History Version 8
Re: History Version 8
Version 8.33
Contest
- Updated: YOTA (points)
- Updated: VFDB-Kontest (Sonder-DOK)
Contest - Work
- A call sign that has already been logged will not only be displayed
after entry as "Double", but also registered 2s later as "Double"
in the bandmap.
Contest - Score Upload
- "CQ Contest" renamed to "Live Score" (contest.run),
Upload destination updated
- Contest IDs updated
Member lists updated
- RDA.TXT
- FIRAC.TXT
- FOC.TXT
- HSC.TXT
Country list
- New/changed special calls
TX0QRP FO
GB6WWA GW
GB8WWA GI
KL2A/7 W
TO5LA FH
EM1EHR CE9
EM1UTQ CE9
R81AWD UA3
TX7W FO/A
TO8FP FP
Nun schon 2 Fehlalarme, das wird immer schlimmer werden ...
Already 2 false alarms, this is only going to get worse ...
Contest
Contest - Work
in the bandmap.
- RDA.TXT
- FIRAC.TXT
- FOC.TXT
- HSC.TXT
Country list
TX0QRP FO
GB6WWA GW
GB8WWA GI
KL2A/7 W
TO5LA FH
EM1EHR CE9
EM1UTQ CE9
R81AWD UA3
TX7W FO/A
TO8FP FP
Leider habe ich keinen Weg gefunden, Cynet und Rising wegen der Fehlalarme zu kontaktieren
Die 8.34 Beta 8 endlich mal wieder ohne jeden Fehlalarm
Version 8.34
Contest
- New: World Wide Patagonia DX
Scan - Text
- Results list sorted by callsign
Settings - Station - General
- New: Scaling (All windows): 100...200 %
Windows - Bandmap
- New check box "Sum": Show band overview column
- 40m Fone extended to 7300 (if set in "Station-Bandplan")
Windows - DX Cluster - Contest
- "Show only - Multipliers": Messages for own callsign suppressed
Network
- State display for "Data Rate" and "Log deficit" improved.
- Match of own locators checked (important for VHF/UHF)
- RDA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- MC-AL.TXT
- AGCW.TXT
- DIG.TXT
- CWOPS.TXT
Fixed errors
- Scan - Distance: Band selectable again
Country list
XQ7UP/9 CE9
TO7PX FR
EM1/UW5EHR CE9
N5J KH5 20240801-
N2W KP2 20240103-20240201
AO75IB EA6
AO75IC EA8
AO75MC EA9
E51TLM E5/S
TO60CSG FY 20240406-20240721
Contest
Scan - Text
Windows - Bandmap
Network
- RDA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- MC-AL.TXT
- AGCW.TXT
- DIG.TXT
- CWOPS.TXT
Fixed errors
Country list
XQ7UP/9 CE9
TO7PX FR
EM1/UW5EHR CE9
N5J KH5 20240801-
AO75IB EA6
AO75IC EA8
AO75MC EA9
E51TLM E5/S
Version 8.35
Contest
- New: MRAI - DL6RAI Memorial
- Updated: DARC Hessen HF (MIXED added)
Settings - Station - Transceiver - CAT - Offset
- Negative values allowed
Example: SDR Console and QO-100: Display=10GHz but TX frequency=2.3GHz
Band=2300 Offset/kHz= -8089500 --> Display=2.3GHz
View - Recorded Audio
- English lettering restored
- RDA.TXT
- FOC.TXT
- HSC.TXT
Country list
3D2CCC 3D2/C
GB6WW GM
RP79H UA9
RP79PK UA9
RP79V UA9
GB0SRW GM
GB8VED GM
N5J KH5 20240805-20240820
K8K KH8 20240626-20240709
3D2Z 3D2/R 20241115-20241204
Contest
- RDA.TXT
- FOC.TXT
- HSC.TXT
Country list
3D2CCC 3D2/C
GB6WW GM
RP79H UA9
RP79PK UA9
RP79V UA9
GB0SRW GM
GB8VED GM
Version 8.36
Contest
- Deleted: DL-DX RTTY
Fixed errors
- Keying via Kenwood CAT: Repetition of last sent serial number
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
Country list
- Prefixes VK0, AX0 and VI0 removed at Heard I. and Macquarie I.
KH7Y W 20240313-
JD1BQW JD1/O
TO0J FY
WH6LE W 20211120-
GB9DAT GM
GB6DD GM
R2024B UA2 20240610-20240625
9M1Z 9M6
KL7YK W 20240409-
9M4TOTA 9M2
9M4VM 9M2
GB9OO GM
VK2/W7BRS VK9L 20240710-20240801
K8R KH8 20240707-20240725
VK0* CE9 20240511
E51KEE E5/S
TO973FY FY 20240726-20240810
E51CZZ E5/S
Leider wieder vom Virus-Scanner Bkav Pro der bekannte Fehlalarm:
Contest
Fixed errors
- RDA.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
Country list
KH7Y W 20240313-
JD1BQW JD1/O
TO0J FY
WH6LE W 20211120-
GB9DAT GM
GB6DD GM
9M1Z 9M6
KL7YK W 20240409-
9M4TOTA 9M2
9M4VM 9M2
GB9OO GM
VK0* CE9 20240511
E51KEE E5/S
E51CZZ E5/S
Version 8.37
Contest
- Updated: DARC HSW Aktivitaetswettbewerb (S-DOKs)
- New rules: Russian WW RTTY (before: Russian RADIO RTTY WW)
New member list
- OLYMP24.TXT
- FOC.TXT
- RDA.TXT
Country list
K8R KH8 20240707-20240728
TO2DX FM 19950304-19950326
TO2DX FR 20240928-20241007
GB1URC GM
TX7XG FO
TO2X FG
9M67MA 9M2
9M67MB 9M2
9M67MC 9M2
9M67MD 9M2
9M67MJ 9M2
9M67MK 9M2
9M67MM 9M2
9M67MN 9M2
9M67MP 9M2
9M67MR 9M2
9M67MT 9M2
9M67MW 9M2
9M67MY 9M2
E51WLG E5/S
Wie fast immer der Fehlalarm vom Virus-Scanner Bkav Pro:
Contest
New member list
- OLYMP24.TXT
- FOC.TXT
- RDA.TXT
Country list
GB1URC GM
TX7XG FO
TO2X FG
9M67MA 9M2
9M67MB 9M2
9M67MC 9M2
9M67MD 9M2
9M67MJ 9M2
9M67MK 9M2
9M67MM 9M2
9M67MN 9M2
9M67MP 9M2
9M67MR 9M2
9M67MT 9M2
9M67MW 9M2
9M67MY 9M2
E51WLG E5/S
Version 8.38
Contest
- New: SP Straight Key
- Updated: ARRL EME (New multiplier rule)
- Updated: UBA ON
- Updated: DARC Koeln-Aachen (Sonder-DOK)
Import - ADIF
- Additional field NOTES into "Remarks"
Contest - Import
- Operator added
Fixed errors
- EDI Mode codes 3 and 4 exchanged
Help: Settings - Station
- Split into subchapters
Master list
- MASTER_CT.TXT updated (Release 2024.10.02.00 by Stu Phillips, K6TU)
Locator list
- LCTR_MMM.TXT updated (October 31, 2024 - Source: MMMonVHF (Make More Miles on VHF))
- LOTW.TXT
- DOK.TXT
- RDA.TXT
- FOC.TXT
- HSC.TXT
- FIRAC.TXT
- GDXF.TXT
Country list
3D22 3D2/R
3D2V 3D2/R
3D2YY 3D2 20240904-20240919
FO/G0VDE FO 20240917-20240921
FO/N5LCP FO 20241111-20241116
TX9A FO/A 20250425-20250507
FO/NX1P FO/M
TX100REF FO/M 20250112-20250127
TX7MAS FO/M 20250112-20250127
TX7N FO/M 20250112-20250127
TX7WW FO/M 20250112-20250127
FO/DH5FS FO 20241004-20241023
3D2Y 3D2/R 20241115-20241204
E51SGC E5/S 20241106-20241124
KL7QK W
WH6GNK/4 W
GB2ZL GM
K2IDA KP4
KL1Y W
Endlich wieder ohne einen einzigen Virus-Scanner-Fehlalarm:
Contest
- Updated: UBA ON
Import - ADIF
Contest - Import
- Operator added
Fixed errors
Master list
Locator list
- LOTW.TXT
- DOK.TXT
- RDA.TXT
- FOC.TXT
- HSC.TXT
- FIRAC.TXT
- GDXF.TXT
Country list
3D22 3D2/R
3D2V 3D2/R
FO/NX1P FO/M
KL7QK W
WH6GNK/4 W
GB2ZL GM
K2IDA KP4
KL1Y W
Version 8.39
Contest
- New : DARC CW Ausbildungscontest
- Updated: Russian 160-m-DX
(Points from 10, oblast determination for multiplier)
- Updated: DARC Schwaben
Settings - Station - Band Plan
- List of FT4 and FT8 frequencies added
Settings - Station - Other interfaces
- Send UDP "Radio Info": Second destination possible
Send UDP-Message "Log QSO":
- Points added for contest QSOs (<points>)
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- MF.TXT
- AGCW.TXT
- DIG.TXT
Country list
FO/DL7JLL FO
KP4Q W
4U30B I
TX5NH FO
Ohne Virus-Scanner-Fehlalarme:
Contest
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- MF.TXT
- AGCW.TXT
- DIG.TXT
Country list
FO/DL7JLL FO
KP4Q W
4U30B I
TX5NH FO
Version 8.40
Contest
- New: WWA (World Wide Award)
- Updated: WW PMC (Peace Messenger Cities) - New "GMC"
- Updated: VFDB-DLPX (Month of SSB part)
- Updated: VFDB-Conteste (Special DOKs)
- Updated: PRO DIGI (FT, RTTY, BPSK63 -> 3 independent contests)
- Updated: FOC Marathon (Continent Antarctika=AN counted)
- New check box "> 0 points" at "Display = Contest":
Suppresses all messages with 0 points (mostly double QSOs)
QSO - Work
- QRZ.COM/QRZCQ.COM: SSL used
List of satellite names updated from ARRL
- RDA.TXT
- RRDXA.TXT
- BCC.TXT
- FOC.TXT
- EHSC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- MC-AL.TXT
- FIRAC.TXT
Country list
TX24HAID FK
VK9/W5EIT VK9C
WL7OU W
W4I KP4 20250101-20250116
UE25NY UA3
RC25BA UA9
RK25BA UA3
Keine Virus-Scanner-Fehlalarme:
Contest
QSO - Work
- RDA.TXT
- RRDXA.TXT
- BCC.TXT
- FOC.TXT
- EHSC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- MC-AL.TXT
- FIRAC.TXT
Country list
TX24HAID FK
VK9/W5EIT VK9C
WL7OU W
UE25NY UA3
RC25BA UA9
RK25BA UA3
Version 8.41
Attention:
In Windows 11, the "Mailslots" have recently been switched off (2024).
To work around this, see Help, chapter "Network".
Contest
- Updated: DARC contests: DOK take over from list DOK.TXT
- Updated: DARC Baden-Wuertbg. (Classes, Special DOKs, Cabrillo log)
- Updated: DARC Franken (Band 10m, Mode FM, DOKs)
- Updated: RSGB Commonwealth (Country rating)
- Corrected: WWA (DX cluster display)
UDP "Radio Info"
- Field <gridsquare> filled
Fixed errors
- Telnet messages - Line detection: Error tolerance improved
- DOK.TXT
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- AGCW.TXT
- DIG.TXT
Country list
W4I KP4 20250101-20250131
GB200LB GM
K4W KP4 20230101-20230131
IR0WWA IS
VK9AB VK9N 20250222-20250301
VK9QD VK9N 20250222-20250301
VK9YB VK9N 20250222-20250301
KH7AL W
JA1YVT/JD1 JD1/O 20250402-20250410
FO/TF1OL FO
TO1P FJ
TO8AN FS
Keine Fehlalarme auf VirusTotal:
Attention:
Contest
UDP "Radio Info"
Fixed errors
- DOK.TXT
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- VHSC.TXT
- AGCW.TXT
- DIG.TXT
Country list
GB200LB GM
IR0WWA IS
KH7AL W
FO/TF1OL FO
TO1P FJ
TO8AN FS
Version 8.43
Contest
- Updated: NRAU Activity Contest (NAC) 10m (EDI log : CODXC filled)
- Updated: Holyland (missing points calculated)
- Updated: Deutschland-Contest (missing points calculated)
- Updated: DARC Rheinland-Pfalz Akt.Abend UKW (Multiplier)
- Own IOTA number stored (but not yet used)
- RDA.TXT
- HSC.TXT
- FOC.TXT
Country list
SV1GA/A SV/A 20250125-20250127
TO3E FM 20250520-20250527
GB1KBR GM
IR0RIVA IS
9M4PA 9M2 20250502-20250504
JD1BPG JD1/O
TX5U FO 20250526-20250608
TO974REF FR
RP80* UA3
RP80BF UA2
RP80VPO UA2
RP80AB UA9
RP80AEG UA9
RP80ANW UA9
RP80AV UA9
RP80AZ UA9
RP80CWD UA9
RP80DG UA9
RP80DT UA9
RP80DWK UA9
RP80GAN UA9
RP80GK UA9
RP80GPF UA9
RP80GSD UA9
RP80H UA9
RP80J UA9
RP80KM UA9
RP80KN UA9
RP80KR UA9
RP80LP UA9
RP80MMK UA9
RP80NIK UA9
RP80NT UA9
RP80OTD UA9
RP80PEO UA9
RP80PSH UA9
RP80RF UA9
RP80RGA UA9
RP80RS UA9
RP80SAS UA9
RP80SD UA9
RP80SDD UA9
RP80STD UA9
RP80SUF UA9
RP80TG UA9
RP80TKP UA9
RP80TOF UA9
RP80TVM UA9
RP80U UA9
RP80UK UA9
RP80UR UA9
RP80V UA9
RP80YT UA9
RP80ZAM UA9
Keine Fehlalarme auf Virustotal:
Contest
- RDA.TXT
- HSC.TXT
- FOC.TXT
Country list
GB1KBR GM
IR0RIVA IS
JD1BPG JD1/O
TO974REF FR
RP80* UA3
RP80BF UA2
RP80VPO UA2
RP80AB UA9
RP80AEG UA9
RP80ANW UA9
RP80AV UA9
RP80AZ UA9
RP80CWD UA9
RP80DG UA9
RP80DT UA9
RP80DWK UA9
RP80GAN UA9
RP80GK UA9
RP80GPF UA9
RP80GSD UA9
RP80H UA9
RP80J UA9
RP80KM UA9
RP80KN UA9
RP80KR UA9
RP80LP UA9
RP80MMK UA9
RP80NIK UA9
RP80NT UA9
RP80OTD UA9
RP80PEO UA9
RP80PSH UA9
RP80RF UA9
RP80RGA UA9
RP80RS UA9
RP80SAS UA9
RP80SD UA9
RP80SDD UA9
RP80STD UA9
RP80SUF UA9
RP80TG UA9
RP80TKP UA9
RP80TOF UA9
RP80TVM UA9
RP80U UA9
RP80UK UA9
RP80UR UA9
RP80V UA9
RP80YT UA9
RP80ZAM UA9
Version 8.44
Contest
- New: RSGB 70MHz
- New: QRP-MinimalArt-SESSION
- Updated: VFDB (Special stations and DOKs)
- Updated: DARC Nordischer Hoehentag
- New scaling for windows "Received digital"
- RDA.TXT
- HSC.TXT
- FOC.TXT
- AGCW.TXT
- DIG.TXT
- EHSC.TXT
- SHSC.TXT
- VHSC.TXT
- RRDXA.TXT
Country list
4U0IARU OE
FO/G0VJG FO
GB8SOS GW
JD1BRC JD1/O 20250802-20250808
TX5U FO 20250526-20250611
GB8URC GM
GB2LC GM
TO3K FH 20250802-20250810
TX9XG FO
VP0SG VP8/G
TO0WWA FR 20250630-20250706
Contest
- New: RSGB 70MHz
- RDA.TXT
- HSC.TXT
- FOC.TXT
- AGCW.TXT
- DIG.TXT
- EHSC.TXT
- SHSC.TXT
- VHSC.TXT
- RRDXA.TXT
Country list
4U0IARU OE
FO/G0VJG FO
GB8SOS GW
GB8URC GM
GB2LC GM
TX9XG FO
VP0SG VP8/G
Version 8.45
Contest
- New: RSGB 70MHz Trophy
- Updated: YO DX HF (YO counts also as DXCC multiplier)
- Updated: RSGB 70MHz CW (log format REG1TEST)
Menu "Help - Trace System Events":
- New "Upload Trace"
- Ctrl + Double Click: Also take over of comment into QSO window
- RDA.TXT
- EHSC.TXT
- FOC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- FIRAC.TXT
- LOTW.TXT
Master list
- MASTER_CT.TXT updated (Release Release 2025.09.02.00 by Stu Phillips, K6TU)
Locator list
- LCTR_MMM.TXT updated (September 12, 2025 - Source: MMMonVHF (Make More Miles on VHF))
Country list
M0WTQ GM
9M9TYT 9M2
GB8VJ GM
VK9QO VK9X 20251003-20251007
9M25MQ 9M6
9M25MS 9M6
TX14TOM FO
JA1ZLO/JD1 JD1/O
4U1VHF I
VK2/SP9FIH VK9L
GB2SLH GM
9M1957M 9M2
R95MAI UA3
Contest
- RDA.TXT
- EHSC.TXT
- FOC.TXT
- HSC.TXT
- SHSC.TXT
- VHSC.TXT
- FIRAC.TXT
- LOTW.TXT
Master list
Locator list
Country list
M0WTQ GM
9M9TYT 9M2
GB8VJ GM
9M25MQ 9M6
9M25MS 9M6
TX14TOM FO
JA1ZLO/JD1 JD1/O
4U1VHF I
VK2/SP9FIH VK9L
GB2SLH GM
9M1957M 9M2
R95MAI UA3
Version 8.46
Contest
- Updated: VFDB contests (DOKs)
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- AGCW.TXT
- DIG.TXT
Fixed errors
- From version 8.45:
More critical country determination for FR and FK withdrawn.
Country list
JD1/JA1ZLO JD1/O
VK9/SP9FIH VK9X
II0IARU IS
JD1/JQ3JUK JD1/O
JQ3JUK/JD1 JD1/O
IQ0AK IS
TX9W FO/M 20260419-20260430
Contest
- RDA.TXT
- RRDXA.TXT
- FOC.TXT
- HSC.TXT
- AGCW.TXT
- DIG.TXT
Fixed errors
Country list
JD1/JA1ZLO JD1/O
VK9/SP9FIH VK9X
II0IARU IS
JD1/JQ3JUK JD1/O
JQ3JUK/JD1 JD1/O
IQ0AK IS
