DX Cluser Window - RX option and Watch list
LB2EG
Beitrag von LB2EG »
Ben,
I am using the kHz-kHz option in Dx Cluster Watch list til show all spots on 60 meter band. Checking the RX option, showing only band/mode specific spots, does however not filter out the 60 meter band spots from the Dx Cluster window. Call sign Watch list entries does not show up unless being on the RX band.
Is this a bug or a feature?
Regards
Richard LB2EG
Re: DX Cluser Window - RX option and Watch list
Hello Richard,
This is a limitation to the usual amateur bands and is related to DXCC.
On the left side you see only the classic bands, only these can be filtered by the "RX" option.
The kHz-kHz option is a work around to watch the new bands.
This is not perfect but should be sufficent.
LB2EG
Beitrag von LB2EG »
DL7UCX hat geschrieben:Hello Richard,
Ben,
I can live with that:) The kHz-kHz watch is really useful.
Richard
