Length of the OPERATOR tag
oz1bii
Beitrag von oz1bii »
Hi
I have a log with different operators and want to print them on the QSL with the <op> option.
BUT
In my HRD log the operator names are up to 11 characters and when importing the log into UCXLog they are being cut of to 8. They do not show up in Log Edit Full. But they print with 8 characters.
I found an information in UCXLog help that define the operator to max 7 characters - actually it will print 8.
Is it possible to change that limitation to maybe 16 characters ??
73 de OZ1BII Henning
Re: Length of the OPERATOR tag
Hello Henning,
The operator name is limited to 8 characters ("7" in Help is outdated, I will correct it).
It is stored in the fixed log record, I can not change this, sri.
Tip: You can rename the truncated operator names to better ones using "Group modify".
oz1bii
Hello Ben
Thanks for the answer - allthough it did'nt fullfill my hope :-)
Maybe it was a small change in the program.
It is logs from different operators put together in one log for printing.
I must make a change in the operator field before import.
Again thank you for reply and for the super program.
