Can not start UCXlog after power down of PC
I had en unexpected power down of my PC with UCXlog on and working. Now I cannot restart the program. I get the following error message: ”UCXlog was already started for this log directory. If this is wrong you must do Windows ”New Start””. Suggestions how to fix would be appreciated?
Re: Can not start UCXlog after power down of PC
Hello Dag,
there is the hint
there is the hint
Did you try this ?... you must do Windows ”New Start”
Than you for the quick reply. No, I have not tried New Start. I will do so momentarily.
73 / Dag (SM5LW)
73 / Dag (SM5LW)
Further to my previous email, i turned off the computer and restarted. Attempting to start UCXlog resulted in the same error message.
Is this what is meant with ”New Start”. I searched for infomation regarding New Start. I have not found a clear-cut definition. What is meant with ”New Start” in the error message?
73 / Dag
73 / Dag
I don't know the exact english wording in Windows...
If you finish windows using the off switch in the task bar there is a selection:
- Lock
- Sleep
- Shutdown
- Restart
You must use "Restart"
- Lock
- Sleep
- Shutdown
- Restart
After ”Restart” the program works. Thank your for the advice.
73 / Dag
73 / Dag
Ok, I will improve the UcxLog message to
73 Ben... you must do Windows ”Restart”
