5MHz Not being displayed correctly in Worked Window
MD0MDI
Beitrag von MD0MDI »
If i log a contact on 5MHz, when i enter that same callsign again and see a list of previous contacts, all of the entries that were on 5MHz appear with a frequency of '?????', is there a way to get the actual frequency to be displayed?
Re: 5MHz Not being displayed correctly in Worked Window
Hi James,
you will need to select 5.1 MHz as "additional band" (Settings -> Station -> Special) to get 5 MHz accepted. Sadly I'm not able to test this in my office...
73 Nick, DL6ER
Hello James,
Please note that only some windows handle the additional bands (see HISTORY.TXT).
I'm working on more extensions ...
And I need user comments, what is really needed.
MD0MDI
Thanks for the info but this was already set, I unselected it and shut down UcxLog, and then restarted and reset this, and then shut down again to make sure that the options were applied corerectly, and it still only shows the 5MHz frequencies in the 'Worked' window when no QSO is entered and the text is green (just for clarification), when you enter a callsign that you have previously talked to on say 5MHz in the 'Worked' window that is now just displaying previous contacts made to that callsign, the frequency appears as '???'.
Hello James,
thanks for the tip, I will check it next week when I will be back in DL.
