History Version 7
Re: History Version 7
Version 7.47
Contest:
- New: Italian Activity
- New: UBA PSK63 Prefix
- New: MF Activity Weekend
- Updated: DARC Februar QSO-Party
All windows:
- Windows - Control Panel - Display - ... size of text and other items:
Enlargement (125%, 150%) realized
Main windows
- New field "CRC": Green = Program self check ok
TRX
- K3/KX3: RTTY+PSK via CAT possible (still test phase)
Settings - Station - Special
- Blind: New display field in Work window and hotkeys
Telnet
- Sent "Talk" messages also listed in separate yellow field
PSK (internal)
- Submode selection simplified
Member lists updated
- FIRAC.TXT
- LOTW.TXT
- DOK.TXT
Fixed errors
- Windows-Signal-Envelope: Missing green signal line
- NRAU-Baltic Contest: Private Cabrillo format implemented
COUNTRY.TXT Version 7.47
- New/changed special calls
R2MWO UA2
R900BL UA3
RA/UT2LA UA9
RA77VV UA9
RC/UU9JDP UA3
RT77VV UA9
K1N KP1 20150130-20150228
Contest:
All windows:
Main windows
TRX
Telnet
PSK (internal)
- FIRAC.TXT
- LOTW.TXT
- DOK.TXT
Fixed errors
R2MWO UA2
R900BL UA3
RA/UT2LA UA9
RA77VV UA9
RC/UU9JDP UA3
RT77VV UA9
Version 7.49
- 7.48 moved back because of band selection error at Contest-New
Update
- New: "Additional Member Lists - ..."
for Download/Update of W/VE lists from DL6ER
Contest
- New: EA PSK63
- New: DARC UKW Fruelingswettbewerb
- Updated: Ten Ten
- Updated: NRAU VHF class numbers
- Updated: Hessenkontest
- Updated: UBA-DX
Contest - Work
- Field "Needed multis": Redesigned (Country related, Mode dependent)
Windows
- New: "Tune data": Store up to 6 tune data values per band segment
Windows - DX Cluster - Watch List
- New option: "..." for exact search of complete call
Windows - Telnet
- New field "Offset" for Skimmer RXs with transverter
Scan - DXCC/WAE
- Full country names added
Settings - Station - Transceiver - CAT K3 - Control via CAT
- New check box: "Set submodes"
TRX
- K3/KX3: RTTY+PSK via CAT: MOX usable (max. 4s diddles)
- LOTW.TXT
Fixed errors
- DARC Februar QSO-Party 2015: Points corrected
- K3/KX3: RTTY+PSK via CAT: Send breaks fixed
COUNTRY.TXT Version 7.48
9M4SI 9M2
RAEM UA9 20141201-20141231
FO/K8PGJ FO
GS8VL GM
N0J KH0 20150212-20150218
TO66R FG
Update
Contest
- New: EA PSK63
- Updated: Ten Ten
- Updated: UBA-DX
Contest - Work
Windows
Windows - Telnet
Scan - DXCC/WAE
TRX
- LOTW.TXT
Fixed errors
9M4SI 9M2
FO/K8PGJ FO
GS8VL GM
TO66R FG
Falls jemand im DX-Cluster-Fenster statt der bunten Farben nur noch Weiß und Dunkelgelb sieht,
hilft es in Settings-Station-Special das Häkchen bei "Blind" zu entfernen.
Version 7.50
Contest
- New: Africa All-Mode International DX
- New: Open Ukraine RTTY Championship
TRX control
- New: Yaesu FT-991
Settings - Station - Other interfaces - Digital
- New choice: "Send letters = Upper case / Lower case"
- Extensions for "Blind"
- LOTW.TXT
Fixed errors
- Windows - Tune Data: Upper display row deleted > 500MHz
COUNTRY.TXT Version 7.50
DX0P 1S
TO5BR FY
VP8DOU CE9
II0C IS
KP4QT/4 W
E51IOU E5/S
E51UFF E5/N
II0ICH IS
II0IDP IS
R120RDP UA9
4U5F I
TO90IARU FM
R120RB UA9
R120RG UA9
R120RI UA9
R120RJ UA9
R120RL UA9
R120RN UA9
R120RP UA9
R120RQ UA9
R120RU UA9
R120RW UA9
R120RZ UA9
R2015R UA9
Version 7.50
Contest
TRX control
- New: Yaesu FT-991
- LOTW.TXT
Fixed errors
DX0P 1S
TO5BR FY
VP8DOU CE9
II0C IS
KP4QT/4 W
E51IOU E5/S
E51UFF E5/N
II0ICH IS
II0IDP IS
R120RDP UA9
4U5F I
TO90IARU FM
R120RB UA9
R120RG UA9
R120RI UA9
R120RJ UA9
R120RL UA9
R120RN UA9
R120RP UA9
R120RQ UA9
R120RU UA9
R120RW UA9
R120RZ UA9
R2015R UA9
Version 7.51
Contest
- Updated: VFDB-Aktivitaetstage
- New: DigiFest
- New: UKSMG Summer Marathon
- New: UKSMG Summer Contest
- Updated: Saar Contest
- Updated: DARC Funkertag Juni-Party
Settings - Cloud
- Additional TRX number possible for "Upload/publish own TRX frequency"
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- LOTW.TXT
- EPC.TXT
COUNTRY.TXT Version 7.51
R450WA UA9
VK9NW VK 20150404-20150420
9M4WSB 9M2
VP8DOZ VP8/G
TX5P FO/C
GB8RAF GI
PY0NY PY0F 20150503-20150509
9M4LHC 9M2
9M4LHJ 9M2
9M4MIA 9M2
9M4SEA 9M6
9M4SIX 9M2
9M4SMS 9M6
9M4SMY 9M2
9M4STA 9M6
9M4TI 9M2
GB6AC GW
JE2EHP/JD1 JD1/O
RP70KB UA2
RP70KG UA2
RP70MW UA2
RP70WB UA2
RP70AB UA9
RP70AF UA9
RP70AS UA9
RP70AY UA9
RP70AZ UA9
RP70BP UA9
RP70DG UA9
RP70DT UA9
RP70G UA9
RP70GA UA9
RP70GB UA9
RP70GI UA9
RP70GK UA9
RP70GM UA9
RP70GP UA9
RP70GR UA9
RP70GS UA9
RP70H UA9
RP70KE UA9
RP70KM UA9
RP70KV UA9
RP70LF UA9
RP70LL UA9
RP70LM UA9
RP70LS UA9
RP70MA UA9
RP70MC UA9
RP70MD UA9
RP70MP UA9
RP70NK UA9
RP70NM UA9
RP70OB UA9
RP70OF UA9
RP70OS UA9
RP70P UA9
RP70PM UA9
RP70R UA9
RP70RS UA9
RP70SA UA9
RP70SD UA9
RP70SF UA9
RP70SL UA9
RP70SU UA9
RP70TG UA9
RP70TM UA9
RP70UF UA9
RP70UH UA9
RP70UK UA9
RP70V UA9
RP70YF UA9
RP70ZF UA9
RP70ZO UA9
R120RP UA3
RP65TT UA9
E51DLD E5/S
E51VFT E5/S
GB0PAT GI
GB2AES GM
GB2MAC GI
GB2REL GI
GB2STP GI
GB2SUM GM
GB2WW GW
GB4MPI GW
GB6RAF GW
TO5Y FM
AO150U EA8
R90IARU UA3
4U150ITU 4U_IT
DL1YAF/VK9 VK9L
Contest
- New: DigiFest
Settings - Cloud
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- LOTW.TXT
- EPC.TXT
R450WA UA9
9M4WSB 9M2
VP8DOZ VP8/G
TX5P FO/C
GB8RAF GI
9M4LHC 9M2
9M4LHJ 9M2
9M4MIA 9M2
9M4SEA 9M6
9M4SIX 9M2
9M4SMS 9M6
9M4SMY 9M2
9M4STA 9M6
9M4TI 9M2
GB6AC GW
JE2EHP/JD1 JD1/O
RP70KB UA2
RP70KG UA2
RP70MW UA2
RP70WB UA2
RP70AB UA9
RP70AF UA9
RP70AS UA9
RP70AY UA9
RP70AZ UA9
RP70BP UA9
RP70DG UA9
RP70DT UA9
RP70G UA9
RP70GA UA9
RP70GB UA9
RP70GI UA9
RP70GK UA9
RP70GM UA9
RP70GP UA9
RP70GR UA9
RP70GS UA9
RP70H UA9
RP70KE UA9
RP70KM UA9
RP70KV UA9
RP70LF UA9
RP70LL UA9
RP70LM UA9
RP70LS UA9
RP70MA UA9
RP70MC UA9
RP70MD UA9
RP70MP UA9
RP70NK UA9
RP70NM UA9
RP70OB UA9
RP70OF UA9
RP70OS UA9
RP70P UA9
RP70PM UA9
RP70R UA9
RP70RS UA9
RP70SA UA9
RP70SD UA9
RP70SF UA9
RP70SL UA9
RP70SU UA9
RP70TG UA9
RP70TM UA9
RP70UF UA9
RP70UH UA9
RP70UK UA9
RP70V UA9
RP70YF UA9
RP70ZF UA9
RP70ZO UA9
R120RP UA3
RP65TT UA9
E51DLD E5/S
E51VFT E5/S
GB0PAT GI
GB2AES GM
GB2MAC GI
GB2REL GI
GB2STP GI
GB2SUM GM
GB2WW GW
GB4MPI GW
GB6RAF GW
TO5Y FM
AO150U EA8
R90IARU UA3
4U150ITU 4U_IT
DL1YAF/VK9 VK9L
Version 7.52
Update
- Fall back to last installed version (release)
Contest - VHF
- New bands (e.g. 70Mhz and >10GHz) possible
- Work window redesigned
Contest
- WAEDC: Cabrillo format supported
- Updated: VFDB contests
- Updated: DARC Ruhrgebiet-Kurzcontest
Locator Map
- Extended by new bands
Settings
- New: Export QSL Layout (without other settings)
PSK modes
- Additional predefined submodes PSK250, PSK500, QPSK250, QPSK500
CW
- Speed setting refined
- DOK.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
- EPC.TXT
- LOTW.TXT
- FIRAC.TXT
COUNTRY.TXT Version 7.52
UE25IK UA3
AO150V EA8
E51DWC E5/S
UE44Y UA9
E51AGY E5/S
GB2BOW GW
R2015AS UA9
R2015DS UA9
R2015EP UA9
R2015KM UA9
R2015LY UA9
R2015TL UA9
TO90R FR
R98KPM UA3
E51EAQ E5/S
E51XGI E5/S
R15CWC/0 UA9
R15CWC/8 UA9
R15CWC/9 UA9
LU4AA/? LU
R100D UA9
R100DI UA9
UE73D UA9
UE73DI UA9
9M10CSB 9M2
9M4KI 9M2
FO/JI1JKW FO/M 20150809-20150813
UE85NKN UA3
UE85WDW UA3
GB1DHL GM
GB1DS GW
9M4CST 9M2
R920RZ UA3
9M58MA 9M2
9M58MB 9M2
9M58MC 9M2
9M58MD 9M2
9M58MJ 9M2
9M58MK 9M2
9M58MM 9M2
9M58MN 9M2
9M58MP 9M2
9M58MR 9M2
9M58MS 9M6
9M58MY 9M2
9M58MW 9M6
JD1BOH JD1/O
TX7EME FO
R2015SV UA9
Update
Contest - VHF
Contest
Locator Map
Settings
PSK modes
CW
- DOK.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
- EPC.TXT
- LOTW.TXT
- FIRAC.TXT
UE25IK UA3
AO150V EA8
E51DWC E5/S
UE44Y UA9
E51AGY E5/S
GB2BOW GW
R2015AS UA9
R2015DS UA9
R2015EP UA9
R2015KM UA9
R2015LY UA9
R2015TL UA9
TO90R FR
R98KPM UA3
E51EAQ E5/S
E51XGI E5/S
R15CWC/0 UA9
R15CWC/8 UA9
R15CWC/9 UA9
LU4AA/? LU
R100D UA9
R100DI UA9
UE73D UA9
UE73DI UA9
9M10CSB 9M2
9M4KI 9M2
UE85NKN UA3
UE85WDW UA3
GB1DHL GM
GB1DS GW
9M4CST 9M2
R920RZ UA3
9M58MA 9M2
9M58MB 9M2
9M58MC 9M2
9M58MD 9M2
9M58MJ 9M2
9M58MK 9M2
9M58MM 9M2
9M58MN 9M2
9M58MP 9M2
9M58MR 9M2
9M58MS 9M6
9M58MY 9M2
9M58MW 9M6
JD1BOH JD1/O
TX7EME FO
R2015SV UA9
Version 7.53
Contest
- New: UBA ON contest
Windows - Call Data Base
- New selection for "Standard browser" if internal browser fails
Worked list
- New pop-up menu item "No limit of window height"
QSL - LOTW upload
- Work around for error in TQSL 2.1
- LOTW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
- AGCW.TXT
Fixed errors
- Cloud upload failed
- QRZ.COM window pushes before work window
- NAC contest - Work window: Bonus points not shown in column "Total"
COUNTRY.TXT Version 7.53
E51MKW E5/N
E51MQT E5/N
E51MBX E5/N
TX7A FO
GB75BB GW
TO1E FS
TX3X FK/C
4U70VIC OE
R10NRC UA9
UE25R UA3
Contest
Worked list
QSL - LOTW upload
- LOTW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
- AGCW.TXT
Fixed errors
E51MKW E5/N
E51MQT E5/N
E51MBX E5/N
TX7A FO
GB75BB GW
TO1E FS
TX3X FK/C
4U70VIC OE
R10NRC UA9
UE25R UA3
Version 7.54
!!! Important security update !!!
!!! Essential for cloud access !!!
Help
- New: Read news
Contest
- DTC: Checks tighten up
- DARC 10m + Easter: New class "SSB"
- New Pop-Up menu at "RX" check box: "Only RX Mode" / "All Modes"
- MF.TXT
- LOTW.TXT
- DOK.TXT
Fixed errors
- Ten-Tec Omni: CAT modes corrected
COUNTRY.TXT Version 7.54
GB2BOL GM
K5P KH5 20151015-20160430
RA/DL8WAA UA9
TO4K FJ
TO2M FM 20151017-20151027
TO4GU FM
UE96SN UA3
4U70UN 4U_UN 20151024-20151025
E51KIK E5/S
IA0IPY I
Help
- New: Read news
Contest
- MF.TXT
- LOTW.TXT
- DOK.TXT
Fixed errors
GB2BOL GM
RA/DL8WAA UA9
TO4K FJ
TO4GU FM
UE96SN UA3
E51KIK E5/S
IA0IPY I
Version 7.55
Contest
- New: CQ DX Marathon
- New: UFT-YL-CW
- New: UK-EI DX
- Updated: RTC-Party
Contest - Cabrillo format
- Updated for DARC-XMAS and DARC-10m
- Private defined field "SPECIFIC" of DARC implemented
Settings - Station
- Other interfaces: New "Cat Output to PA/Tuner"
- LOTW.TXT
Fixed errors
- RTTY-Contest/ESM-S&P: Wrong F-text number after call sign
take-over from "Received Digital" window
COUNTRY.TXT Version 7.55
- ZL9: Long name changed from "Auckland & Campbell Is."
to "New Zealand Subantarctic Isl."
VI90IARU VK
R2015RR UA9
ET2US E3 -19621114
TO8M FM
XR90IARU CE
8T2BH CE9
9M4CHM 9M2
Contest
- New: UFT-YL-CW
- New: UK-EI DX
Settings - Station
- LOTW.TXT
Fixed errors
VI90IARU VK
R2015RR UA9
ET2US E3 -19621114
TO8M FM
XR90IARU CE
8T2BH CE9
9M4CHM 9M2
Version 7.56
Contest
- Updated: PACC (all multipliers per mode)
Contest
- Work : Length of "Worked" QSO list limited because of run time
- Worked Multis: Separate fields and colors for multiplier 1..3
Windows - Received Digital
- Titles of F-buttons changeable
- Sideband for RTTY/AFSK and PSK/Digital independent selectable
- "TX Mode = Data/Pkt.": ICOM CAT command "Data Mode" implemented
Settings - Station - Transceivers
- Check box "CW Revers" (not supported by some old TRX)
LPT ports
- Driver inpout32.dll supported (useful for all Windows versions)
WinRotor
- Updated for version 5
IOTA list
- Updated from www.rsgbiota.org/xml/fulllist.xml
Master list
- MASTER_CT.TXT updated (Release 2015.12.02.00 by Stu Phillips, K6TU)
Manager list
- OQRS list updated
- FIRAC.TXT
- LOTW.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
COUNTRY.TXT Version 7.56
SX90IARU SV
ZL90IARU ZL
E51WET E5/S
R18KDR/0 UA9
R18KDR/8 UA9
R18KDR/9 UA9
TX90IARU FK
R1AN UA3
UE24SU UA3
TO2EE FJ
VP8SGI VP8/G
VP8STI VP8/S
E51LLA E5/S
GB5OMU GI
VK2IAY/9 VK9L
4U20B I
PJ/KG2A PJ2
9M90IARU 9M2
R2015BP UA9
R170GS UA9 20151101-20151108
RAEM UA3 -20031221
RAEM UA9 20041226-
E51ARJ E5/S
E51AVO E5/S
E51IVU E5/S
E51J E5/S
E51LSS E5/S
E51PBL E5/S
E51SSS E5/S
E51UJR E5/S
E5SKCC E5/S
Contest
Contest
LPT ports
WinRotor
IOTA list
Master list
Manager list
- OQRS list updated
- FIRAC.TXT
- LOTW.TXT
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
SX90IARU SV
ZL90IARU ZL
E51WET E5/S
R18KDR/0 UA9
R18KDR/8 UA9
R18KDR/9 UA9
TX90IARU FK
R1AN UA3
UE24SU UA3
TO2EE FJ
VP8SGI VP8/G
VP8STI VP8/S
E51LLA E5/S
GB5OMU GI
VK2IAY/9 VK9L
4U20B I
PJ/KG2A PJ2
9M90IARU 9M2
R2015BP UA9
RAEM UA3 -20031221
RAEM UA9 20041226-
E51ARJ E5/S
E51AVO E5/S
E51IVU E5/S
E51J E5/S
E51LSS E5/S
E51PBL E5/S
E51SSS E5/S
E51UJR E5/S
E5SKCC E5/S
Version 7.57
Contest
- New: Concurso 80 metros CW URE Manises
- Corrected: BARTG Sprint
- Updated: DARC Ostercontest (Easter egg) - Cabrillo format
- Updated: VFDB DOKs
QSO - Work - DXpedition
- New fields "x * Fy -> Fz" for counted F-text addition
(Hotkeys for increment/decrement of "x")
Settings - Station - Other interfaces - ...digital
- Check box "IC-746pro" added (special data mode)
K3/KX3
- RTTY/PSK via CAT: Control stabilized
- LOTW.TXT
- EPC.TXT
- DOK.TXT
COUNTRY.TXT Version 7.57
GB0ELR G
R2AG/9 UA9
RA/DL5WW UA3
RA/UT5JCE UA3
RA/UY6IM UA3
TX7EU FO/M 20160303-20160315
R1991A UA9
R25ARCK/0 UA9
R25ARCK/8 UA9
R25ARCK/9 UA9
RA/NT2X UA3
E51JLL E5/S
E51JNH E5/S
TX2AH FO
E51RJR E5/S
GB5LB GD
Contest
K3/KX3
- LOTW.TXT
- EPC.TXT
- DOK.TXT
GB0ELR G
R2AG/9 UA9
RA/DL5WW UA3
RA/UT5JCE UA3
RA/UY6IM UA3
R1991A UA9
R25ARCK/0 UA9
R25ARCK/8 UA9
R25ARCK/9 UA9
RA/NT2X UA3
E51JLL E5/S
E51JNH E5/S
TX2AH FO
E51RJR E5/S
GB5LB GD
Version 7.58
Contest
- New: UKEI 80m
- New: Russian Wednesday Mini
- Updated: DARC Februar-QSO-Party
- Improved: FOC Marathon: Taking over of exchange from FOC member list
Contest - Wertungslog
- Additional result file *.SUM generated
Scan
- New: Member lists: Searches logged callsigns in member lists
QSO - Work
- Automatic take-over of DOK from DOK member list
Windows - Send
- Colon (:) for additional pause of 1 point length
Windows - Main
- Windows7 error at 150% scaling: Huge font in status line fixed
- New check box "Disable ports" for temporary TRX switch off
TRX control
- New TRX: "Flexradio-SmartSDR" - New mode "RTTY(AFSK)" supported
- DOK.TXT
- LOTW.TXT
Fixed errors
- QSO-Work-DXpedition: Counted F-text addition also with ESM mode
- Scaling of window "Received Digital" with 120ppi fixed
- FT-450: Wrong "PTT via CAT" removed
COUNTRY.TXT Version 7.58
9M4CKB 9M2
LU1ZI VP8/H
N0J KH0 20160210-20160215
VK9PAS VK9N 20160523-20160530
E51RR E5/S
JD1BMT JD1/O
9M4CRX 9M2
R85PAR UA3
TO5O FS
VK0EK VK0/H
E51AQA E5/S
Contest
- New: UKEI 80m
Scan
QSO - Work
Windows - Send
Windows - Main
TRX control
- DOK.TXT
- LOTW.TXT
Fixed errors
9M4CKB 9M2
LU1ZI VP8/H
E51RR E5/S
JD1BMT JD1/O
9M4CRX 9M2
R85PAR UA3
TO5O FS
VK0EK VK0/H
E51AQA E5/S
Version 7.59
Update - UcxLog Registration
- Also possible by UcxLog web server (without own e-mail program)
Contest
- Updated: ES Open (Same station can be worked in CW + SSB)
- Auto-copy to work window: New "Manager"
Settings - QSL Layout
- Date format "DD-mon-YYYY" added
New start parameter: "-DX_MSG_BUF=nnnn"
Increases number of buffered DX messages to nnnn (3000...9000).
Attention:
Do not use on slow PCs. Observe CPU load during flood of RBN messages.
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
- CWOPS.TXT
Fixed errors
- Scan - Member list - HSC: Member ID too short
- Contest-Work-VHF-Undo-Sent: Doubling of own locator
- Contest - Score log: NAC file error
Contest
Attention:
- AGCW.TXT
- DIG.TXT
- FOC.TXT
- HSC.TXT
- RTC.TXT
- CWOPS.TXT
Fixed errors
Version 7.60
Contest
- New: AGCW-DL QRP-Contest
Windows - Map
- New pop-up menu item: "Large size"
- LOTW.TXT
Fixed errors
- SR/SS display missing
- AGCW VHF/UHF Contest: Correct sent exchange forced
COUNTRY.TXT Version 7.60
R2014FX UA9
R80KEDR UN
RA80KEDR UA3
RL80KEDR UA3
RN80KEDR UA3
RU80KEDR UA3
UE25ST UA9
UE80G UA3
UE80HS UA3
FO/NH6XO FO
GB0SPD GI
UE2KR UA3
VK9/LB1GB VK9C
TO972M FM
Contest
Windows - Map
- LOTW.TXT
Fixed errors
R2014FX UA9
R80KEDR UN
RA80KEDR UA3
RL80KEDR UA3
RN80KEDR UA3
RU80KEDR UA3
UE25ST UA9
UE80G UA3
UE80HS UA3
FO/NH6XO FO
GB0SPD GI
UE2KR UA3
VK9/LB1GB VK9C
TO972M FM
Version 7.61
Contest
- New: AEGEAN RTTY
- Complete display of all messages of own callsign
QSO - Edit Log - Short
- New "Log check" (for DXpeditions).
- LOTW.TXT
COUNTRY.TXT Version 7.61
- DXCC list: Kingman Reef (KH5K) deleted, effective 29 March, 2016.
- WAE list: Prefix of Kosovo changed from YU8 to Z6
9M4PB 9M2
FO/K3JZ FO
FO/N7SOF FO
UE2SE UA3
9M0O 1S
E51MRC E5/S
RK55GC UA9
RW55YG UA9
RX55YG UA9
RZ55YG UA9
SV2RSG SV/A
Fixed errors
- OK-OM-DX SSB contest: Month corrected to April
- ES Open Championship: Calculation corrected
Contest
- New: AEGEAN RTTY
- LOTW.TXT
9M4PB 9M2
FO/K3JZ FO
FO/N7SOF FO
UE2SE UA3
9M0O 1S
E51MRC E5/S
RK55GC UA9
RW55YG UA9
RX55YG UA9
RZ55YG UA9
SV2RSG SV/A
Fixed errors
Version 7.62
Contest
- New: DUR-GHz-Aktivitaetscontest
- Updated: IARU Region 1 Fieldday - Cabrillo format
Contest - Score Log
- Category Power stored
- New check box "Additional SUM file"
Start parameter: "-DX_MSG_BUF=nnnn" removed,
number of buffered DX messages always increased to 9000.
- LOTW.TXT
- HSC.TXT
- FIRAC.TXT
COUNTRY.TXT Version 7.62
9M0Z 1S
R25ARCK UA9
RP70DG UA9
RP71SD UA9
RP71SF UA9
RP71TG UA9
RP71V UA9
E51ADT E5/S
E51XYZ E5/S
VI9ANZAC VK9N
VK9OL VK9L
VK9PC VK9N
VK9PAC VK9N
VK9WI VK9N 20160524-20160530
R85WTA UA3
R90DNF UA3
Contest
Contest - Score Log
- LOTW.TXT
- HSC.TXT
- FIRAC.TXT
9M0Z 1S
R25ARCK UA9
RP70DG UA9
RP71SD UA9
RP71SF UA9
RP71TG UA9
RP71V UA9
E51ADT E5/S
E51XYZ E5/S
VI9ANZAC VK9N
VK9OL VK9L
VK9PC VK9N
VK9PAC VK9N
R85WTA UA3
R90DNF UA3
