I have noticed that when you sync the databases between systems using the Network option, it does not copy over the 'QSL Received' Data, Can you let me know which file holds this information so that I can manually copy this information to the other systems.
James
What file holds the QSL Received Data?
Re: What file holds the QSL Received Data?
Hello James,
If you want to syncronize the UcxLog data between different PCs, you have to use "QSO - Synchronize Ucx Logs".
This synchronizes all data incl. QSL information.
UcxLog "Network" synchronizes only the log of the present year or of the running contest.
"QSL received" is stored together with all other data of the QSO in one record of a log file (*.UCX).
Never access or edit these files !
Thanks as always...
James
James
MD0MDI hat geschrieben:Thanks as always...
James
Hi James , I tried to look at http://www.md0mdi.com/, but the result:
Forbidden
You don't have permission to access / on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2 Server at www.md0mdi.com Port 80
Sorry that you have a secret homepage
Sorry Klaus,
Been very busy for a while, site now back up, was working on it....
James (MD0MDI)
James (MD0MDI)
OK, James, a very nice site.
Hope you will be back on the waves in the near future
