UBA DX contest only CW possible to log??
PE1EXD
Beitrag von PE1EXD »
I worked some stations in SSB in th UBA DX contest of today, but I could only log them as CW contact, with also a 599 report.
I did not manage to change to SSB, and 59. Other contests in the recent past never a problem.
Something that I did wrongly, or do I at last have to learn CW?
73, Kees, PE1EXD
Re: UBA DX contest only CW possible to log??
Hi Kees,
I think you made a mistake: if you select the UBA-DX Contest you have to activate the Fone Mode, otherwise you are in the CW Mode..
It works perfectly.
73 Klaus DL1DTL
Contest - New ...
PE1EXD
Thanks, Ben,
I was to fast, and did no see that menu. It works well, only have to correct my QSOs from CW to SSB, but I will never again make that mistake.
Hello Kees,
By the way, I remember that there is a menu function to solve your problem also later:
Contest - Rename
