Hello
I have a problem with the telnet connections.
I am connected to DB0SUE and the RBN telnet. No spots show up on the DXCluster window.
Any solution?
Thanks,
Dani
YO5LD
telnet
Re: telnet
Hello Dani,
If you entered an "Offset" in Telnet, change it to 0.
Do you have green check boxes for band and mode in DX cluster window ?
Re: telnet
Hello Ben
Thanks for the reply.
I'm using also ver 6.84, also tried in the last version. With no offset obviously.
Could there be any problems how the OS is installed?
Re: telnet
Hello Dani,
Version 6.84 is 5 years old
I can not remember about such a problem.
Please note:
I support only the actual last UcxLog version.
I can not manage support for older versions, this is impossible, sri.
Please note:
