MWC)
- Updated: VFDB
- Updated: RSGB 160m
- ARRL-DX: Canadian province VO1: NL -> NF
Contest - Work:
- New check box "Log only multis"
Settings - QSL layout
- PSE/TNX QSL: Vertical offset
View - QSO Statistics
- New field: LOTW received ... %
Member lists
- EPC.TXT updated
- BCC.TXT updated
- RRDXA.TXT updated
- LOTW.TXT updated
Fixed errors
- NAC: CQSOP corrected
- Edit Full: Deletion of correct WAE country determination not possible
- Contest - Network - Shared number:
Not allocated by F-text with Snr, special handling for ESM added
COUNTRY.TXT Version 7.15
- WAE entries
Z6 YU8 20080217-
YU8/ YU8 20080217-
GM4SID/P GM/s 19970724-19970727
- New R150S entries
..8W UA9#9
GB2JTA GU
TO2A FY
TX4FO FO
9M4CBP 9M6
E51ABS E5/S
E51BYD E5/S
E51C E5/S
E51CHX E5/S
E51KBR E5/S
TO9R FM
GO3UOF GW 20120720-20120909
RI1ANF/P VP8/H
VP8SGK VP8/G
2R0CTT G
3Y5X 3Y/B
4O1A YU -20070331
4O2A YU -20070527
FO4BM FO
II0AMZS CE9
JF7MTO/JD1 JD1/M
PJ0J #255 -20101009
PJ1B #85 -20101009
R100W UA9 20091101-20091130
R60F UA2
VE2PAB/4U YK
ZS9Z/ZS1 #493
LU???/XP LU
LU????/XP LU
E51BZD E5/S
RI1ANU VP8/H
TRX control
Worked List
Contest
- Updated: VFDB
Contest - Work:
Member lists
- EPC.TXT updated
- BCC.TXT updated
- RRDXA.TXT updated
- LOTW.TXT updated
Fixed errors
- WAE entries
Z6 YU8 20080217-
YU8/ YU8 20080217-
- New R150S entries
..8W UA9#9
GB2JTA GU
TO2A FY
TX4FO FO
9M4CBP 9M6
E51ABS E5/S
E51BYD E5/S
E51C E5/S
E51CHX E5/S
E51KBR E5/S
TO9R FM
RI1ANF/P VP8/H
VP8SGK VP8/G
2R0CTT G
3Y5X 3Y/B
4O1A YU -20070331
4O2A YU -20070527
FO4BM FO
II0AMZS CE9
JF7MTO/JD1 JD1/M
PJ0J #255 -20101009
PJ1B #85 -20101009
R60F UA2
VE2PAB/4U YK
ZS9Z/ZS1 #493
LU???/XP LU
LU????/XP LU
E51BZD E5/S
RI1ANU VP8/H
