History Version 7
Re: History Version 7
Version 7.32
Contest
- OK1WC Memorial (MWC) corrected
- CQ WWDX: "Category Overlay" enabled
- Ruhrgebiet: Updated 2014 (28 MHz -> 7 MHz)
- R (Nordrhein): Updated (Date)
- Rheinland-Pfalz: Updated (Special DOK CPU)
- New: WW PMC (Peace Messenger Cities)
- New: YO International PSK31 Contest
QSO - Work
- Pop-up menu Name/QTH: New switch "Allow small letters"
Windows - Map
- Popup menu extended
- Land color adjustable
Windows - Received Digital
- Autodetect of last logged call on same band suppressed
- New check box "Exchange only figures"
QTC Receive (WAEDC)
- QTC lines can be splitted by ENTER
- 2 more reserve lines visible
Member lists updated
- EPC.TXT
- LOTW.TXT
- HSC.TXT
- AGCW.TXT
- FIRAC.TXT
Fixed errors
- Telnet password change failed
COUNTRY.TXT Version 7.32
- New/changed special calls
3D2DD/P 3D2/R 20130927-20131011
3D2GC/P 3D2/R 20130927-20131011
3D2RA 3D2/R 20130927-20131011
OW75FOC OY
A35JP/? A3
E51YIV E5/S
GP0PKT GU
GB1BOL GM
GB1ROC GI
GB6SPD GW
TO2TT FH
TO4FM FM
TX5D FO/A
VK9DAC VK9X 20130601-20130607
VK9DAC VK9L 20131014-20131020
E51AAR E5/S
TO1A FM 20030301-20060310
TO1A FY 20130302-20131027
JD1BOI JD1/O
JD1BON JD1/O
K9W KH9 20131102-20131116
TX5RV FO/A
TX5W FK
GB1SOI GD
N8A KH8 20131123-20131124
W8A KH8 20131112-20131122
TO0MT FG
VK0GB CE9
Version 7.33
Fixed errors
- Digital: Own exchange auto detected
COUNTRY.TXT Version 7.33
R2013T UA9
Version 7.34
QSL - LOTW
- New menu item: "Repeat Upload"
Windows - DX Cluster
- Watch list: New "Show" choice "NOT from"
Contest
- New: Russian 160 meter
- New: Ten-Meter RTTY
- New: UK DX BPSK63
- Updated: WW PMC (List of PMC references added)
- Updated: VFDB Contest
- Updated: FIRAC HF
Scan
- New: Add State to USA-CA Award field
District lists
- New: UR.LST
- EPC.TXT
- LOTW.TXT
- BCC.txt
Fixed errors
- CQ-WWDX: QSOs between defferent NA countries count 2 points
- NAVAL Contest: Multiplier calculation corrected for short member numbers
COUNTRY.TXT Version 7.34
N8A KH8 20131112-20131127
W8A KH8 20131112-20131127
4U0WFP I
9M4JIJ 9M2
IA0MZ CE9
VK0DB CE9
R110RAEM UA9
R95NRL UA3
RA110RAEM UA9
RB110RAEM UA9
RC110RAEM UA9
RD110RAEM UA9
RG110RAEM UA9
RN110RAEM UA9
RQ110RAEM UA9
RR110RAEM UA9
RW110RAEM UA9
E51CDW E5/S
R7378TM UA9
Version 7.35
Windows:
- New: "Talk Help" (pronunciation of some phrases in partner language)
Contest
- New: OK-OM DX SSB
- Updated: Schwaben-Contest
Window - Send
- Contest: Standard text set band-independent, starts with 1.
Scan - WPX
- Period/years selectable
QSO/Contest - Work
- Hotkey ']' --> Log + F3
File MANAGER.TXT
- Removed from UcxLog package because empty
- EPC.TXT
- HSC.TXT
- AGCW.TXT
- DIG.TXT
- MDXC.TXT
- LOTW.TXT
Fixed errors
- QSO - Convert to Contest: Begin/end time calculation corrected
- FIRAC HF Contest: Multi count corrected
COUNTRY.TXT Version 7.35
CE9/UA4WHX CE
RU110RAEM UA9
RI20ANT VP8/H
RI44ANT VP8/H
R7378TM UA9
RAEM UA9 20131229-
RA22MX UA9
RA22QF UA9
RT22CT UA9
RT22MC UA9
RT22MD UA9
RT22SA UA9
RT22UA UA9
RT22WF UA9
RT22ZS UA9
RU22AZ UA9
RU22CR UA9
RU22LR UA9
RU22WZ UA9
RV22PM UA9
RV22WB UA9
RW22GO UA9
RW22MW UA9
RW22QA UA9
RW22QC UA9
RW22WR UA9
RX22WN UA9
RY22MC UA9
RY22RZ UA9
RZ22WW UA9
UE22A UA3
RA22AA UA3
RA22AO UA3
RA22AR UA3
RA22AX UA3
RA22CW UA3
RA22DM UA3
RA22KO UA3
RA22KW UA3
RA22LA UA3
RA22MA UA3
RA22VG UA3
RA22XA UA3
RA22XF UA3
RA22FF UA3
KH2TJ W
XR9H2O VP8/H
RN22DY UA3
TO3JA FM
Version 7.36
Windows - DX cluster
- Watch list extended
- Sound added
- Sound channel IDs separated for: CW/SSB input, CW/SSB output, PSK
Hotkeys
- ALT (alone) activates menu (with setting "Blind")
Contest
- New: AGCW YL-CW-Party
- New: DARC YL-Aktivitäts-Party
- New: YLRL YL-OM
Manager list
- File MANAGER.TXT reintroduced for OQRS
Master list
- MASTER_CT.TXT updated
- FIRAC.TXT
- EPC.TXT
COUNTRY.TXT Version 7.36
R22BIA UA9
R22SKJ UA9
R22ULM UA9
RA22AL UA3
RA22OH UA3
RA22YA UA3
RD22FU UA2
RJ22DX UA2
RT22TK UA9
RV22PM UA3
RW22WG UA9
9M4CMN 9M2
R22SKE UA9
R80SVC UA3
VK9IR VK9L
VL8A VK
R2014Y UA9
RA22RK UA3
RA22XU UA3
RA22YQ UA3
TO4YL FM
GB4UAS GI
TO8UFT FG
TO6D FG
2A* GM 20140125-20141130
GA* GM 20140125-20141130
MA* GM 20140125-20141130
Version 7.37
TRX CAT control
- K3/KX3: Frequency range extended up to 99 GHz
- K3/KX3: USB: DATA-REV changed to DATA
Settings - Station - Transceivers
- Band/Offset: Extended with selected "Additional bands"
Settings - Import Settings for
- New: Watch List only
Help
- New: Transport complete Log to new PC
- New: Take over complete Log from old PC
Contest
- New: AGCW Schlackertastenabend
- New: TESLA Memorial HF CW
- New: ADRAD Kayldall DMR
- Updated: RSGB First 1.8MHz
- Updated: RSGB 2nd 1.8MHz
- ARRL: State search in optional W/VE member lists
Contest - Score Log ...
- EDI: "Callsign of responsible operator" added
- EDI: Station data stored for each band
- Watch extended: "New member" + "kHz-kHz"
GHz bands corrected:
- 122 GHz (122.25-123)
- 134 GHz (134-141)
QSL - Received
- Pop-up menu for sort order
New member list
- DOK.TXT
- FOC.TXT
- LOTW.TXT
- EPC.TXT
Master list
- MASTER_CT.TXT updated (RELEASE 2014.02.04.00)
Additional (optional) member list download possible
- US states: http://www.dl6er.de/W-List/W.TXT.zip
- VE provinces: http://www.dl6er.de/VE-List/VE.TXT.zip
COUNTRY.TXT Version 7.37
4U10NPT OE
AH6FX/4 W
R0000O UA3
RAEM UA3
RP67SW UA9
RU22TU UA9
Z6* YU -20120923
TO7CC FR
D8A CE9
GB100LB GW
GB2CRU GI
CE0/W6NV CE0Y
TX6G FO/A
Version 7.38
Fldigi Connection
- First test, read Help chapter "General - Digital Modes (RTTY, PSK ...)
QSO/Contest - Work/Edit - Mode
- New: Contestia, DominoEX, Olivia, THOR, Throb
CW
- Key words Ar/Sk/As/Eb for prosigns
Contest
- New: DARC Ostercontest (Easter egg)
- New: NAURYZ DX
- Updated: EA RTTY
- Updated: Marconi Memorial HF
Window "Last logged ..."
- New in Pop-up menu: "Show full entity name"
Talk Help
- TALK.TXT updated
- FIRAC.TXT
- LOTW.TXT
- DOK.TXT
- EPC.TXT
- HSC.TXT
- AGCW.TXT
- FOC.TXT
- DIG.TXT
Fixed errors
- STF file: "Category" empty
COUNTRY.TXT Version 7.38
GB1SPD GI
R155AP UA9
R155RP UA9
RC80KEDR UA3
RI59ANT VP8/H
RO80KEDR UA3
RT80KEDR UA3
RV80KEDR UA3
UE80V UA3
VP8DOI CE9
RP68BP UA9
RP68DT UA9
RP68GM UA9
RP68GR UA9
RP68GS UA9
RP68H UA9
RP68J UA9
RP68KE UA9
RP68KM UA9
RP68LK UA9
RP68LS UA9
RP68MC UA9
RP68MD UA9
RP68MP UA9
RP68NK UA9
RP68PK UA9
RP68R UA9
RP68RG UA9
RP68SD UA9
RP68TK UA9
RP68TT UA9
RP68TZ UA9
RP68UF UA9
RP68V UA9
RS80KEDR UA3
TO4C FM
TO5NED FH
UE91L UA3
C7A OE
4Y1A OE
GA3KHH GM
GB8MD GW
JD1AAI JD1/O
Version 7.39
Settings - Station - Other interfaces - Fldigi
- New check box "CW" activates Fldigi at CW (only for receive)
Mode lists
- JT9 added
Contest
- New: DARC Rheinland-Pfalz Akt. Woche
- Update: DARC Rheinland-Pfalz Akt. Abend (own DOK 0 points)
QSO/Contest - Work
- DX Spot: New check box "Spot each logging automatically"
QSL - Send - Pop-up menu
- New items: "Mark if >1 cards/call", "Mark if >2 cards/call"
QSL - Received
- New field "Cash"
Master list
- MASTER_CT.TXT updated (RELEASE 2014.02.04.00 + 2014.05.04.00)
- LOTW.TXT
- EPC.TXT
Fixed errors
- Marconi Memorial HF Contest: Extra multiplier IG9 (= WWDX rule)
COUNTRY.TXT Version 7.39
FO/EI6DX FO
RP69CM UA9
RP69DK UA9
RP69GI UA9
RP69GP UA9
RP69GR UA9
RP69GS UA9
RP69KE UA9
RP69KM UA9
RP69LK UA9
RP69LL UA9
RP69LS UA9
RP69MC UA9
RP69MD UA9
RP69MM UA9
RP69NB UA9
RP69P UA9
RP69PW UA9
RP69R UA9
RP69SD UA9
RP69SF UA9
RP69UF UA9
RP69V UA9
RP69YN UA9
TO6A FO 19930327-19930328
TO6A FG 20140505-20140520
UE80YG UA3
CE9OJZ VP8/H
E51AVE E5/S
E51JQY E5/S
E51KJW E5/S
E51MCA E5/S
E51NHX E5/S
VK9DAC VK9N 20140520-20140527
TX5C FK 20141105-20141109
TX5E FK 20141114-20141117
TX5B FK 20141121-20141124
GB2RSM GW
GB2SFM GW
GB4SMM GM
Version 7.40
Scan
- New: WAS
Start parameter
- New: -LPTnnnnn : Set LPT1 address to nnnnn (nnnnnn = decimal value)
- LOTW.TXT
Fixed errors
- Startup: Unfounded message "Open sound card ... for output failed."
COUNTRY.TXT Version 7.40
TX7G FO/M 20141018-20141026
R44EPC UA9
R95PW UA3
UE14TS UA9
Version 7.41
Contest
- New: GREENPARTY
- Updated: Saar Contest: 80+40m separated
- Updated: DARC Ausbildungscontest
Contest - Rename
- New: Change name of logged contest
Fldigi Control
- Sending in mode HELL enabled
(Key ESC in UcxLog Work window needed to finish sending)
View/Scan-...
- Columns of band table increased (160-6m visible without scrolling)
QSL - Received
- New button "Set all "Sent""
Contest - Network
- Fixed part additional to "Incremental shared number" possible
Network
- Click to take over of frequency to work windows
Oblast determination
- New: 6T, 7T = Stavropol
- New: 6K, 7K = Cremea
- New: 6R, 7R = Sevastopol
- EPC.TXT
- FOC.TXT
- DIG.TXT
- HSC.TXT
- RTC.TXT
- AGCW.TXT
- LOTW.TXT
- RRDXA.TXT
- FIRAC.TXT
District lists updated
- Deleted in UR.LST:
KR Respublika Krym
SL Sevastopol
- Added to UA3.LST
RK Cremea
SE Sevastopol
Fixed errors
- Fldigi modes PSK63 + PSK125 wrong logged as PSK31
- FT-950 CAT control for new digital modes
- Network-Shared number: Wrong value at release on same band
- QSL-LOTW-Import: Check of own (operator) call added
COUNTRY.TXT Version 7.41
9M4DX 9M2
E51QBV E5/S
TO5LBJ FG
VK9EC VK9C
VK9EX VK9X
R90NOR UA3
TO5LBJ deleted
TO5MJ FG
GB4JPJ GM
4U4F I
GB1TAY GM
GB4CGS GM
EF6 EA
4U20B I 20140701-20150731
Version 7.42
Contest
- New: QCWA-QSO-Party
Windows - Send
- Pop-up menu extended with clipboard copy functions
- EPC.TXT
- LOTW.TXT
Fixed errors
- First cloud access failed
- QTCs in Undo mode
- K2: "advanced" removed (sideband change shifts frequency)
- Double ADIF import possible
COUNTRY.TXT Version 7.42
R14CWC/8 UA9
R14CWC/2 UA2
RZ37ZF UA9
R150LB UA9
VK9AN VK9X 20140918-20141002
9M4LHX 9M2
UE70Y UA9
R14CWC/9 UA9
R14CWC/0 UA9
GB0RSL GI
GB1RM GI
GB2GNL GM
GB2VJ GM
GB4EUL GW
Version 7.43
Contest
- New: North American QSO Party
- New: Greek Telegraphy Club (GTC) CW Cup
- Updated: HA-DX (HA-DXC member number is also multiplier)
- New rules: Rheinland-Pfalz Aktivitätswoche 2015
- New rules: OK1WC Memorial HF (52 rounds)
- Updated: AGCW-VHF/UHF: Receive of '/' unnecessary,
Received serial always filled with leading zeros
- New: Russian WW Digital
Contest - Work
- New hot key Shift+Space exchanges "call sign" and "next call sign"
Contest - Statistics - Export
- File content extended
Contest - WAEDC - QTC receive
- Empty QTCs can be logged,
will be counted in score log after error message as "C"
Windows - DX Cluster - Watch settings
- New check box "Disable watch line"
Scan
- File export: Added "CSV list of unconfirmed QSOs"
Settings - Station - Special
- New: "Additional constant ADIF output field"
- New "Blind" symbols: M = new Multiplier, E = Error
- LOTW.TXT
- EPC.TXT
- AGCW.TXT
- FOC.TXT
- DIG.TXT
- HSC.TXT
Fixed errors
- Contest - Rename: Wrong year corrected
- SAC: Missing country check for Scandinavian station
COUNTRY.TXT Version 7.43
- New prefixes
AM06 AN06 AO06 EA6
AM08 AN08 AO08 EA8
AM09 AN09 AO09 EA9
GB0NRL GM
TX4A FK
TX5Z FO/A
UE85AGN UA3
9M57* 9M2
9M57MS 9M6
9M57MW 9M6
FO/DF1YP FO
UE60TDP UA9
E51HDJ E5/S
2SZ G
Version 7.44
Contest
- New: FISTS Sprint
- Updated: Holyland
- Updated: Bayern Ost (Single band classes)
- WAG: Recommended log format Cabrillo 3.0
QSL - LOTW - Download
- URL was changed from https://p1k.arrl.org to https://lotw.arrl.org
Fldigi
- Control improved
- New check box "Modem only" in "Settings - Station - Other interfaces"
Elecraft K3/KX3 - Submode set via CAT
- RTTY/FSK -> "FSK D"
- RTTY/AFSK -> "AFSK A"
- PSK -> "PSK D"
- other digital modes: "DATA A"
- LOTW.TXT
Fixed errors
- Fldigi: Sending sometimes incomplete
- Ausbildungscontest: Contest name corrected in STF log
COUNTRY.TXT Version 7.44
GB2LO GM
GB2WAA GW
VK0MH VK0/M
VK9DJ VK9L
AO08ID/Z EA
JD1BOJ JD1/O
JD1BOK JD1/O
JD1BOM JD1/O
JD1BOW JD1/O
TX7G FO/M
TO1A FY 20130302-
4U2U OE
TO0X FH
Version 7.45
Settings - Cloud
- New: Check box for web upload "Upload/publish own TRX frequency"
Contest
- New: Russian WW MultiMode
- Updated: NRAU Activity: Microwave file names extended (7Y -> 72..75)
Fldigi
- RPC error handling extended
- New: "General offset / Hz" to correct TRX deviation
Start parameter
- New: '-NOLPT' suppresses loading of DLPORTIO.DLL
Network
- Avoid blocking by network problems
- DOK.TXT
- LOTW.TXT
- EPC.TXT
COUNTRY.TXT Version 7.45
GB1BGS GW
TO10RR FG
TO4R FG
TX5W FO/A 20150105-20150111
K1N KP1 20150101-20150131
FO/JI1WTF FO/M
FO/W6TLD FO/M
FO8AA FO
FO8AA/P FO
FO/JI1JKW FO 20070930-20141107
FO/JI1JKW FO/M 20141121-20141121
FO8BM/P FO
FO8BM/P FO/M 20141121-20141121
E51RAT E5/S
FO4BM/P FO 20141116-
TX8C FK
Version 7.46
README.TXT updated, see "Licensing"
QSO/Contest - Edit Log - Full
- New button: "Add managers" (see help)
View - IOTA - Summary
- Pop up menu to list "Worked / Confirmed / .. not Confirmed"
Contest:
- WW PMC: Cities updated
- New: WORLD WIDE IRON HAM
- New: ONY (Old New Year)
- New: TRIATHLON-DX
- VFDB Contest: S-DOK updated
- New: VFDB-Aktivitaestage
DL6ER-Keyer
- Winkey + 10 output lines (Band/TRX) supported
Settings - Station - Interfaces - WinKey
- Check box "+buffer": Buffer one more character
Talk Help
- TALK.TXT updated
Dlportio
- EXE removed from Ucxlog package because of wrong alarm of virus scanner
Manager lists
- Format of dailydx.com/qslmanager.txt accepted
- MF.TXT
- LOTW.TXT
- EPC.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- RTC.TXT
Fixed errors
- Fldigi: PSK submode in contests always PSK31
- Network: Handle broken network during "Start Network"
- Network: Suppress opening of QSO work window by operator change
COUNTRY.TXT Version 7.46
- WAE entries
JW2US JW/b 20120601-20121130
JW2US JW/b 20131201-20140531
IA/IZ2QEJ CE9
JD1BOX JD1/O
KC4/* CE9
KC4AAB CE9
KC4AAC CE9
KC4AAD CE9
KC4AAF CE9
KC4AAG CE9
KC4USB CE9
KC4USM CE9
KC4USV CE9
KC4USX CE9
UE16SR UA9
9D2UU -
JX4A -
KH6JEB/KH7 KH7K
E50A E5/S 20150101-20151231
E50B E5/S 20150101-20151231
E50D E5/S 20150101-20151231
E50J E5/S 20150101-20151231
E50K E5/S 20150101-20151231
E50V E5/S 20150101-20151231
E50W E5/N 20150101-20151231
HL8* CE9 deleted
8J1R* CE9
IR0PS CE9 20040126-20040223
IA0* CE9
VK9/G7VJR VK9N
FO/KK6BT FO
FO/OE1SSS FO
Gesperrt
