Seite 2 von 4
Re: History Version 8
Verfasst: Montag 10. Januar 2022, 09:24
Version 8.18
Contest
- Update: ARRL EME
- Update: VFDB-DLPX
- Update: VFDB-Kontest
ADIF-Export: 560M split to 560M and 630M
- New: "Send UDP Radio Info"
Windows - DX Cluster - Watch
- New selection "NOT remarks"
New member list
- UBA75.TXT
Member lists updated
- DIG.TXT
- AGCW.TXT
- FISTS.TXT
- RDA.TXT
Country list
- New/changed special calls
TO60CNES FY
TX5AQ FO/A
TX60CNES FK
GB0DBS GM
K2SHO KH6 20210921-
KB1HGW KH6 20211001-
KC7ELH KH6 20211001-
KI7ZTQ KH6 20180723-
KJ6SGY KH6 20210925-
KP3U W
LW7HRM/H LU
W1GDM KH6 20211002-
TX5N FO/A 20220416-20220428
GB8HRM GI
GB8PJE GI
RA/SM6LRR UA3
RL22NY UA9
RM22NY UA9
RQ22NY UA9
RX22NY UA9
RY22NY UA9
R22HNY UA3
R2022NY UA3
RA22NY UA3
RG22NY UA3
RJ22NY UA3
RK22NY UA3
RO22NY UA3
RT22NY UA3
RW22NY UA3
- Virustotal818.png (21.2 KiB) 17424 mal betrachtet
Verfasst: Mittwoch 16. März 2022, 08:16
Version 8.19
Contest
- Update: VFDB-DLPX, new Classes CW + FONE
- Correction: BARTG RTTY Sprint: Cabrillo Mode
- Update: Schwaben Contest (Club stations)
- Update: DARC Baden-Würtbg.
- Update: DARC Rheinland-Pfalz Akt.Abend (Special DOKs)
- Update: EA PSK63
- Update: DARC Nord-Contest (Special DOKs)
- New: Send UDP "Spot Data"
- New: Send UDP "Log QSO"
View - IOTA
- "LOTW" added
Scan - WAS
- Check of state abbreviations
Windows - Send
- CW speed (via COM port line) corrected
- FOC.TXT
- RDA.TXT
- FIRAC.TXT
- DIG.TXT
- HSC.TXT
Country list
IO0WRTC IS
JE1XUZ/JD1 JD1/O 20220212-20220215
FO/SP5EAQ FO/A 20220302-20220330
TX5N FO/A
UE99AE UA3
UE99ME UA3
JE1XUZ/JD1 JD1/O
TO1Q FG
GB4NPT GW
BY1CRA/WO22 BY 20220208-20220314
- Virustotal819.png (22.47 KiB) 17066 mal betrachtet
Verfasst: Mittwoch 6. April 2022, 14:51
Version 8.20
Contest
- New: PACCdigi
- Updated: Franken Contest (new exchange)
- FOC.TXT
- RDA.TXT
- LOTW.TXT
Country list
R50JNV UA9
TO8N FM
Fixed errors
- Contest-Work: Sometimes wrong value for "QSOs/h"
- REG1TEST (EDI) logs: Outdated keyword "[END..." removed
- Virustotal820.png (15.98 KiB) 16907 mal betrachtet
Verfasst: Dienstag 31. Mai 2022, 10:42
Version 8.21
Contest
- New: ARRL International Digital
- New: MST
- New: DARC Ruhrgebiet Aktivitätstage
- Updated: AGCW QRP/QRP Party (Bands)
Contest - Work
- Immediate logging of FT4/8 QSOs via UDP (see below)
QSO - Work
- Check box "Use TRX" moved into main window
- "Clublog" changed to "Log Upload", Upload to QRZ.COM added
- New: WSJT-X/JTDX - UDP Port:
Receiving of logged QSOs through UDP message "Logged ADIF"
(also into active digital contest work window)
Receiving of messages "Status" and "Decode" for DX cluster display
- RDA.TXT
- LOTW.TXT
Master list
- MASTER_CT.TXT updated (Release 2022.05.02.00 by Stu Phillips, K6TU)
Locator list
- LCTR_MMM.TXT updated May 31, 2022
Country list
NP3K W
GB70I GI
GB70J GJ
GB70U GU
R5AQ UA9
RP77AAP UA9
RP77AB UA9
RP77AZ UA9
RP77BD UA9
RP77DG UA9
RP77DT UA9
RP77GB UA9
RP77GI UA9
RP77GS UA9
RP77H UA9
RP77J UA9
RP77KAS UA9
RP77KM UA9
RP77KR UA9
RP77LL UA9
RP77MP UA9
RP77MVI UA9
RP77NIK UA9
RP77P UA9
RP77PC UA9
RP77RGA UA9
RP77SD UA9
RP77SSD UA9
RP77TG UA9
RP77TS UA9
RP77TT UA9
RP77TZ UA9
RP77U UA9
RP77UF UA9
RP77UK UA9
RP77UR UA9
RP77V UA9
RP77WAO UA9
RP77WU UA9
RP77ZAM UA9
E51CJC E5/S
TO2AS FG
JD1AJD JD1/O 20220624-20220702
TO2AZ FG
3D2RRR 3D2/R
- Virustotal821.png (16.07 KiB) 16524 mal betrachtet
Verfasst: Dienstag 30. August 2022, 09:35
Version 8.22
Contest
- New: NTC QSO Party
- New: K1USN SST Slow Speed
- Updated: DARC Ausbildungscontest
Clublog - Upload
- Satellite ADIF data added
QSO - Export - ADIF - 3.0
- Field MY_GRIDSQUARE added
QSO - Edit Full
- Show further QSOs: Window behavior improved
Scan - Distances
- Mode selection: All and Digital added
Cabrillo
- Modes FM and DIGI added to drop-down list
- DOK.TXT
- FOC.TXT
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- EHSC.TXT
- SHSC.TXT
- VHSC.TXT
- ILLW.TXT
List of satellite names updated
Country list
- Prefix KX6 added to entity W
GB70M GM
GB70W GW
GB70D GD
R19JHM UA9
R19JIG UA9
R19JSV UA9
R19UGRA UA9
R350S UA9
MQ0HVU GM
VK0WN CE9
K7K KL 20220725-20220731
VK0MQ VK0/M
DX0NE 1S
G8T GW
GB2HMM GW
TX5XG FO/A
RA20LH UA2
RL20LH UA9
RW20LH UA9
K9FD KH6 20100715-20220222
FO/DJ6GI FO
GB5TP GM
FO5QS FO/M 20220722-
GB22GI GI
GB22GJ GJ
GB22GM GM
GB22GU GU
GB22GW GW
RD20LH UA9
- Virustotal822.png (15.88 KiB) 15737 mal betrachtet
Verfasst: Mittwoch 28. September 2022, 17:08
Version 8.23
Contest
- New: DARC FT4
- Updated: VFDB...: Special DOKs
- FOC.TXT
- HSC.TXT
- RDA.TXT
Fixed errors
- Helvetia-VHF/UHF/Microwaves contest:
Slash added in exchange from HB
Country list
VK2GPL/9 VK9L 20220827-
9M65MA 9M2
9M65MB 9M2
9M65MC 9M2
9M65MD 9M2
9M65MJ 9M2
9M65MK 9M2
9M65MM 9M2
9M65MN 9M2
9M65MP 9M2
9M65MR 9M2
9M65MT 9M2
9M65MW 9M2
R875VU UA3
R870G UA3
FO/K6VVK FO
UE85L UA3
UE85RO UA3
9M4BCN 9M2
- Virustotal823.png (16.33 KiB) 15403 mal betrachtet
Verfasst: Mittwoch 7. Dezember 2022, 17:01
Version 8.24
Contest
- Updated: NRAU Activity Contest (NAC) 10m: REG1TEST log
- Updated: DARC Rheinland-Pfalz Akt.Woche 2023
- Updated: EU DX
- Updated: QRP HOT-Party
- Updated: SSA Christmas (JULTESTEN)
- Updated: DARC Brandenburg-Berlin (Special DOK)
Settings - Station - Transceivers
- New: CAT control using FLRIG
Settings - Station - Special - CW timing
- New: "Delay Key off -> PTT off"
Network
- New: Communication using UDP/IP (alternative to mailslots)
Send
- Warning "TRX not used" at begin of sending if CAT is disabled
ADIF file export
- Output always "time_off" (also if equal to "time_on")
- HSC.TXT
- FOC.TXT
- EHSC.TXT
- SHSC.TXT
- VHSC.TXT
- UFT.TXT
- AGCW.TXT
- DIG.TXT
- FIRAC.TXT
- RDA.TXT
- HSC.TXT
- DOK.TXT
- MF.TXT
Fixed errors
- Send UDP message "Log QSO":
Missing slash added in "<run1run2>1</run1run2>"
Country list
TO2DL FG
AH2AV W 20171129-
JD1BQP JD1/O
TO5M FS 20220922-
K8H KH8 20221118-20221201
KL0NP W
TO5Z FM
WA0OII KH2 20220226-
9M100SK 9M2
VP8/SQ1SGB/p CE9
- Virustotal824.png (15.9 KiB) 14850 mal betrachtet
Verfasst: Dienstag 3. Januar 2023, 19:29
Version 8.25
Contest
Settings - Station - General
- New modes:
VARAHF = VARA HF
VARSAT = VARA SATELLITE
VARFM1 = VARA FM 1200
VARFM9 = VARA FM 9600
- WSJT-X/JTDX ADIF log: Up to 6 logs for background import possible
(also from VarAC)
Settings - QSL Layout
- Freq.format "Band (MHz)": Missing bands added
- DX messages on own callsign can be suppressed via watch list
- DOK.TXT
- LOTW.TXT
- RDA.TXT
- HSC.TXT
- FOC.TXT
- EHSC.TXT
- FISTS.TXT
- SHSC.TXT
- VHSC.TXT
- FIRAC.TXT
Fixed errors
- Clublog upload failed since begin of year 2023
Country list
AT42I CE9
VK9MTO VK9N 20221229-20230105
- Virustotal825.png (16.1 KiB) 14605 mal betrachtet
Verfasst: Montag 23. Januar 2023, 10:02
Version 8.26
Contest
- Updated: DARC Baden-Würtbg.: Special DOKs
Contest - Bandmap
- Callsign display improved in multi-pass contests
- FOC.TXT
- AGCW.TXT
- DIG.TXT
Country list
3Y0J 3Y/B
3Y/LB1QI 3Y/B
3Y/LB5GI 3Y/B
3Y7GIA 3Y/B
3Y7THA 3Y/B
RI30ANT CE9
R900RO UA3
- Virustotal826.png (15.85 KiB) 14430 mal betrachtet
Verfasst: Dienstag 30. Mai 2023, 09:34
Version 8.27
Contest
- New: DARC YL World Womans Day
- New: KCJ Top Band
- New: RSGB AFS 80m+40m
- New: PRO DIGI
- Updated: DUR-GHz-Aktivitaetscontest (point multiplier removed)
- Updated: Juri Gagarin DX
- Updated: UBA DX (Cabrillo format)
- Updated: DARC Rheinland-Pfalz Akt.Abend
QSO - Work
- New button "Edit Log" -> Opens "Edit Log - Short"
- Fields AWARD/COUNT extended to both possible contents
QSO - Work - Upload Log - QRZ.COM
- "Remarks" data added
- RDA.TXT
- FOC.TXT
- BCC.TXT
Country list
KL3RA W
LU1ZV CE9
VK0AW CE9
RI41POL UA9
FO/AA7JV FO/M
AH6AX W 19950701-
- Virustotal827.png (17.09 KiB) 13491 mal betrachtet
Verfasst: Dienstag 30. Mai 2023, 09:35
Version 8.28
Modes
- New: T10
Contest
- New: CROATIAN RADIO AMATEUR CUP
- Updated: BARTG HF RTTY (Cabrillo format)
- Updated: PACCdigi (rules significantly changed)
- Updated: Holyland (rules significantly changed)
- Updated: DARC Nord-Contest (S-DOKs)
- New: Check box "SSL access to UcxLog server"
Scan - Countries ... - Print:
- New: "Cross list HF" (incl. 60m)
List of satellite names updated:
- FO-118 CAS-5A
- IO-117 Green Cube
- DOK.TXT
- FOC.TXT
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- HSC.TXT
- FIRAC.TXT
Country list
- Prefix 2R added for England
- WAE list
4U100QO 4U_V
TX5L FK
FO/AA7JV FO/M -20230320
FO/AA7JV FO 20230321-
WP4LBK K
E51CIK E5/S
E51WEG E5/S
KL7OR W
FO/N1DG FO
GB3KCJ GJ
RP78AB UA9
RP78AZ UA9
RP78DT UA9
RP78KR UA9
RP78MA UA9
RP78MMK UA9
RP78MP UA9
RP78P UA9
RP78PAW UA9
RP78PM UA9
RP78RGA UA9
RP78TG UA9
RP78TOF UA9
RP78U UA9
RP78UF UA9
RP78V UA9
RP78YT UA9
RP78KM UA9
RP78UR UA9
TX7L FO/M 20231104-20231119
2R0HQA GW
GB9HRH GI
MR0HVU GM
NL7D W
VP6A VP6/D 20230601-20230630
W8S KH8/S 20231004-20231017
4U100QO OE
- Virustotal828.png (22.57 KiB) 13494 mal betrachtet
Verfasst: Dienstag 15. August 2023, 08:47
Version 8.29
Contest
- New: DARC RTTY Kurzconteste
- New: SCRY - Scandinavian Baltic RTTY
- Updated: ARRL International Digital (Cabrillo format)
- Updated: REF Championnat de France VHF (Band multiplier removed)
- Updated: DARC Thueringen
- Updated: WAG (40m SSB allowed over 7130)
- Updated: IOTA (Cabrillo log)
Send UDP Radio Info
- Comment: HTML Escape characters used for "<" and ">"
- TEVEL ...
Help Index expanded
- EHSC.TXT
- FOC.TXT
- HSC.TXT
- RDA.TXT
- SHSC.TXT
- VHSC.TXT
- GDXF.TXT
- AGCW.TXT
- DIG.TXT
- UFT.TXT
- RRC.TXT
Country list
TX6D FO
LU8DBS/Z CE9
VK5DG/9 VK9N
TO0GL FR
FO/F4FJH FO
FO/F1SMB FO
TO8FH FH
16. September: No longer false alarms from "Bkav Pro":
- Virustotal829_2.png (29.02 KiB) 13037 mal betrachtet
Verfasst: Freitag 27. Oktober 2023, 15:40
Version 8.30
Program interface completely available in German
Contest
- New: Croatia DX
- New: Latvian Open Mechanical Key
- Updated: DARC 10m (QSO and Multiplier count per mode)
- Updated: DARC Ostercontest (QSO and Multiplier count per mode)
- Updated: DARC HSW Aktivitaetswettbewerb (Sonder-DOKs)
- Updated: DARC Westfalen Sued Aktiv. (Sonder-DOK)
- Updated: WAEDC (automatic QTC time correction)
- Updated: VFDB-Kontest (Sonder-DOK)
Contest - Work - WAEDC
- "Receive QTC" window scalable
Scan
- New: R150 S
- DOK.TXT
- LOTW.TXT
- RDA.TXT
- FOC.TXT
Master list
- MASTER_CT.TXT updated (Release 2023.10.02.00 by Stu Phillips, K6TU)
Locator list
- LCTR_MMM.TXT updated October 26, 2023
Country list
R150S list completely revised
E51D E5/N
RM80RO UA3
RW80RO UA3
9M66MB 9M2
TO4VV FH
TO7K FR
K8R KH8 20230914-20230917
R80YBR UA3
E51JAN E5/N
VP8/UW5EHR CE9
AL7KT W 19930101-
- Virustotal830.png (31.63 KiB) 12944 mal betrachtet
Verfasst: Montag 4. Dezember 2023, 09:21
Version 8.31
Contest
- New: HAM Spirit
- Updated: WAG (Multiplier counts per mode)
- Updated: AGCW Schlackertastenabend (40m added)
- Updated: VFDB-DLPX (New date for SSB)
- Updated: Russian 160-m-DX
- "Modes shown as 'Rest' = Digital": Base digital modes permanently marked
Fixed errors
- Scan - R150S: Some missing sites
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- RDA.TXT
- MF.TXT
Country list
- Deleted special calls
VK9? VK
VK9QO VK9C 20231103-20231107
JD1YCE JD1/O 20231208-20231219
L36Z CE9
TO0T FJ 20231122-20231129
K8R KH8/S 20231122-20231128
KL5GZ W 20230101-
3Y0K 3Y/B
- Virustotal831.png (31.14 KiB) 12828 mal betrachtet
Verfasst: Mittwoch 24. Januar 2024, 08:36
Version 8.32
Contest
- Updated: OK-OM DX (Rules changed !!!)
- Updated: DARC Weihnachtswettbewerb (QSO and Multiplier count per mode)
- New: Marconi Club ARI Loano QSO Party Day
- Updated: HSC-CW-Contest (NM: 2 points + Multiplier)
- Updated: Croatia DX (determination of ITU zone)
- Updated: RAC Canada Day + RAC Canada Winter
- Updated: DARC Mecklenburg-Vorpommern
- Updated: DARC Baden-Würtbg. (Special DOKs)
View - Call Signs
- New: "Worked on Band in Mode"
QSL - LOTW/eQSL/Clublog - Download QSLs
- List sorted by callsigns
- AGCW.TXT
- DIG.TXT
- FIRAC.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- 100FK.TXT (100 Jahre Deutsches Funk-Kartell)
- MC-AL.TXT (Marconi Club ARI Loano)
- RDA.TXT
- LOTW.TXT
Country list
- Yemen(7O): CQ zone 37 added, ITU zone 48 added
3Y0L 3Y/P
ZS85VDAM ZS
R120I UA9
R120RAEM UA9
R120S UA9
R120T UA9
R120W UA9
VK0DS CE9 20231024-
TO2FY FY
TX8GC FW 20240219-20240309
AR7R AP
TX5S FO/C
GB4WWA GM
VK0AI CE9 20230101-
Leider wieder einmal 1 Fehlalarm
