I am getting a dialogue box appera whenever I select the 'QRZ.COM' button in the work window.
It states:
"Ungultige Gleitkommaoperation."
If I then try to move the window that displays 'QRZ.COM' i get this message:
'Zugriffsverletzung bei Adresse 3D7B4E56 in Modul 'jscrip.dll'. Lesen von Adresse 0000F012.
The UcxLog shuts down!!
Sorry but I do not understand German, but if you could suggest anythign to fix this I would be greatful.
James (MD0MDI)
Error Message: Ungultige Gleitkommaoperation.
Re: Error Message: Ungultige Gleitkommaoperation.
Which Version of Internet-Explorer you have installed and which OS you are using?
I think it's not an error in UcxLog but in your Internet Explorer and JavaScript.
"Ungueltige Gleitkommaoperation" means "Invalid floating point operation".
No idea to fix this.
Maybe installing actual Microsoft patches for OS and IE would fix the problem. Also upgrading IE could also do something good on it.
Hi Guys, I personally do not use IE, but I take it from the comments that UcxLog defaults to IE?
The version that is installed is 8.0.6001.18702
I have checked 'Windows Update' and the system is updated as far as it can go (Windows XP SP3), plus ALL available updates...
I have installed the latest version of Java (Version 6 Update 29).
Any other ideas?????
James (MD0MDI)
James (MD0MDI)
Hi James,
UcxLog "defaults" to windows API functions and components and windows opens an explorer, don't know which.
