Can not start UCXlog after power down of PC
sm5lw
Beitrag von sm5lw »
I had en unexpected power down of my PC with UCXlog on and working. Now I cannot restart the program. I get the following error message: ”UCXlog was already started for this log directory. If this is wrong you must do Windows ”New Start””. Suggestions how to fix would be appreciated?
Re: Can not start UCXlog after power down of PC
Hello Dag,
there is the hint
... you must do Windows ”New Start”
Did you try this ?
sm5lw
Beitrag von sm5lw »
Than you for the quick reply. No, I have not tried New Start. I will do so momentarily.
73 / Dag (SM5LW)
sm5lw
Beitrag von sm5lw »
Further to my previous email, i turned off the computer and restarted. Attempting to start UCXlog resulted in the same error message.
Is this what is meant with ”New Start”. I searched for infomation regarding New Start. I have not found a clear-cut definition. What is meant with ”New Start” in the error message?
73 / Dag
I don't know the exact english wording in Windows...
If you finish windows using the off switch in the task bar there is a selection:
- Lock
- Sleep
- Shutdown
- Restart
You must use "Restart"
sm5lw
Beitrag von sm5lw »
After ”Restart” the program works. Thank your for the advice.
73 / Dag
Ok, I will improve the UcxLog message to
... you must do Windows ”Restart
