DXCluster old spots
YO5LD
DXCluster old spots
Beitrag von YO5LD »
Hello,
in cases when UCXLog is running in the background for long times, and a restart happens, really old spots are loaded into the DXCluster window, then disappearing, other spots loaded and so on.
After like 5 minutes, everything stabilizes and only new spots are appearing.
What could be the issue?
Thanks,
Dani
YO5LD
Re: DXCluster old spots
Hello Dani,
what exactly means "running in the background" and what is a long time?
What is a "restart"?
YO5LD
Beitrag von YO5LD »
I keep my machine open 24/7 and UCXLog running 24/7, often for 4-5 days plus.
Restart being closing UCXLog and reopening it.
YO5LD
Beitrag von YO5LD »
A screen recording here where I just closed and reopened UCXLog: https://drive.google.com/file/d/1fBhfm_ ... sp=sharing.
It can be seen that it starts up with 0/9000 spots, at the beginning some very old ones (6Y7ei was 13th to 24th March 2025) which are appearing then disappearing.
You must switch off the "Protocol File" in "Settings - Station - Other interfaces - DX Cluster".
Because the spots didn't contain a date information, you reload too much outdated spots.
If you run UcxLog for such a long time, this protocol is not needed and not useful.
YO5LD
Beitrag von YO5LD »
That worked. Also removed the 166 MB file aswell..
Don't remember me activating it that, but it's fine.
Thanks for the help
