IOTA confirmation
IOTA confirmation
Hello,
I do have a QSO with a given IOTA island confirmed on the respective band/mode as show in the "Worked IOTA" window, but the Main window shows it as light-blue (unconfirmed) and it also show up in DXCluster.
Is there anything I have set up wrongly? (I do have Suppress CFMD selected in DXCluster)
Dani
YO5LD
Dani
YO5LD
- Capture.PNG (74.12 KiB) 10701 mal betrachtet
Re: IOTA confirmation
Hi Dani,
just an educated guess based on your colur scheme for confirmed in the main window:
What are your settings for QSL in settings-station-coulour/qsl?
Card and LoTW activated for IOTA?
73 de Adi
73 de Adi
Hello Dani,
Normally only paper QSL and Clublog (via RSGB) count for "confirmed IOTA".
I can't tell for sure which (green) confirmations you have in View-IOTA.
Hello Ben. Dark-green is LoTW and the other green is Paper QSL.
I just imported ClubLog matches into UcxLog. Let's see how that changes things.
By the way, RSGB accepts LoTW as "IOTA Confirmation" too.
Now I 'X'ed everything in QSL in settings-station-coulour/qsl?.
let's see how it works. Might have been again an issue with the user..
Dani
Dani
Hello Dani,
I see the two greens in the lower left corner but I can't identify in the Band/IOTA table which green it is.
Where is settled that LOTW confirmations count for IOTA ?
On https://www.iota-world.org/iota-directo ... dures.html
"Application procedure" I find only
- Paper cards",
- IOTA contest and
- Clublog matches
In the table it's mostly LoTW.
Indeed, in the "procedures" pdf LoTW isn't mentioned, but after logging in to the IOTA platform, there's a "Add QSOs from LoTW" option:
- Screenshot 2023-03-28 at 11.16.59 AM.png (67.88 KiB) 10653 mal betrachtet
Ok, did you set LOTW for IOTA in "Settings-Station-Color/QSL ?
The problem is, that LOTW or Clublog confirmation are not always automatically = "IOTA confirmed".
This needs the additional confirmation of IOTA committee because every IOTA activation must be reported and acknowledged.
Hello again.
Still unsure if I'm doing something wrong
The confirmation for the IOTA is LoTW not paper (green color mostly match)
Can't upload screenshots due to size, so I'll post Google Photos links:
Settings/QSL: https://photos.app.goo.gl/ZNBdB32Rw6ob5raS7
Worked IOTA window: https://photos.app.goo.gl/VyHTuhEUo6utdN187
Main+Log window: https://photos.app.goo.gl/pqYiwfPyXJHgECCR7
For some reason, that specific IOTA still shows up as unconfirmed in the main window + DXCluster window.
The "IOTA Confirmation" is not equal to "Clublog Match" or "LOTW confirmation".
If you have "LOTW confirmed" for a QSO it is the confirmatioon for the DXCC entity but NOT the real/final confirmation for the IOTA .
IOTA confirmation needs download/upload by the RSGB IOTA website using
- "My IOTA - Add QSOs from LOTW" or
- "My IOTA - Add QSOs from Clublog".
Then the IOTA server logs into your LOTW/Clublog account and retrieves the QSOs.
The result should be a CSV-File which can be imported in "QSL - Clublog - Import CSV-File (RSBG-IOTA)" .
The result are the "real" confirmed IOTA.
I hope that this procedure is still unchanged by RSGB.
You can switch the meaning of the shown "C" in tables using "Settings- Station Colors/QSLs" field "QSL report C"
I fear that this doesn't yet work for LOTW but I think you can transfer the QSOs from LOTW to Clublog
I don't like to introduce such an IOTA double meaning for "L" (Lotw confirmations).
Ok, by downloading the IOTA CSV and ingesting it, it works as expected with the configuration sent above.
I will think about whether the presentation of the IOTA confirmations can be improved and how LOTW can be included.
But that will take some time ...
I think the current way is fine, but I didn't find any reference on it, what counts and what doesn't for a IOTA confirmation.
Yes, if you understand the current way, it is fine.
I can't change anything about the procedure at IOTA.
Hello,
I added explanations in the Help chapter "Settings - Station - Colors/QSL" of version 8.28 Beta 4.
There was already an related post: viewtopic.php?p=13596#p13596
